Rear diff leaking. - Mustang Evolution
Old 05-21-2015, 03:49 PM   #1
FastFord13's Avatar
Rear diff leaking.
So on the way home today i noticed a faint ticking sound going around 50 kmh,kinda like when we were kids and stuck baseball cards in the spokes but not nearly as loud. I deducted that its not the engine and when i looked underneath the car i noticed my diff leaking from the driver side. Any possible connection?
Sent from LG G3.
ID:	183070   Click image for larger version
Old 05-21-2015, 03:57 PM   #2
Kevin.Cook
Guest
Posts: n/a
I always thought ticking could be exhaust leak or valves in the engine. But you could always fix the diff leak first and see if it helps.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 05-21-2015, 04:04 PM   #3
FastFord13's Avatar
Well i get her up to speed until i can hear it then i put it in neutral and as i coast slowly slowing down the ticking slows down with the cars slowing speed, as if something is ticking in the wheel.
Sent from LG G3.
Old 05-21-2015, 04:50 PM   #4
Kevin.Cook
Guest
Posts: n/a
I would replace the gasket and refill the diff fluid. See if that does it. If not, at least you got 1 thing ruled out.
Old 05-21-2015, 05:56 PM   #5
WJBertrand's Avatar
It's probably blowing oil out the breather cap. Ford has a TSB to fix this or you can add an aftermarket expansion reservoir. The Ford fix is I think free, but less effective / durable than some of the aftermarket solutions.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 05-21-2015, 06:05 PM   #6
tym_v6's Avatar
^ Yeah, I think it's just the rattle cap vent. I had the Ford fix done, as I wasn't interested in dropping $100 plus for an aftermarket expansion tank.
Old 05-21-2015, 08:19 PM   #7
Diehard's Avatar
I wouldn't jump to any assumptions.
I would put a little time into trying to find the source of the ticking sound. Being of such a high frequency, as you described, would bring to mind a higher frequency than the revolutions of a wheel or even a drive shaft for that matter. More like a multi tooth gear, such as a ABS gear or similar. I mention ABS gear as that is typically external and visible and could be subject to picking up something. Just some food for thought.
Same with rear end leak. As I see it, putting some effort into pinpointing the source of the leak should be your first step.
Old 05-22-2015, 10:55 AM   #8
FastFord13's Avatar
Well upon further investigation it appears to be coming from the breather valve up top, the pinion bearing and gasket look O.K. Made an appointment for Tuesday to get it repaired as my warranty runs out next month.
Sent from LG G3.
Old 05-22-2015, 10:59 AM   #9
FastFord13's Avatar
The ABS gear is a great suggestion! Is it something i clean/repair or is it dealer work?
Sent from LG G3.
Old 05-22-2015, 11:09 AM   #10
tym_v6's Avatar
^ If you pull the wheel, you *might* have enough access to visually check the ABS ring and even hit it with some compressed air if there's lodged debris. You *might* need to remove the rotor to get bst access...can't remember off the top of my head.
Old 05-22-2015, 11:19 AM   #11
Diehard's Avatar
Sent from LG G3.
To be honest, I haven't seen it on the mustang, nor have I looked for it. But I would guess most cars would be similar. I tried googling and came up with this picture. Should give you an indication where they're typically located.
ID:	183132Click image for larger version
Old 05-22-2015, 12:49 PM   #12
I just put my wifes 2013 on a rack and the pinion seal is leaking and throwing lube all over. it goes in Tues for warranty work.
2013 V-6 AUTO COUPE
1965 MKII Roadster Factory Five
steve63 is offline   Reply With Quote
Old 05-22-2015, 02:21 PM   #13
tym_v6's Avatar
^ Make sure they service the vent and check the fluid level. If low, have them inspect the internals of the diff for damage. I had my seal leak, combined with a fluid underfill condition (most likely from a dealer screw-up), and wound up needing new bearings and gears.
Old 05-22-2015, 02:31 PM   #14
FastFord13's Avatar
Well i might have found the issue, damn ford sticker wrapped around the DS that came loose, gonna take it around the block and report back.
Sent from LG G3.
ID:	183153   Click image for larger version
Old 05-22-2015, 02:48 PM   #15
FastFord13's Avatar
So after a spin around the block the noise is gone. Just the damn factory DS sticker. So to anyone who has a similar issue check your DS sticker first, could be as simple as that.
Sent from LG G3.
Old 05-22-2015, 02:50 PM   #16
Kevin.Cook
Guest
Posts: n/a
Don't you just love how when an issue with noise occurs, there is about 5,000 possible culprits? And sometimes it is the most trivial. Glad to see you fixed it with minimal effort/cost.
Old 05-22-2015, 03:14 PM   #17
Diehard's Avatar
Sent from LG G3.
I don't think that's covered by the warranty!
Old 05-22-2015, 03:30 PM   #18
FastFord13's Avatar
+1. How many times have we taken our cars into the dealership for a noise, only for them to say they can't reproduce/hear it lol.
Sent from LG G3.
Old 05-23-2015, 04:35 PM   #19
tym_v6's Avatar
"Warranty void if sticker removed. "
Old 05-23-2015, 05:52 PM   #20
Sterling S197's Avatar
If you want to avoid the sticker issue, remove the entire driveshaft and replace it with an aftermarket aluminum DS. Just sayin'...
- Sterling S197 (aka Magnetic S550)
Sterling S197 is offline   Reply With Quote
Old 05-25-2015, 06:47 AM   #21
Hampton CIT's Avatar
Those aftermarket driveshafts have high quality stickers. Don't skrimp when it comes to stickers man.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 05-27-2015, 06:13 PM   #22
FastFord13's Avatar
Lol, +1!
Sent from LG G3.
Old 05-27-2015, 06:16 PM   #23
FastFord13's Avatar
:Update:
So my car went in to have the leak fixed under warranty as my bumper to bumper is up in two weeks, turns out it was the breather valve that was replaced. Apparently there is a tsb.
Sent from LG G3.
Old 06-01-2015, 08:51 PM   #24
I had this same problem...brought it to the dealer and they replaced it, only for it to leak again after 5k miles.
mustanguitarist is offline   Reply With Quote
Old 06-02-2015, 04:30 AM   #25
FastFord13's Avatar
Oh great lol. Well at least it was free this time.
Sent from LG G3.
Old 06-02-2015, 04:29 PM   #26
WJBertrand's Avatar
That's why I decided to bite the bullet and install a JLT reservoir instead. All nice and tidy dry there since.
-Jeff-
Ventura, CA
Old 06-27-2015, 11:00 AM   #27
FastFord13's Avatar
:Update:
So after a month of having the breather valve replaced under warranty I notice its leaking again lol. I was looking under my car because i have that ticking sound again and noticed the remainder of the sticker on the driveshaft starting coming off......again.
Any links to replacing the oem breather valve with something aftermarket?
Sent from LG G3.
Old 06-27-2015, 01:02 PM   #28
tym_v6's Avatar
Expansion reservoir would be best. Personally, I just let mine vent a bit...free rustproofing!
Rear diff leaking? NicholasP 2011-2014 V6 Mustang 5 03-03-2014 07:00 PM
Leaking oil from rear diff. redbeast0712 2011-2014 Mustang GT 6 12-17-2013 03:39 PM
RTV or Gasket for my rear Diff that is leaking drusmith 1996-2004 Mustang GT 5 03-07-2011 02:15 PM
Rear Diff is leaking, OH NO!!!!!!!!!!!!!! drusmith 1996-2004 Mustang GT 13 02-21-2011 03:55 PM
Rear diff oil change help ctstang Pre-2005 V6 Mustang 1 10-28-2006 06:50 PM
02:19 AM
