Bbk headers cracked almost completely - Mustang Evolution
Old 06-05-2015, 07:30 PM   #1
So today I hit a bump in the road and almost broke my header completely off at the collector. Almost no damage to anything else but this happened to the header. Being my only car, this sucks....
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
rgstelzner is offline   Reply With Quote
Old 06-05-2015, 07:34 PM   #2
Pretzel's Avatar
Holy crap dude, that does suck! How big a bump did you hit??
Pretzel is offline   Reply With Quote
Old 06-05-2015, 07:35 PM   #3
Kevin.Cook
Guest
Posts: n/a
Sorry to hear about that. When did you buy the header? Is it from AM?
Old 06-05-2015, 07:35 PM   #4
I'd guess 2 inches or so, I'd driven over it numerous times before
Old 06-05-2015, 07:35 PM   #5
doyouevenforum
Guest
Posts: n/a
Your s pen has been detached.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 06-05-2015, 07:40 PM   #6
Yeah I got them from AM, but bbk isn't open on weekends so I had to just order another and pay for them. I need this fixed asap. And yeah I had to use th s pen to circle it lol
Old 06-05-2015, 07:54 PM   #7
Cooolbreeez's Avatar
Did you have a header wrap on there?
Cooolbreeez is offline   Reply With Quote
Old 06-05-2015, 07:55 PM   #8
Nope, no header wrap, and no real signs of wear on the headers otherwise
Old 06-05-2015, 08:17 PM   #9
Kevin.Cook
Guest
Posts: n/a
What I would do, is replace the headers. Then get those welded and fixed. Then sell them to get some money back. Shouldnt cost much for a muffler shop to re-weld those.
Old 06-05-2015, 08:36 PM   #10
Mean14's Avatar
That sucks dude. I'll have to keep an eye out for that on mine. Are they ceramic?
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-05-2015, 08:41 PM   #11
Kevin.Cook
Guest
Posts: n/a
Also, are you lowered?
Old 06-05-2015, 08:56 PM   #12
Yes they're ceramic, and yeah I'm lowered, but only an inch.
Old 06-05-2015, 09:10 PM   #13
Kevin.Cook
Guest
Posts: n/a
Well, get those welded and sell them would be my suggestion.
Old 06-06-2015, 04:41 AM   #14
natestang07's Avatar
Honestly bbk is somewhat no bueno. A few of us here preach it and take a lot of flack. The quality just isn't there with their products and their design is poor. Hope you get fixed up quick, I would talk to am when you can.
Old 06-06-2015, 05:00 AM   #15
Strange Mud's Avatar
just wondering....exhaust hanger broken/missing?
Old 06-06-2015, 10:36 AM   #16
I would RMA them through AM or BBK... get NEW replacements and sell those.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 06-06-2015, 12:32 PM   #17
All hangers are intact, no damage. And yeah, I'll figure something out. Giving BBK a call Monday when they open
Old 06-06-2015, 09:36 PM   #18
Also, if it is unclear in the picture that Crack is directly along a weld
Old 06-07-2015, 12:28 AM   #19
NewMtang's Avatar
Why would someone buy a set of headers that has one cracked and then welded to fix it? Better to have it welded and keep them.
Old 06-07-2015, 08:01 AM   #20
Kevin.Cook
Guest
Posts: n/a
Depends on how good the welding is. Its gotta be better then the bbk welding. Lol!
Old 06-08-2015, 06:22 AM   #21
2011fastford's Avatar
Region: New Mexico
those are just speed cracks... no big deal
2011 Mustang V6 auto/procharger p1sc kit with 3.70 pulley/circle d 3200 stall/4:10 gears/dss aluminum driveshaft/tial q bov/bbk long tubes with catted x pipe/dynomax ultra flo catback/bbk throttle body/accel super coils/cyclone ported upper and lower intake manifolds/brembo front brake kit
INSTAGRAM @2011fastford505
2011fastford is offline   Reply With Quote
Old 06-08-2015, 07:04 AM   #22
so how does it sound now?
poor impulse control
Old 06-08-2015, 07:26 AM   #23
20prima10's Avatar
Bbk welding quality is terrible. I ground every weld on mine and re welded them before instal. Every weld but one had a crack when I got mine. I'm a weld inspector for work so naturally I xrayed all my welds and they are complete junk.
20prima10 is offline   Reply With Quote
Old 06-08-2015, 07:57 AM   #24
It sounds terrible, finishing my drive home was painful. Now with a few mentions of how bad these welds are (and having a leak in the passenger side collector on my first set) I'm wondering if getting them welded shut might be a better option than a new pair...
Old 06-08-2015, 08:07 AM   #25
20prima10's Avatar
Grind the welds and fix them. There's no reason to buy another set with junk welds. I have xrayed a few now and most there welds are junk. Using a pmi gun which tells me the materials used they are using the wrong wire to weld these. Terrible quality on there behalf
Old 06-09-2015, 01:02 PM   #26
I just had that seam re-welded and put it back on my car, being the second issue I've had with their welds I figured it might be better to just have it fixed than put on a new pair. I love the sound/performance but I swear if I have to take those headers off one more time I'll snap and go crazy.
BBK Long tube headers and BBK Catted X-Pipe Rexex 2011-2014 V6 Mustang 8 10-07-2014 05:36 AM
cracked headers stang916 Pre-2005 V6 Mustang 13 06-17-2013 01:14 AM
2010 Shelby GT500: Almost Completely Undisguised! DetroitWonk 2011-2014 Mustang GT 23 01-09-2009 08:59 AM
almost mr lt1...........almost Kyle The Bar 36 06-03-2006 04:39 PM
almost........almost....... Kyle The Bar 26 10-03-2005 06:52 AM
04:47 PM
