Bleeding Brakes - Mustang Evolution
Old 06-10-2015, 12:12 PM   #1
Socal Stangman's Avatar
Bleeding Brakes
I got a good deal on some used Brembos and if all goes well Ill be putting them on this weekend. Is there anything I need to know about bleeding them? I have a manual tranny, does this some how share the master cylinder and if so is it an issue? I plan on using a one man bleeder kit.
Old 06-10-2015, 12:24 PM   #2
Voltwings's Avatar
The clutch is self bleeding, so even though they share a reservoir, the clutch wont be affected when bleeding brakes.
Just mind that there are two sets of pistons, and thus, you must bleed each side of the caliper. So there's a total of 4 spots to bleed in the front, and two in the rear, other than that its just standard procedure; start furthest from the Master Cylinder (PR) and move closest to it (DF).
And honestly, if you have an air compressor, this is the best $30 you can spend, ive done at least 20 full bleeds with this thing and its still runnin strong.
http://www.harborfreight.com/automot...der-92924.html
Old 06-10-2015, 12:26 PM   #3
Ok cool. Ive done BBK's before I just always had auto's so I never had to worry about the clutch. Thanks for the info.
Old 06-10-2015, 01:16 PM   #4
Ill look into that bleeder. I have a Motive bleeder now. I kind of like it, it tends be a little messy and sometimes a pain. It doesn't like to keep pressure all the time.
Old 06-10-2015, 01:17 PM   #5
Kevin.Cook
Guest
Posts: n/a
The word Motive will always give me bad memories...
Old 06-10-2015, 01:51 PM   #6
Just remember only a handful of wheels actually fit the brembos so you might need new wheels and tires fyi
Lan_Evo is offline   Reply With Quote
Old 06-10-2015, 01:55 PM   #7
Kevin.Cook
Guest
Posts: n/a
Or spacers. On my 2014 V6 PP or 13/14 GT/CS Rims, you need 0.5" Spacers.
Old 06-10-2015, 02:00 PM   #8
Lol, yeah I guess so.
Im good with the wheels. I learned that lesson the hard way...once.
Old 06-10-2015, 11:20 PM   #9
Mean14's Avatar
This reminds me...I replaced the stock clutch line with a stainless steel one. I must've pumped the clutch over 200 times before it started to feel normal again.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-11-2015, 08:07 AM   #10
Voltwings's Avatar
^^ Yup, same here. Get your leg workout in for the day haha
Old 06-11-2015, 10:14 AM   #11
Strange Mud's Avatar
200 times the 1st day, and another 100 on the 2nd day
Bleeding the Brakes MustangGTZXR 2005-2010 Mustang GT 8 03-09-2015 07:20 PM
bleeding brakes rajeev2liz 2005-2010 V6 Mustang 2 03-13-2013 06:00 AM
Bleeding Brakes PBrown92 2011-2014 V6 Mustang 1 03-10-2013 09:30 AM
Painting Calipers/Bracket and Caliper Reinstalltion/Brake Bleeding Napoleon85 2011-2014 Mustang GT 22 02-02-2012 04:12 AM
Bleeding Brakes? ridenmystang 1996-2004 Mustang GT 10 06-12-2007 05:14 PM
12:06 AM
