BBK Shorty Ceramic Headers - Mustang Evolution
Old 05-26-2015, 08:31 PM   #1
Kevin.Cook
Guest
Posts: n/a
So I didn't notice until today. But after installing the headers, I hear an extremely faint tick tick sound at idle. I try listening to both sides where the headers are and it sounds like the sound is coming from both sides? I normally drive with the radio on but didn't today and that is when I heard it. With the radio on, you wouldn't even hear it.
I checked that all of the bolts were tight. I took everything apart and redid the headers. They are using OEM Ford gaskets. Everything is tight. I am not noticing any crazy performance issues or anything. The tick tick gets a little louder as I accelerate past 30 MPH.
Is this normal with these headers? I have not drove my car much since the install due to wisdom tooth surgery. I did not hear this when I initially did the install.
Idk, it just doesn't seem normal to me.
Old 05-26-2015, 09:51 PM   #2
03Graymach's Avatar
Gaskets are not reusable get new gaskets and see if it is still there
03Graymach is offline   Reply With Quote
Old 05-26-2015, 09:52 PM   #3
Mean14's Avatar
Yeah I never understood why people reuse the stock gaskets. You have new gaskets provided by bbk. Use them.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 05-26-2015, 09:58 PM   #4
5pointYoBro's Avatar
They sell BBK gaskets on americanmuscle separate.
Or maybe it was latemodelrestoration
Like 25 bucks or something
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 05-26-2015, 10:33 PM   #5
jonyou's Avatar
Brand new OEM gaskets are under $20. They are going to be better since they are metal instead of steel core with graphite.
Correct me if I'm wrong but I'm pretty sure he bought new OEM gaskets.
2014 V6 Performance Package Sterling Grey
MPT Tuned.
Airaid CAI, BBK Shorty Headers, Borla S-types, Stubby Antenna, JLT Catch Can, MMD hood struts, GT500 spoiler, Oracle Halos on GT Grille, Dynotech One piece Aluminum Driveshaft.
jonyou is offline   Reply With Quote
Old 05-26-2015, 10:37 PM   #6
03Graymach's Avatar
If that's what he was saying the ok I may have miss understood the other thing is did you use a you torque them to spec or just use a rachet till you could not get it tighter and try spraying then with soapy water where the connect to see if it starts bubbling
Old 05-27-2015, 01:35 AM   #7
Kevin.Cook
Guest
Posts: n/a
I did not try the soap method. I will take a look at that.
I went by the BBK install document and it doesnt mention the bolt's torque specs. In fact, their document doesn't get really specific at all. Like tools needed/size of bolts, etc.
I am no wiz at bolts so m10 means nothing to me. A 13 and a 17 would have sufficed.
Sent from my SAMSUNG-SM-G900A using Mustang Evolution mobile app
Old 05-27-2015, 07:03 AM   #8
03Graymach's Avatar
I would look up stock torque specs and use a torque wrench all that needs to be torque to spec
Old 05-27-2015, 07:06 AM   #9
RaceRed3.7's Avatar
I get this sound too with the chrome headers. I am not very happy with the bbk shorty headers. Not much power gained if any and the sound is close to the stock headers.
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
Old 05-27-2015, 07:11 AM   #10
Voltwings's Avatar
my headers + h-pipe made a ticking sound. I figured it just came down to a unique noise the unique combination made and never thought anything of it. Granted, mine is a 5.0.
Old 05-27-2015, 07:54 AM   #11
Kevin.Cook
Guest
Posts: n/a
Is there any sealant or anything i can put around where the header meets the engine just to be safe? With the hot temps, I am not sure what can withstand the heat ok.
Old 05-27-2015, 07:57 AM   #12
Voltwings's Avatar
Shouldnt need a liquid sealant on the exhaust, and i also doubt there is anything that would take the heat.
Old 05-27-2015, 08:08 AM   #13
Kevin.Cook
Guest
Posts: n/a
Well, i wonder if the cut n clamp x pipe I am getting in July will help or hurt the sound. :/
Old 05-27-2015, 08:12 AM   #14
Jon3.7's Avatar
if the gasket are metal, normally you can reuse them, if they aren't toss them and get new ones.
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 05-27-2015, 08:16 AM   #15
Kevin.Cook
Guest
Posts: n/a
I did buy new ones. I mentioned this in another thread when I first did this. LOL. Idk why everyone is mentioning me using old ones.
Yea those OEM ones were $10 per side on Ford and the shipping and tax was like another $10 O_O
Old 05-27-2015, 08:19 AM   #16
Jon3.7's Avatar
haha, localdealer doesn't have any
Old 05-27-2015, 08:22 AM   #17
Kevin.Cook
Guest
Posts: n/a
I sometimes buy from other dealers in Austin and just get them shipped to me. You should be able to search for other dealerships on the Ford Parts website.
Old 05-27-2015, 08:47 AM   #18
The increased sound is normal from what I've seen of people installing headers. Just not as much deadening as the the heavy cast stockers provide.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 05-27-2015, 08:49 AM   #19
Kevin.Cook
Guest
Posts: n/a
I will drive it for a bit and check it again next weekend. Sounds like I got a rattle snake in my engine bay. LOL
Old 05-27-2015, 09:36 AM   #20
Diehard's Avatar
Never heard of anyone ever being able to torque those nuts on the BBK headers. Is it even possible?
Old 05-27-2015, 09:41 AM   #21
Kevin.Cook
Guest
Posts: n/a
This just sounds soo wrong.
But in a sense, I agree. Tell me how you got a torque wrench to some of the bolts on these shorty headers I barely got a little basic wrench in on some of them. Probably why BBK doesn't have these specs in their guide. More of a "good luck getting these tight as it is" type thing.
Old 05-27-2015, 11:19 AM   #22
03Graymach's Avatar
That's because shortys do not give you any power in my opinion shortys are a waste of money
Old 05-27-2015, 11:21 AM   #23
Diehard's Avatar
That's my exact point. How would you get a torque wrench on those nuts?
In fact, I looked in the 2013 Repair Manual and in the torque chart for Exhaust manifold nuts, it was blank with a reference to a note which read, "Refer to the procedure in this section". I couldn't find what they were talking about.
I'm going to look a bit further just for the hell of it.
Old 05-27-2015, 11:21 AM   #24
Kevin.Cook
Guest
Posts: n/a
Thanks. I appreciate your extremely unhelpful comment.
Old 05-27-2015, 11:23 AM   #25
Kevin.Cook
Guest
Posts: n/a
Yea I hear you. When I showed the tech that helped me, he almost wanted to quit after examing the new headers. lol. He said the way the tubes looped near the bolt holes told him it was going to be a PITA. HAHA
Old 05-27-2015, 12:23 PM   #26
Hampton CIT's Avatar
Kevin, you shouldn't reuse those gaskets, that's your trouble. LOL.
Hampton CIT is offline   Reply With Quote
Old 05-27-2015, 12:27 PM   #27
Voltwings's Avatar
Please, elaborate?
Old 05-27-2015, 12:40 PM   #28
Kevin.Cook
Guest
Posts: n/a
Aww man! Yall are killin me!!! LOL!
Old 05-27-2015, 02:46 PM   #29
Diehard's Avatar
It's probably not even leaking.
On the other hand, did you put back all 12 nuts? JK
Old 05-27-2015, 02:48 PM   #30
Kevin.Cook
Guest
Posts: n/a
All right. You got me! The headers are attached via gorilla glue!
Just kidding
Old 05-27-2015, 03:02 PM   #31
fomoco4life's Avatar
Originally Posted by Voltwings View Post
Please, elaborate?
If it's a NE 4.6 2v, the stock manifolds are already a decent flowing, shorty header. LT headers, however, will show significant gains.
Old 05-27-2015, 03:04 PM   #32
Kevin.Cook
Guest
Posts: n/a
Yea maybe that person was just in the wrong thread then. These are the 11-14 3.7s. Stock manifolds are very restrictive looking compared to even the shorties.
Old 05-27-2015, 06:20 PM   #33
Mean14's Avatar
You're going to have the same exact setup that I have. Dude, you're going to love it.
Old 05-27-2015, 06:26 PM   #34
Kevin.Cook
Guest
Posts: n/a
Yea. I didnt want a loud raspy exhaust. This setup, from what i have heard, is a deep mean sound. For the v6.
Old 05-27-2015, 06:28 PM   #35
Mean14's Avatar
It really is. Spent hours searching for the right setup because I didn't want raspy nails in a blender sound. Its perfect IMO.
Wanted: BBK Shorty Ceramic Headers for 3.7 lisl12 Mustang Parts for Sale and Wanted 5 03-13-2015 07:16 AM
Wanted: Bbk shorty ceramic headers for 3.7 jonyou Mustang Parts for Sale and Wanted 1 02-26-2015 07:41 AM
Advice on BBK CERAMIC TUNED LENGTH SHORTY HEADERS raykrieg Pre-2005 V6 Mustang 0 01-25-2015 09:08 PM
Bbk shorty ceramic header install tips for large handed people 14mustang 2011-2014 V6 Mustang 8 10-23-2014 06:00 AM
BBK Ceramic Shorty headers GrabberBlue1993 2011-2014 V6 Mustang 64 10-22-2014 08:49 PM
12:11 AM
