what is the widest tire on stock rims - Mustang Evolution
Old 06-14-2015, 12:58 PM   #1
So I was Just wondering when I replace the tires what is the widest tire I could use without interference? thanks
Oh yea It has 205-65 17 on it right now.
2013 V-6 AUTO COUPE
1965 MKII Roadster Factory Five
steve63 is offline   Reply With Quote
Old 06-14-2015, 01:00 PM   #2
Rapinator126's Avatar
*Isn't it a 225?
Rapinator126 is online now   Reply With Quote
Old 06-14-2015, 01:12 PM   #3
Jon3.7's Avatar
what are you driving? a civic?
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-14-2015, 01:33 PM   #4
Mean14's Avatar
Hahaha
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-14-2015, 03:18 PM   #5
Socal Stangman's Avatar
I would say no more than a 235 or possibly a 245...
Old 06-14-2015, 03:20 PM   #6
Kevin.Cook
Guest
Posts: n/a
For the price of new tires, you can find take off 18" GT ones for probably less. Unless you really like the look of 17s.
Old 06-14-2015, 04:34 PM   #7
2011 Kona Blue's Avatar
Sir, Are you talking about our factory Michelin tires? If so, they are 215/65/17
Have a great day!
Old 06-14-2015, 06:28 PM   #8
Have a great day!
I believe the automatics came with 215's but the manuals came with 225's stock on the same size rim. So I dont see a reason why you couldn't put 225's on a stock rim even if you had 215's from the factory.
StarzTA17 is offline   Reply With Quote
Old 06-14-2015, 06:36 PM   #9
Jon3.7's Avatar
mine came with 18's from factory, according to the tire sticker in the door well
Old 06-14-2015, 06:36 PM   #10
doyouevenforum
Guest
Posts: n/a
I'd do 325 all around and call it a day.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 06-14-2015, 07:15 PM   #11
VIG
VIG's Avatar
Region: Delaware
225 is the max I'd go.
You get diminishing returns the wider you get. Wider than a 225 on the 7" rim and not all of the tread will be contacting the ground, hence you'll actually lose some handling.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 06-15-2015, 06:36 AM   #12
Voltwings's Avatar
Look on most tire manufacturer's websites and they will have a recommended rim width for a given tire. Basically just check a tire height calculator to make sure you are staying close to the stock size, then check the comparability of that tire with your rim.
For example, Nitto lists the 225 / 55 / 17 Motivo (26.74" - so shorter than stock, but the closest size) as fitting on a 6" - 8" rim.
Old 06-15-2015, 08:15 AM   #13
For the stock 17x7, 235/55r17 is as wide as you can go.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 06-15-2015, 10:17 PM   #14
Brandonb2012's Avatar
Name:	ImageUploadedByMustang Evolution1434428207.822295.jpg
ID:	184985 will these fit our mustangs lol
Brandonb2012 is offline   Reply With Quote
Old 06-15-2015, 10:28 PM   #15
GrabberMeBlue's Avatar
When I get around to buying new tires, I was going to get 235/60/17. The overall diameter and revs per mile are almost exactly the same as the 215/65/17 my car came with so speedo should be fine without doing anything.
2012 Grabber Blue Mustang Convertible V6 Premium
1979 Solar Gold Trans Am
1995 Bright Red Trans Am Convertible
2012 Grabber Blue V6 Convertible
1995 Red Trans Am Convertible
1979 Gold Trans Am
GrabberMeBlue is offline   Reply With Quote
Old 06-16-2015, 06:02 AM   #16
235/60r17 is a wonky size. There aren't any performance oriented tires in a 235/60.
Old 06-16-2015, 07:39 AM   #17
Voltwings's Avatar
^^ You can also get by putting a wider tire on a more narrow rim when you have that much sidewall, but the car is going to drive funny - hence, why no performance tire is in that size lol your contact patch in relation to your rim is basically an inverted trapezoid.
Old 06-16-2015, 08:07 AM   #18
I have 185/55/17's on my car and they are a performance tire
Old 06-16-2015, 09:27 AM   #19
Voltwings's Avatar
Im torn between acknowledging you as a smart ***, or ignoring you to deny you the satisfaction lol.
Old 06-16-2015, 09:36 AM   #20
185/55/17. M&H race masters lol
Old 06-16-2015, 09:47 AM   #21
Voltwings's Avatar
You over paid, should have just gotten some miata donuts. My spare is a like 185 on a 15 x 4" rim or or 14 x 4 or something.
Old 06-16-2015, 09:54 AM   #22
This is the tire I was tossing around. I don't drive the car in the winter, but I will use it in colder weather. I have ultra high performance summer tires on my '95 T/A and noticed one spring morning when it was in the 30s that you can really feel how hard those tires get in the colder weather. Since I use the Mustang in colder weather until the snow flies, I want to stay with all-season. I also wanted to get as much width as I could without throwing the speedo off, and these show as being for a 7 inch rim, which I thought our stock wheels were. Not saying I am getting these for sure, I probably won't be looking until next year. If these really wouldn't fit, it would be good to know ahead of time.
http://www.tirerack.com/tires/tires....RT43&tab=Specs
1979 Gold Trans Am
Old 06-16-2015, 10:02 AM   #23
True, but won't hold up to 140+ mph
Old 06-16-2015, 10:05 AM   #24
Voltwings's Avatar
This is the tire I was tossing around. I don't drive the car in the winter, but I will use it in colder weather. I have ultra high performance summer tires on my '95 T/A and noticed one spring morning when it was in the 30s that you can really feel how hard those tires get in the colder weather. Since I use the Mustang in colder weather until the snow flies, I want to stay with all-season. I also wanted to get as much width as I could without throwing the speedo off, and these show as being for a 7 inch rim, which I thought out stock wheels were. Not saying I am getting these for sure, I probably won't be looking until next year. If these really wouldn't fit, it would be good to know ahead of time.
I think you could do a little better, depending on what you're after*, than that tire. I understand all treadwear "ratings" are not the same between companies, but typically its at least a general ballpark, and a 700 treadwear rating is ... useless honestly. I would maybe look for something more towards the 300-400 range. Granted, i'm in Houston, so our "winter" is 40* at best lol ...
pshhhhhhhhh
Old 06-16-2015, 10:15 AM   #25
pshhhhhhhhh
I don't tear around or hot rod around in the car. I use it more for enjoyable cruising and daily driving spring through fall, and don't beat on it. Still have the 2.73, so off the line traction has never been an issue for me. Would that make a difference in your decision?
1979 Gold Trans Am
Old 06-16-2015, 12:38 PM   #26
Voltwings's Avatar
Yes, in that case get a comfortable, long lasting tire.
Old 06-16-2015, 06:21 PM   #27
jande063's Avatar
pshhhhhhhhh
Treadwear is pretty much BS when you get to the newly released TW 200 tires aimed specifically at the SCCA Street Tire classes. Especially the Bridgestone Potenza RE-71R, that is "200 treadwear" with the biggest wink in the world. That tire wears faster than my 40 treadwear Hoosiers (and is just as sticky).
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 06-18-2015, 10:13 PM   #28
Maybe a 225/60/17 would be better? Overall diameter is 27.6" vs 28". Speedo off by .8 at 60mph. Would also lower overall gear ratio by a hair, not really significant. Would that fit better on a 17x7 rim? Would the tires look noticeably wider than the stock 215/65/17? Just trying to get something that looks a little meatier but won't affect drivability.
1979 Gold Trans Am
Old 06-19-2015, 12:40 AM   #29
Midnight2012's Avatar
I have the opposite problem. Bought 8" rims from American a Muscle. Have my stock 215/65/r17 on them now but slightly too small for safety sake. And I can feel it handles slightly different. When I get new tires I'm thinking of going 235/60/r17. Which is 28.1 vs 28 in height. Speedo will have no significant difference but not a lot to choose from. Hoping they don't rub or effect my turning radius. Any suggestions on a tire better or equal to the stock Michelins?
I could go the manuals tires of 225/60/r17 but in 100,000 on the speedo I'd have actually only gone 97k.
Midnight2012 is offline   Reply With Quote
Old 06-19-2015, 05:10 AM   #30
Go with the 225/60r17 if you want to stay with a taller tire. As mentioned above there are literally zero tires that you will want to run on a Mustang in the 235/60r17 size.
Old 06-19-2015, 09:29 PM   #31
Anyone upsize the tires on their stock 17" wheels and if so, what size did you go with? Any pictures?
I actually like the painted stock wheels so I want to stay with them. I also don't want to spend the money buying new wheels. I also don't want to tune my car to adjust speedo. Getting larger diameter wheels is not that important to me. Just want something that looks a little meatier but doesn't negatively affect drivability.
Some of the answers earlier in the thread were conflicting, so I was just wondering who has actually done it and what did they go with, not that I don't value the other opinions.
1979 Gold Trans Am
Old 06-19-2015, 11:23 PM   #32
This is really helpful: http://www.americastire.com/dtcs/infoTireMath.do
Old 06-19-2015, 11:33 PM   #33
I really appreciate your input. I've been considering the 225/60/r17 that come on the manual trans cars. It would lower the gear ratio a tad (have 3:31 now) and I'd have a better speed rated tire and
I suppose in the big scream of things it wouldn't matter that at 150,000 miles I'd actually have 2000 less than that.
But as compared to the stock Michelin Energy Saver 215's what would be wrong with these?
Looking at the BF a Goodrich sight they recommend these for the Mustand at 215/65/17 and 225/60/17 as an upgraded alternative to the stock BF goodrich that come on the manual trans car. So why not 235/60/17? Overall closer in height to the 215's and would only raise the gear ratio slightly. Or would they just be too wide?
Name:	ImageUploadedByMustang Evolution1434778366.903196.jpg
Old 06-20-2015, 12:55 AM   #34
VIG
VIG's Avatar
Region: Delaware
If you're going just for aesthetics, you're not really going to be able to see the difference between the 215 and 225, and 235 is going to be too wide.
Old 06-20-2015, 01:58 AM   #35
Can you offer why 235 is too wide? I have 8" Wide rims. Must I go lower profile to go wider and reprogram for the speedo? The 215's aren't recommended for 8" rims although I'm doing it. 225's they say fit the 8"
Widest tire on stock rim? ChrisD522 Mustang Wheels & Tires 7 09-25-2013 10:50 PM
Whats the widest tire you can fit on a stock rim ? SloMoGT 1996-2004 Mustang GT 15 09-10-2012 04:30 PM
widest tire on stock rim? stangracer Mustang Wheels & Tires 3 08-22-2004 02:09 PM
Widest Tire 88stang Mustang Wheels & Tires 16 07-08-2004 09:01 AM
widest tire on a 8 inch rim. SVT_Rob Mustang Wheels & Tires 3 06-03-2004 08:17 PM
03:27 PM
