The factory motor mounts are terrible - Mustang Evolution
Old 05-19-2015, 02:28 PM   #1
jande063's Avatar
This, more than anything else, is why the 2011 and up cars have trouble shifting. It has nothing to do with which shifter is installed, because the transmission is still wildly bucking around under the car (likely the reason for the plus sized transmission tunnel, and the two piece driveshafts for everyone).
I made this video at a local test and tune's slalom course this weekend. I did not launch the car (typical launch procedure is tach to 3500 rpm, side step off the pedal, and floor it) Keep in mind that I was on 300 run A6's (while sharpie does not give you grip, it WILL get you through tech inspection), which are about as grippy as polished marble (the A6 goes sharply downhill after 40-50 runs).
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 05-20-2015, 03:30 AM   #2
Strange Mud's Avatar
I keep telling people how much new motor mounts helped in the shifting of my V6. For me they were the biggest improvement.
Jande, nice mod list
Old 05-20-2015, 06:05 AM   #3
ponie1992's Avatar
Can't watch the video on my phone. Is it on you tube?
Jeremy
Jeremy
2016 Ruby Red PP GT
ponie1992 is online now   Reply With Quote
Old 05-20-2015, 08:21 AM   #4
This is also why either the MGW Race spec or the blowfish bracket (a good deal if you buy used) are a drastic improvement. It allows the shifter to move with the driveline instead of anchoring it to the body and smooths out a lot of situations where it would bind due to the driveline moving.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is online now   Reply With Quote
Old 05-20-2015, 09:31 AM   #5
WJBertrand's Avatar
^^^This!
In my opinion this is the best solution as it prevents the excess NVH from being transmitted into the structure of the car that you will get with stiffer mounts.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 05-21-2015, 08:12 AM   #6
RaceRed3.7's Avatar
interesting..
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
Old 05-21-2015, 12:04 PM   #7
jande063's Avatar
It certainly explains some of the nervous handling characteristics when driven truly fast. I was wondering what was causing that little extra push a split second after corner entry...
I guess that it is time to ninja some factory mounts to do a poly injection, followed by a torque damper.
Old 05-22-2015, 01:26 AM   #8
VERY interesting thread. Thanks for the info!
2014 V6 manual
Charlotte Stang is offline   Reply With Quote
Old 06-04-2015, 10:20 AM   #9
20prima10's Avatar
Does anyone make solid mounts for these v6 motors?
20prima10 is offline   Reply With Quote
Old 06-04-2015, 10:30 AM   #10
Mean14's Avatar
http://www.americanmuscle.com/aje-mo...unts-37v6.html
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-04-2015, 10:33 AM   #11
V6/V8 same mounts
Old 06-04-2015, 11:09 AM   #12
jande063's Avatar
Yeah, they use the same mounts to reduce the amount of inventory needed during assembly. Simplifies the logistic chain, and reduces cost slightly.
Old 06-04-2015, 11:16 AM   #13
You definitely don't want solid mounts unless you only race the car. Also the ones linked earlier require changing out to an aftermarket K member.
Steeda makes these with poly bushings Steeda 2007-14 Mustang Adjustable Heavy Duty Engine Mounts - Made in the USA 555-4005 | Free Shipping! which work with the OEM crossmember.
Old 06-04-2015, 12:22 PM   #14
+1 on avoiding solid....if you have the V6 MT when the dual mass flywheel starts it's decel vibe it is like mild rumble strips. That is with the Urethane mounts...solid would be bad (unless race car)
Old 06-04-2015, 01:10 PM   #15
20prima10's Avatar
If I went with the steeda motor mounts what adjustment would I make for them? Says it has 1/4inch adjustments? I've never used poly styles I've always done solid mounts on cars I've built
Old 06-04-2015, 01:26 PM   #16
Voltwings's Avatar
If you dont have adjustable UCA, you could use whatever setting helped set the pinion angle.
Old 06-04-2015, 02:22 PM   #17
20prima10's Avatar
Don't have uca
Old 06-04-2015, 09:10 PM   #18
5pointYoBro's Avatar
What does it cost to have this installed?
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 06-05-2015, 06:30 AM   #19
Assuming the around 3 hours Steeda states on their site for install time, depending what labor rates are around you I'd probably expect to pay around $300 as a complete shot in the dark estimate. Could be more, could be less.
Old 06-05-2015, 08:41 AM   #20
May be a noob question, but do you need to remove the engine to install them?
Old 06-05-2015, 08:47 AM   #21
Remove no, support yes. You can open the PDF in the link to the steeda mounts and they have the install instructions.
Old 06-05-2015, 10:01 AM   #22
Hints from someone who did them B4:
Disconnect the battery!
I made the mistake of trying to save the oem's it is bad because you need to remove the aluminum blocks that go from the mount to the engine as you can not lift the motor enough to clear the stud on the mount....cut that stud instead and you don't have to remove those blocks which was the hardest part.
doing it the hard way took me 5-6 hrs the easy way would have been 2-3hrs that is from someone who can turn a wrench but not a car mechanic. I will caution again that this added a good bit of NVH but for me was one of the better mods as it eliminated 90% of my missed/blocked shifts. I still have the notchy feeling but like this improvement.
It is simple wrenching somewhat of a pain but look at them and you can see what needs to be done.
Help with motor mounts mlaytonsr1 1996-2004 Mustang GT 4 07-13-2009 03:44 PM
terrible, terrible news. DropTop_Stang The Bar 12 10-18-2003 09:01 PM
06:57 PM
