How to remove my trunk emblem - Mustang Evolution
Old 06-11-2015, 03:23 PM   #1
2011 Kona Blue's Avatar
How in the world do you take off and reinstall the trunk emblem? Is it secured with screws from the underside or what?
Have a great day!
ID:	184585   Click image for larger version
Old 06-11-2015, 03:25 PM   #2
Kevin.Cook
Guest
Posts: n/a
I believe on the 2011/12 it is screws.
Old 06-11-2015, 03:29 PM   #3
Strange Mud's Avatar
i THINK it is tabs/3m tape/ I don't like how it looks but it is a convenient close handle that doesn't show fingerprints. I saw one of the 15's the other day and talking to the owner/looking at the smooth shiney back panel when I asked about fingerprints I got the LOOK. Me thinks it's a finger print display board (the 15's)
Strange Mud is online now   Reply With Quote
Old 06-11-2015, 03:37 PM   #4
Socal Stangman's Avatar
On my 14 it's tabs and tape.
Old 06-11-2015, 03:38 PM   #5
Kevin.Cook
Guest
Posts: n/a
This is probably right then.
Old 06-11-2015, 03:44 PM   #6
bigmac3's Avatar
Tabs. I swapped trunk lids with a GT/CS and had to also remove the caps. First, you will have to remove the liner to gain access. Easy-peasy.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
bigmac3 is offline   Reply With Quote
Old 06-11-2015, 03:58 PM   #7
I have an 11 so I wonder if its with screw's or tabs and tape?
Have a great day!
Old 06-11-2015, 03:59 PM   #8
Once I remove the felt liner, should I just pull it off the trunk emblem
Have a great day!
Old 06-11-2015, 04:17 PM   #9
Rapinator126's Avatar
It's just tabs and double sided tape. No screws
Old 06-11-2015, 04:30 PM   #10
Thanks Rap. Appreciate everyone's quick responses.
Have a great day!
Old 06-11-2015, 04:48 PM   #11
Mean14's Avatar
I would heat it up a bit to warm up the adhesive for easy removal. Probably less prone to breaking tabs that way too.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-11-2015, 06:57 PM   #12
Gunner's Avatar
And run dental floss or fishing line between the cap and trunk to separate the tape.
Gunner is offline   Reply With Quote
Old 06-11-2015, 08:07 PM   #13
Hampton CIT's Avatar
Tabs and tape. I used a credit card and small flat head screwdriver to pry mine off for painting. Tabs are flimsy. Take your time and you'll be good. Use some type of card to protect outer decklid cover.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 06-11-2015, 09:43 PM   #14
Good grief, couldn't Ford come up with an easier way for us to remove this. Ha ha
Have a great day!
Old 06-11-2015, 09:49 PM   #15
Harm_3.7's Avatar
Have a great day!
Lmao I asked myself the same question a couple times 😂
Harm_3.7 is offline   Reply With Quote
Old 06-11-2015, 09:50 PM   #16
FastFord13's Avatar
Have a great day!
Dynamite.
Sent from LG G3.
FastFord13 is online now   Reply With Quote
Old 06-12-2015, 12:25 AM   #17
Originally Posted by FastFord13 View Post
Dynamite.
Sent from LG G3.
If the adhesive on the trunk emblem is anything like Ford put on my factory spoiler, I'll need a crowbar to get it off. Ha ha ha.
Have a great day!
Old 06-12-2015, 02:58 AM   #18
bucko's Avatar
It uses some of that super duty 3m automotive tape, and plenty of it. It took me awhile to remove mine. I used different sizes of body filler applicators to assist in getting behind it, and to gently pry it up and off all the way around. The dental floss kept getting stuck once it got to the guide pins, and there's more of that 3m tape on the inside of these pins, so that won't help when you get to that part.
Old 06-12-2015, 01:29 PM   #19
KryptonKnight's Avatar
Ford uses two alignment/centering tabs and 3M tape. Removal can be helped with a hair dryer. Wrap about 12" of 20 lb test fishing line around a dowel rod at each end. Warm up the emblem and using a sawing motion go back and forth between the body and the emblem. The tape kinda stuck to my line so I cleaned it off every now and then. Be patient, it will come off. Do not attempt to Pry it off under any circumstances.
CAI,6pt.Cage,FRPPSprings,Raptor,UDP,Hurst,SiliconeHoses,BossStrutBar,LoudMouths,Plenum,Cam,Brake,Battery,StrutCovers,FRPP PC.ValveCovers,Chin Spoiler,Hood Scoop&Pins,painted 10"Stripes & Pins,EleanorGrill,Chin Spoiler,"C" Scoop,1/4 Side Scoops,Rear Fascia,PJ Rear Louvers,Roush Skirts & Rear Wing,Triple Pod & Gauges,CF Dash,2010Projector lights,2014Taillights, Real Carbon Fiber full kit,19" 2014 GT rims.
KryptonKnight is offline   Reply With Quote
Old 06-12-2015, 02:55 PM   #20
The_Chech's Avatar
Yeah I pried mine off... Oops lol didn't do any damage really but I was starting to get frustrated a bit.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 06-12-2015, 03:51 PM   #21
MustangDawg's Avatar
Hay Kona, why are you taking it off. I'm trying to understand what you're going to do once its off. Thanks
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Old 06-12-2015, 04:31 PM   #22
Cooolbreeez's Avatar
That faux gas cap would look better if you could get the ford letters in blue.
---------- Post added at 03:31 PM ---------- Previous post was at 03:30 PM ----------
I know that's not helpful to your question, just thought I'd point that out. Lol
Cooolbreeez is offline   Reply With Quote
Old 06-12-2015, 04:39 PM   #23
Anybody have any pictures of the emblem completely removed?
Smalls is offline   Reply With Quote
Old 06-12-2015, 05:38 PM   #24
Looking to have the chrome color painted professionally.
Have a great day!
Old 06-12-2015, 06:01 PM   #25
Have a great day!
I see, fair enough, thanks. Love to see some pics when it's done.
Old 06-12-2015, 10:59 PM   #26
tym_v6's Avatar
I remember watching a 40 minute video on supercars that covered Mustang assembly at the Flat Rock plant. You can see a clip of a guy installing the emblem...literally a 2-second process with the tabs and tape, which is probably why they don't use screws.
Old 06-13-2015, 07:32 AM   #27
The_Chech's Avatar
Name:	ImageUploadedByMustang Evolution1434202309.073368.jpg
To remove fogs or not to remove fogs SystemCritical 2011-2014 Mustang GT 64 05-23-2013 07:10 PM
How to remove trunk carpet to access tail lights 96 Spiney 1996-2004 Mustang GT 1 03-16-2013 06:20 AM
How do i remove my back emblem ?? F4m0usfr34k 2005-2010 Mustang GT 15 09-04-2012 09:43 PM
trunk emblem delete? CZYFAST 2011-2014 Mustang GT 18 03-02-2011 04:20 PM
12:44 PM
