Caster Camber Plates and Strut Tower Brace - Mustang Evolution
Old 05-25-2015, 05:49 PM   #1
Hampton CIT's Avatar
Looking at caster/camber plates on my V6 to handle some Eibach springs and lowering. Anyone know if you can still use your strut tower brace with these plates installed?
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 05-25-2015, 05:54 PM   #2
RomanG's Avatar
I think only the 2 point strut tower brace is usable after camber caster plate installation. 4 point will be a no go because of the 5th added nut.
RomanG is offline   Reply With Quote
Old 05-25-2015, 06:11 PM   #3
forceflow2's Avatar
My 2 point one works fine with them.
2013 V6 Premium GHIG purchased 01/16/13
forceflow2 is offline   Reply With Quote
Old 05-26-2015, 04:50 PM   #4
jande063's Avatar
You will be able to keep your strut tower bar.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 05-26-2015, 09:33 PM   #5
oxford5pointoh's Avatar
I have the Steeda cc and the studs are long enough to retain the strut bar like others have said. One issue I ran into was my Morroso oil air separator bracket needed to be drilled out a bit. So the studs are a bit bigger or wider.
IG @Oxford5pointoh
Strut and caster camber plates install ab_mach1 1996-2004 Mustang GT 24 04-18-2015 08:17 PM
J&m Caster Camber Plates with SR Strut Tower Brace JoeyM91 Mustang DIY and Technical 0 09-08-2014 01:29 PM
Plates for Steeda/SR Strut Tower Brace? Hulk 5.0 2011-2014 Mustang GT 0 06-11-2014 01:37 PM
M M Caster Camber Plates + Ford Racing GT500 Style Strut Mount racksteris 2011-2014 Mustang GT 6 01-29-2013 05:21 PM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
01:25 PM
