Ran into small problem w/ shorty install... - Mustang Evolution
Old 06-01-2015, 07:06 AM   #1
Dark_Pony's Avatar
First off - anyone trying to do this install yourself: it's possible but well worth the extra $50 or so to have a shop do it. Besides the point, I was removing the passenger side header and dropped one of the nuts. The problem is, I didn't hear it hit the ground. I looked and probed for about an hour to see if I could find it sitting on something in the engine bay but I haven't found a trace of it nor can I rattle anything. Should I really be worried about where it went? I don't have a problem running to Home Depot to try and get a replacement nut but am afraid it's fallen somewhere it shouldn't have - am I being paranoid? This is my daily driver so I've got to have it functional within the next day or so. I just keep imagining starting it up and blowing my car up....
2014 Sterling Grey FP6 w/ Tech package
Current Mods: Gibson exhaust; MMD hood scoop and side scoops; Tinted head lights, tail lights and all reflectors.
Dark_Pony is offline   Reply With Quote
Old 06-01-2015, 07:13 AM   #2
DiESeven's Avatar
Where can you get it installed for $50?
Old 06-01-2015, 07:15 AM   #3
Seriously, for $50 I'd let someone else deal with headers all day long.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 06-01-2015, 07:23 AM   #4
Voltwings's Avatar
it likely ended up in the K-member somewhere. As long as its not binding anything in the steering rack you're fine.
Old 06-01-2015, 07:35 AM   #5
Kevin.Cook
Guest
Posts: n/a
I checked Home Deport in the area I live and as they do sell bolts, they do not sell these studs. You will need to reorder them from ford.
On top of that, they could not find an EXACT bolt match to the stud. So I did not risk trying anything unusual and thread out the hole on the engine. Trust me, you do not want to do this.
However, I could not find them on Ford. I had to order a new Nut and Stud on ebay. I even asked a guy at AM since they did not carry these, he could not find them either.
Hope these help:
Fordlincolnmercury W712244S300 Genuine Manifold Stud | eBay
Ford Manifold Exhaust Exhaust Manifold Nut Left W701706S440 | eBay
Old 06-01-2015, 07:39 AM   #6
Voltwings's Avatar
Try https://www.fastenal.com/home if you have one near you. They're commercial, so their hours are 9-5 which makes things a bit of a pain if you work a 9-5, but they'll likely have what you need, ive had to get studs and washers there a few times for jobs.
Old 06-01-2015, 10:32 AM   #7
Region: New Mexico
Shorty Install
I didn't trust any shops here in Las Cruces, NM to install my shorties. Inquired at a Albuquerque shop: $550 to install. If someone knowledgeable quoted me $50, I"d be there in a heartbeat.
rogcat1 is offline   Reply With Quote
Old 06-01-2015, 10:35 AM   #8
RBK
Donn't worry about where it fell, it can't get into to anything important. If you are really worried buy one of those telescoping rods with a magnet on the end and run it over your frame.
RBK is offline   Reply With Quote
Old 06-01-2015, 11:32 AM   #9
Mean14's Avatar
I had the same problem when taking off my strut brace. Bolt disappeared lol. Had to get a new one from FordParts.com
And if you found a shop to install for $50... You should've done it.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-01-2015, 12:40 PM   #10
Diehard's Avatar
Well hopefully you have solved your problem by now.
If not, if you were not able to get the nut from your local dealer, the next question, as I see it, is to find out the actual size. For example 3/8" x 16, etc.
You have the ford part # but I haven't seen an actual size associated with it.
Of course, you could use one of the existing nuts to figure out the size.
Once you get the correct size it should be easy enough to find a replacement, even if it's just a temporary one.
Old 06-01-2015, 11:52 PM   #11
ak_stang's Avatar
Region: Alaska
My guess is also k member, when I did mine I dropped one of the nuts into the mid pipe, good thing the catalytic converters were there to catch it
Sent from my LG-D801 using Mustang Evolution mobile app
ak_stang is offline   Reply With Quote
Old 06-02-2015, 04:06 AM   #12
Siber Express's Avatar
$50, lowest price around here was $350.
Siber Express is online now   Reply With Quote
Old 06-06-2015, 09:19 PM   #13
Dark_Pony's Avatar
Yeah I've heard average at $200+ for install. Damn I might have paid that too had I known how much of a pain it was. I found a pretty much perfect replacement at Home Depot though. It's a M8×1.25 I think? Anyway it threads right but it's shiny so it's going on the back. Still haven't got them all tight my wrench got stuck on the rear #3 bolt. Might grind the stud down to clear it not sure. Just hope it's worth it...
Old 06-06-2015, 09:23 PM   #14
elkoritaNAY's Avatar
I don't think it was 50 it's probably a typo for 500?
Flowmaster force 2 exhaust, jlt cai, x4 bama tuner, carbon fiber dash overlay kit, modern retro shift knob, mmd hood and side scoops, classic quarter louvers, gt500 spoiler, 3.7 and pony emblems, mustang rocker stripes, eibach anti sway roll bar kit, Bbk shorty ceramic tuned headers
elkoritaNAY is offline   Reply With Quote
Old 06-07-2015, 12:34 AM   #15
NewMtang's Avatar
To get my shorty's installed, it was slightly over $300 and worth every penny of it!
Old 06-07-2015, 12:58 AM   #16
natestang07's Avatar
I envy you all lol
Old 06-07-2015, 05:41 AM   #17
audioAl's Avatar
Me too, I just came into a little money & may get ceramic shorties myself, 1st I want to do 3.55:1 gear change, these 2.73:1 stink!!
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 06-07-2015, 06:57 AM   #18
Do the gears.
Old 06-07-2015, 10:51 AM   #19
Pretzel's Avatar
I got my wrench caught here too, for a second I pondered how bad it would be to have a wrench hanging on my headers for the rest of the cars life, lol!
Pretzel is offline   Reply With Quote
Old 06-07-2015, 11:47 AM   #20
yellowconve's Avatar
my headers only costed me 25 bucks and a 24 pack of beer, the first time and was leaking. then took it back with new felpro gaskets charged me 50$. so i paid like 150 in total for my installation even tho took em twice to fix it lol
0-100 REAL QUICK!!!
yellowconve is offline   Reply With Quote
Old 06-07-2015, 12:04 PM   #21
Diehard's Avatar
I think the "24 pack of beer" tends to help cause leaks.LOL
Old 06-07-2015, 12:15 PM   #22
lol thats what i thought i should of gave them to him hot or after the work on the car lol
0-100 REAL QUICK!!!
Old 06-08-2015, 04:41 PM   #23
Dark_Pony's Avatar
So I got the wrench out and the rest of the bolts on and took her for a spin. I honestly only expected a small increase in HP and was really aiming for better sound and support for future mods. I have to be honest the sound is amazing, but the biggest change was the power! I let my wife drive and she broke the tires loose at a green light by accident, with the traction control on... Now however I'm trying to figure out if I have a leak or not. I used the BBK gaskets and everything looked tight. Maybe might be the change in sound but it seems I can really hear the engine now when accelerating. I wouldn't say it's a "sucking" sound but def something I haven't heard before. At idle I don't hear anything abnormal under the hood, but it sure does still smell like burning oil...
Old 06-08-2015, 06:01 PM   #24
Ha. I did exactly the same thing on my install. Dropped a nut and looked forever trying to find it. Never did. I was in my garage, so I know it didn't fall all the way through. Went to the local Ace Hardware and got an exact SAE replacement for like $0.89. Home Depot sux!
cherry3m is offline   Reply With Quote
Old 06-08-2015, 07:04 PM   #25
Pretzel's Avatar
Congrats man, I love the difference in the sound too! I haven't noticed a sucking sound from my headers, but I used new OEM gaskets...not sure if that makes any difference :/
Old 06-08-2015, 08:17 PM   #26
Dark_Pony's Avatar
Lol yeah HD has its issues... but you work with what you got
Old 06-08-2015, 08:27 PM   #27
Kevin.Cook
Guest
Posts: n/a
You don't hear a sucking sound because they are awesome!!! Lmao!!!!!!!!!
Old 06-08-2015, 09:18 PM   #28
alucard3600's Avatar
My LT header install this weekend is costing me a case of beer and paying for his lunch.
God I hope not!
2014 3.7l Auto Oxford White
Mods: Cervini Stalker Hood, Roush highflow upper and lower grill, AirRaid CAI, LMR strut tower brace,Mac LT headers,Mac Prochamber, Kooks Highflow Cats,Dynomax Race Bullets (resonators), 2.5 o/a pipes, 2011 Gt500 Axlebacks, MPT 93 performance tune.
alucard3600 is offline   Reply With Quote
So I ran into this! DWC_SmOziLLa 2011-2014 Mustang GT 32 07-07-2012 07:15 PM
Big problem-easy find, small problem-hard to find Dnraiders General Mustang Discussion 0 08-30-2011 11:10 AM
Ran into a very nice S197 HotRodRunning General Mustang Discussion 0 03-28-2009 03:29 PM
funny picture I saw a long time ago and ran into again fast64 The Bar 41 07-27-2003 06:01 PM
06:05 PM
