Illuminated Door Sill Plates - Mustang Evolution
Old 05-29-2015, 11:24 AM   #1
white14v6's Avatar
Has anyone on here installed the illuminated door sill plates on a 2014. I have the kit but need some more detailed instructions.
Instagram: jrlewis_3.7
white14v6 is offline   Reply With Quote
Old 05-29-2015, 11:26 AM   #2
Kevin.Cook
Guest
Posts: n/a
Did you get the accessory kit from Ford? Coming from a 2011 Premium, I couldn't install them in my 2014. They looked like knock offs. So I bought pull outs from another Premium so I could get them to change to the color Blue.
You will have to wire the passenger up through the A pillar on the Passenger's side. Then for the drivers side, you feed the wire through under the dash. You tap in to the dome lights. If you tap in to the wrong one in the wire harness, you will blow a fuse to something or the car won't start. lol. Ask me how I know.
The harness in the A pillar that you tap in to seems to be different for different years.
http://mustangforums.com/forum/2005-...with-pics.html
That link will give you a basic outline. Keep in mind the color of the wires in the harness is different for your year. So don't tap in to the wrong ones. If you do, keep some spare fuses handy. LOL
Old 05-29-2015, 12:37 PM   #3
Mean14's Avatar
I recently added some footwell LEDs on my 14. I tapped into the dome light so it illuminates when doors open and dims to off when shut. Just so you know, it is the gray/purple wire in the dome light. Click image for larger version
Name:	ImageUploadedByMustang Evolution1432924373.180925.jpg
I then wired it to a connector if I ever have to take the dome light off for whatever reason..
Name:	ImageUploadedByMustang Evolution1432924449.247153.jpg
Looks pretty cool at night when opening the doors, and emits a heck of a lot more light than the dome alone..
Name:	ImageUploadedByMustang Evolution1432924503.920290.jpg
By tapping into that wire pictured, it will illuminate when the doors open and dim when shut just like the dome light. If you turn them on from the switch next to the headlight switch, it will also work. But, if you click the button/s on the dome light itself, they will not illuminate.
This is for a 2014 mustang v6. May be different with other years/models.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 05-29-2015, 01:05 PM   #4
white14v6's Avatar
That's my problem with all the different color wires
Old 05-29-2015, 01:26 PM   #5
Mean14's Avatar
Well what are you trying to achieve?
Old 05-29-2015, 01:32 PM   #6
white14v6's Avatar
I just want to install them with it lighting up blue but I can't find how to wire the passenger side.
Old 05-29-2015, 01:32 PM   #7
Mean14's Avatar
The same as the drivers side? lol
Old 05-29-2015, 01:34 PM   #8
white14v6's Avatar
It says start with the passenger side so that's what I meant.
Old 05-29-2015, 01:37 PM   #9
Mean14's Avatar
Tap into the gray/purple wire in the dome... Did you read my previous post?
Old 05-30-2015, 10:46 AM   #10
tezz's Avatar
Run the wires down from the A pillar after splicing into the wires described - split them under the dash to run one set to the drivers side, one to the pass side . Note the connectors to the sill plates are a 4 (if I remember correctly) wire connector. If you don't have my color you will have to find the combo for the right color you want. The sill pigtail wires are all black.
If you actually bought a Ford install kit(?) this may be different.
tezz is offline   Reply With Quote
Old 05-30-2015, 11:28 AM   #11
Kevin.Cook
Guest
Posts: n/a
The ford install kit just has a negative and positive. It doesnt allow for changing of light colors.
Old 05-30-2015, 12:50 PM   #12
white14v6's Avatar
I bought this kitClick image for larger version
Name:	ImageUploadedByMustang Evolution1433011810.193905.jpg
Old 05-30-2015, 06:04 PM   #13
white14v6's Avatar
Is the black/yellow wire the ground wire?
Old 05-30-2015, 06:21 PM   #14
oxford5pointoh's Avatar
Yes
IG @Oxford5pointoh
Old 05-31-2015, 08:13 AM   #15
Great info! Thanks for posting and sharing!
GT 1 is offline   Reply With Quote
Illuminated Door Sill Plates sid719e 2011-2014 V6 Mustang 9 09-07-2014 07:23 PM
Illuminated door sill plates grbird88 2005-2010 V6 Mustang 1 06-15-2013 12:47 PM
illuminated door sill plates Alfonso 2011-2014 V6 Mustang 8 06-02-2013 04:38 PM
Illuminated door sill plates. Nocheala 2005-2010 Mustang GT 32 02-12-2013 07:30 PM
Roush Illuminated Sill Plates Install help? USMCSKYLINE 2011-2014 Mustang GT 0 02-03-2013 07:05 PM
10:10 PM
