Help! - Mustang Evolution
Old 05-29-2015, 04:04 PM   #1
Help!
I left my car for 4 months while I was overseas and I think the battery is dead. I tried jump starting it but no success. When I tried jump starting it it just made a clicking noise when I tried to start the engine. All the lights and radio worked when it was hooked up to the other car but nothing else.
Tyler_adams is offline   Reply With Quote
Old 05-29-2015, 04:09 PM   #2
Kevin.Cook
Guest
Posts: n/a
That stinks. Usually this happens to me if I am working on the car and the battery dies. Then I jump it and we are good. Wonder if the battery is bad and not holding a charge. I would take it in and get it tested. It is usually free.
Old 05-29-2015, 04:39 PM   #3
oxford5pointoh's Avatar
If it's that dead it needs a deep cycle charge. One that revitalizes the battery. You won't be able to simply jump a battery that goes completely dead. Get a real battery charger and hook it up over night on a recharge cycle. Low amp. If it's still good, it will bring it back to life. It might be toast though.
IG @Oxford5pointoh
Old 05-29-2015, 06:02 PM   #4
IG @Oxford5pointoh
Also once it goes dead and you revive it, it wont last long before it dies again, SUDDENLY. Replace that battery.
BrewGuy is offline   Reply With Quote
Old 05-29-2015, 06:03 PM   #5
I might add that I am an IBEW electrician. Have been for 38 years.
Old 05-29-2015, 07:17 PM   #6
Just went to auto zone and found out that the battery is shot. This car is less than a year old so I am going to ford and demanding a replacement
Old 05-29-2015, 07:27 PM   #7
Just buy an optima and call it a day. Next time you get deployed you should put a trickle charger on it. I had one on my car when I was in the military. They even make solar powered ones. You can plug them into the power outlet inside the car and it will charge it.
IG @Oxford5pointoh
Old 05-29-2015, 11:11 PM   #8
Abominable Mustang
WhoDat's Avatar
Region: Alaska
In the winter, i usually just disconnect my battery. Two winters so far and it's started up first try after reconnecting it in the spring. That may be a cheaper alternative next time yours goes into storage
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 05-30-2015, 05:28 AM   #9
Strange Mud's Avatar
be nice...it ain't necessarily Fords fault. Batteries do not like not being used. The time away w/o a trickle charger is not good for it. At the minimum you need to disconnect it or somehow either put a tender on it or what I do is charge it for a few hrs 1x month (stored in winter)
while on subject I've seen enough complaints treat your terminals with dielectric grease or some other type of anti corrosion system
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
11:10 PM
