Limp Mode - Mustang Evolution
Old 05-21-2015, 07:42 AM   #1
BlackKnight92's Avatar
Limp Mode
Yesterday my car went into limp mode, i have no idea why, and im trying get a general idea on it before going to the dealership. My car is all stock minus axle backs. Is it possible that bad gas could cause the issue?
2012 Mustang V6
BlackKnight92 is offline   Reply With Quote
Old 05-21-2015, 07:53 AM   #2
Scott2byrd3's Avatar
Try pulling fuse plug 47 for 15-20 mins put it back in and then start the car see if that works for you. i have to pull this every few weeks or my car drives like a mini van
Scott2byrd3 is offline   Reply With Quote
Old 05-21-2015, 07:54 AM   #3
Thanks, what does fuse 47 control?
2012 Mustang V6
Old 05-21-2015, 08:04 AM   #4
RaceRed3.7's Avatar
Unplug fuse 47 under the hood fuse box. Leave it unplugged for about 10 mins. This will reset the driving habits it has learned and your car will relearn how to properly run. Might work! Worth a try, good luck.
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
Old 05-21-2015, 02:27 PM   #5
Diehard's Avatar
You should try to describe what you mean by Limp Mode. There is a Limp mode that refers to a safety system designed to protect the engine from being damaged during extremely hot temperatures.
Or is it just a little less aggressive than what it has been?
What does it do when you "gun it" in this so-called Limp Mode?
Old 05-21-2015, 03:00 PM   #6
The Wrench icon lights up on my dash, which according to my owners manual is limp mode. I have not tried to get on it when the dash light comes on out of the fear of causing more damage.
2012 Mustang V6
Old 05-21-2015, 03:01 PM   #7
And i thought it may have come on due to it getting too hot, because yesterday is when it popped up, near the end of a fairly long trip (approx 400 miles) but it happened again today about a mile away from home when i left for work.
2012 Mustang V6
Old 05-21-2015, 03:47 PM   #8
My car was recently doing this. All I had to do was turn it off and back on it would then drive normal. I put it in the shop and they said the throttle body was going bad. I got the BBK throttle body and have had no further issues.
andrev6 is offline   Reply With Quote
Old 05-21-2015, 07:21 PM   #9
Diehard's Avatar
Excuse me for asking, but did you check your coolant level.
Old 05-22-2015, 07:18 AM   #10
I did, it looks just fine. So I pulled fuse 47 and did the entire idle relearn procedure, along with got a full tank of gas from a different gas station. It didnt go into limp mode almost the entire day. However, after a hard stop (somebody cut me off so i had to slam on the breaks) it came back on when accelerating, it lurched from a stop and squealed the tires even though i barely touched the gas. And then it was like it almost downshifted (automatic trans) and the RPMs jumped to 5-6k. Could a throttle body be the cause of this like andrev6 mentioned?
2012 Mustang V6
Old 05-22-2015, 07:27 AM   #11
Strange Mud's Avatar
TB is a fairly common issue and my internet guess too.
Strange Mud is online now   Reply With Quote
Old 05-22-2015, 08:17 AM   #12
Anybody happen to be selling a throttle body by chance?
2012 Mustang V6
Old 05-22-2015, 06:18 PM   #13
VIG
VIG's Avatar
Region: Delaware
Before I did any fuse pulling or other attempts to mask the problem, I would check for codes. There could be pending codes in there that could clue you in.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 05-23-2015, 09:48 AM   #14
Blogger
99ford's Avatar
Is your Air filter clean and the assembly tightly attached to the throttle body?
Beyond that I had a similar problem caused by the Throttle Position Sensor.
Old 05-25-2015, 01:44 PM   #15
AngryTech's Avatar
pmd you
AngryTech is offline   Reply With Quote
Old 05-26-2015, 08:35 AM   #16
Update: I brought it into the dealership Friday, Its the Transmission. They are going to completely replace it under warranty.
2012 Mustang V6
Old 05-26-2015, 09:09 AM   #17
bad news/good news.
it's nice they are hooking you up
ya should have bought a manual......
Old 05-29-2015, 10:33 PM   #18
Blogger
99ford's Avatar
Originally Posted by Strange Mud View Post
bad news/good news.
I can't say anything because I wish I had bought the Manual in 08. The Autos have been far more reliable in the 11-14 years.
But I can't disagree with strange mud, it's a completely different experience.
Old 05-30-2015, 07:30 AM   #19
FastFord13's Avatar
Idk, I'm starting to read more and more auto issues....
One thing i can say about our manuals is they suck in the cold until they finally warm up with or without ford's tsb fluid swap.
Could be worse though, my manual could have been built in China lol!
Oh wait......
Sent from LG G3.
Old 05-30-2015, 08:53 AM   #20
paintmann111's Avatar
I had this same problem with my auto a week after buying the car. I doubt anything is wrong with the transmission...my issues was a plug became slightly loose causing the car to go into limp mode. If I shut the car off for a bit it would be fine until I hit a bump or braked hard. They read the code, lifted the car and pushed the connector all the way on, lowered the car and handed me the keys. Haven't had an issue since. My dealership has a ton of real good mechanics, I could see other places reading the codes and just throwing in a new transmission on fords dime. Problem is, with those types of mechanics I then would be worried about the install. lol
For reference the code gave the indication of a transmission fault, but the mechanic had seen it before and new to check the plug first.
paintmann111 is offline   Reply With Quote
Old 05-30-2015, 05:57 PM   #21
I sure am glad this isn't a thread about turning 60.
BrewGuy is offline   Reply With Quote
Old 06-01-2015, 11:26 AM   #22
The thing that threw me off the most was the fact that there werent any codes. It just went into limp mode, and the transmission completely blew when he took it out for a drive to see what it was doing. So unfortunately it wasnt the plug. The good news is I should have it back by Wednesday. Im sick of my Chevy Sonic rental lol
2012 Mustang V6
auto trans limp mode issues...... rinfield2004 Pre-2005 V6 Mustang 8 10-11-2013 11:43 AM
Help! Limp Mode tripping! rinfield2004 Pre-2005 V6 Mustang 0 10-07-2013 02:41 PM
05:42 AM
