Installed Eibach Sportlines! - Mustang Evolution
Old 06-12-2015, 08:35 PM   #1
Mean14's Avatar
Name:	ImageUploadedByMustang Evolution1434162323.737093.jpg
ID:	184703Click image for larger version
Name:	ImageUploadedByMustang Evolution1434162349.195975.jpg
ID:	184704Click image for larger version
Name:	ImageUploadedByMustang Evolution1434162417.082799.jpg
ID:	184705Click image for larger version
Name:	ImageUploadedByMustang Evolution1434162435.672179.jpg
I am extremely pleased with the results! And it should drop a bit more once all settled in. I also installed a set of Ford Racing shocks/struts. Took me about 4 hours on jack stands and I took my time. About an hour was spent wrenching on and off the spring compressors cause they were some old ones my dad had laying around lol.
The ride quality is pretty firm over stock. Got rid of that floaty boat like feel. Handles like a dream too. I'm going to install LCAs and relocation brackets tomrw/Sunday.
Also, after installing my one piece driveshaft, i noticed pretty bad vibrations around 2-3k. I thought this was because of the dual mass flywheel.. But after I lowered it, it just about eliminated the vibrations and it's really smooth. So this tells me that the pinion angle was off from the factory. Thought that was kind of weird. I'm going to check my pinion angle tomorrow and if it's on spot, then I might not even install the adj UCA.
By the way.. Anyone looking for stock suspension?
My back hurts.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-12-2015, 09:16 PM   #2
FastFord13's Avatar
That's one sick looking ride!!! Great job.
Btw if you not going to use that adj uca how much u want for it lol?
Sent from LG G3.
Old 06-12-2015, 09:44 PM   #3
Mean14's Avatar
Sent from LG G3.
Thank you! I'm not sure if I'm going to sell it yet, but if I do, you will be the first dibs.
Old 06-12-2015, 09:47 PM   #4
oxford5pointoh's Avatar
The one pc drive shaft changes how the pinion angle would need to be adjusted. The angle is now from the trans and not the carrier bearing like it is with a 2 pc drive shaft. Also, you will most likely need the adjustable UCA and the bracket since you have the one pc drive shaft.
IG @Oxford5pointoh
Old 06-12-2015, 10:07 PM   #5
Mean14's Avatar
IG @Oxford5pointoh
Right. I understand. I just find it weird how after I lowered it, it smoothed out the driveline.
Old 06-12-2015, 10:52 PM   #6
Socal Stangman's Avatar
Looks great. Any scraping yet?
Also, I noticed you don't have any side emblems, there's no holes behind them?
Old 06-12-2015, 10:55 PM   #7
Mean14's Avatar
No scraping!... yet. There's actually a good amount of clearance underneath. I think the 20s help out
I never had any side emblems. I believe they only come on the 3.7 pony package.
Old 06-12-2015, 11:03 PM   #8
tym_v6's Avatar
3.7s don't have a carrier bearing mid-shaft like the 5.0s. They have a crappy sliding spline connection in the middle of the shaft.
Old 06-12-2015, 11:08 PM   #9
Oh interesting. I figured they were similar. My bad.
IG @Oxford5pointoh
Old 06-13-2015, 12:16 AM   #10
Harm_3.7's Avatar
IG @Oxford5pointoh
He is right about the pinion angle and you need an adjustable upper control arm. I had to go through this like a month ago lol
Harm_3.7 is offline   Reply With Quote
Old 06-13-2015, 04:02 AM   #11
audioAl's Avatar
Nice stance, great info concerning the pinion angle. Thanks for the views.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 06-13-2015, 07:10 AM   #12
Kevin.Cook
Guest
Posts: n/a
They 10s though but you keep them clean?
Old 06-13-2015, 12:11 PM   #13
Damn this has me thinking now, I have vibrations around 2-3k too and that is the only thing I hate about the car right now. I did add a 1 piece ds so now I'm wondering how bad my pinion angle is off Hmmm thanks!
Lan_Evo is offline   Reply With Quote
Old 06-14-2015, 04:02 AM   #14
Hampton CIT's Avatar
Looking good brother. Installing the Pro Kit myself this weekend. Rear laat night and front after I finish my coffee.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 06-14-2015, 06:51 AM   #15
tym_v6's Avatar
Are you lowered? If so, your angle may be off.
The 2-3k vibration may be from the dual-mass flywheel.
Which shaft do you have? The DSS shaft has a CV joint at the rear, which helps if the pinion angle is off.
Old 06-14-2015, 09:30 AM   #16
Mean14's Avatar
Did you read the last part of my post?
Old 06-14-2015, 01:19 PM   #17
tym_v6's Avatar
I did. You didn't say which shaft you have. AE, DSS, or somebody else?
Old 06-14-2015, 01:31 PM   #18
Mean14's Avatar
Dynotech
Old 06-14-2015, 08:30 PM   #19
Mean14's Avatar
So I checked my pinion angle today after installing my springs, shocks/struts, LCAs + relocation brackets, and it was right on the money. -2 degrees. I kept the aftermarket LCAs at stock length.
Front trans measurement was 2 degrees less than the rear pinion. I find this extremely odd that it was off from the factory. Makes me wonder how many others are like this and putting strain on their drivetrain. Just another reason to run a crappy 2 piece shaft. No wonder why they're exploding lol
Old 06-14-2015, 08:35 PM   #20
-2 is the setting when you are running poly bushings. -3 to -4 for rubber just FYI
IG @Oxford5pointoh
Old 06-14-2015, 08:59 PM   #21
Mean14's Avatar
IG @Oxford5pointoh
"If you have a fully aftermarket rear end, you could run about 1 to 1.5 degrees. If you are running a common street setup with one set of control arms only, then 2 degrees or so is more appropriate."
-Taken right for this link which explains pinion angle: http://www.cherod.com/mustang/HowTo/LCA%20_adj.htm
Old 06-14-2015, 09:01 PM   #22
Right. But my point is that ford most likely had it set -3 or -4 before he dropped it.
IG @Oxford5pointoh
Old 06-14-2015, 09:03 PM   #23
Mean14's Avatar
IG @Oxford5pointoh
Ah, makes sense.
Old 06-14-2015, 09:17 PM   #24
Mean14's Avatar
Ah, makes sense.
Wait, no. I take that back. Wouldn't that put it a 0 degree angle at factory height?
Old 06-14-2015, 10:07 PM   #25
No it's the opposite. Lowering it pushes the angle or the front of the diff down which takes away negative pinion angle. Pull it up and it adds to the pinion angle.
IG @Oxford5pointoh
Old 06-14-2015, 10:41 PM   #26
Mean14's Avatar
IG @Oxford5pointoh
How does it push the front down? Doesn't it lower the trans flange, therefor "pushing" the diff up
Old 06-14-2015, 10:57 PM   #27
Hmm. Well when I did mine the front was down. But maybe it's because I changed out so much at once that I had that result. You might be right. But I still don't think your pinion angle was off from the factory. It's because you started changing things like the drive shaft without checking the pinion angle after. I am sure if you swapped your factory drive shaft back in now that your lowered it wouldn't have the same result.
IG @Oxford5pointoh
Old 06-14-2015, 11:03 PM   #28
Mean14's Avatar
IG @Oxford5pointoh
I know I'm right. When I changed to my one piece, I was at a neutral setting 0 (factory), therefor causing vibrations under acceleration. After lowering, it put the trans flange lower than the pinion flange causing it to line up during acceleration, hence the -2 degree angle. If I swapped my factory shaft back in, it wouldn't make much of a difference because the two piece shafts are a lot more forgiving to misaligned pinion angles.
Also, you're running an auto which is different than standard trans when it comes to pinion angles.
Old 06-15-2015, 04:59 AM   #29
Well first, two pc drive shaft pinion angle is measured not by the trans and diff but by the post carrier bearing part of the drive shaft and the diff. The trans isn't a factor with a 2 pc drive shaft
Second I have a manual. Not sure how you decided I have an auto.
IG @Oxford5pointoh
Old 06-15-2015, 06:54 AM   #30
tym_v6's Avatar
The V6 shaft doesn't have a center carrier bearing.
Old 06-15-2015, 06:59 AM   #31
Yeah I know, I keep forgetting he has a v6
IG @Oxford5pointoh
Old 06-15-2015, 07:33 AM   #32
tym_v6's Avatar
But you raise a great point about differences in measuring the pinion angle between the stock V6 and V8 setups!
Old 06-15-2015, 10:22 AM   #33
Mean14's Avatar
IG @Oxford5pointoh
My bad I got you confused with someone from a different post.
Eibach Sportlines installed ab_mach1 1996-2004 Mustang GT 14 02-03-2015 12:52 PM
Eibach Sportlines with 20" wheels hispeedlodrag 2011-2014 Mustang GT 9 08-02-2014 07:46 AM
Eibach sportlines or ford b springs? 98vertgt 1996-2004 Mustang GT 7 04-26-2013 04:27 PM
Pic Request: 10+ Eibach Sportlines.. CYCLON37 Pictures and Videos 15 04-19-2012 06:19 AM
04:22 PM
