Throttle issue - Mustang Evolution
Old 06-15-2015, 09:38 AM   #1
Throttle issue
So last night I was driving home when suddenly my car stalled. The car stayed on but no response when I hit the gas. I checked and cleaned cai filter but still same results. What can the problem be? Has this happened to anyone else? Any info is greatly appreciated. 2011 v6 cai
Sent from my SPH-L710 using Mustang Evolution mobile app
jnieto7 is offline   Reply With Quote
Old 06-15-2015, 09:39 AM   #2
I forgot to mention that the car stays on but no response when I press on the gas.
Old 06-15-2015, 10:05 AM   #3
Voltwings's Avatar
id check the throttle body? Is it still plugged in?
Old 06-15-2015, 12:03 PM   #4
Yea I unplugged it then plugged it back in but no response
Old 06-15-2015, 01:07 PM   #5
Voltwings's Avatar
unhook battery, wait 10 minutes, try again. Likely just needs to reset something.
Old 06-15-2015, 01:21 PM   #6
BlackKnight92's Avatar
Uh Oh, unfortunately, it sounds like the same issue i was having a few weeks back before the transmission died on me. Hopefully its nothing though.
2012 Mustang V6
BlackKnight92 is offline   Reply With Quote
Old 06-15-2015, 01:36 PM   #7
iguanaman3's Avatar
Do you have any warning lights on your dash? It sounds like you throttle body died.
iguanaman3 is offline   Reply With Quote
Old 06-15-2015, 03:28 PM   #8
I'll try disconnecting the battery . The only light that came up was a wrench.
Old 06-15-2015, 03:54 PM   #9
I got the wrench as well before my transmission blew. Most people with this issue just need a new Throttle body. If youre still under warranty id just take it to the dealership right away
2012 Mustang V6
Old 06-15-2015, 08:50 PM   #10
Mean14's Avatar
This is why investing in a code reader is worth the $50
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-15-2015, 08:54 PM   #11
Would my tuner work to diagnose?
Old 06-15-2015, 08:56 PM   #12
Mean14's Avatar
Yes, a tuner is able to read codes
Old 06-15-2015, 09:02 PM   #13
Hampton CIT's Avatar
Had a similar problem once (thank God.) Interstate driving, I got into it and while accelerating, everything went dead. Still had electrical power just a motor that wouldn't go. Coasted to a stop on the side fearing something serious (I don't mean repairs - I mean the wife as this story in spouse brain means you broke it!) Turned key off, opened door, key in and car cranked right up as if nothing happened. Hasn't happened again since but it was clearly a system issue just needing a refresh. At what point did our cars and cell phones need an occasional reboot??
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 06-15-2015, 09:30 PM   #14
Gunner's Avatar
When they added processors and became a big computer on wheels.
Gunner is offline   Reply With Quote
Old 06-23-2015, 07:46 PM   #15
So I just replaced the throttle pedal position sensor. I connected the battery back and started car .10 minutes later the little wrench appeared again and car went into limp home mode. What can it be? My tuner shows no dtc's. Any ideas are greatly appreciated
Old 06-24-2015, 09:34 AM   #16
Kevin.Cook
Guest
Posts: n/a
If you have a tuner, it should read any codes that are appearing. Have you tried doing this?
Old 06-24-2015, 10:01 AM   #17
Yea after I replaced throttle pedal position sensor. I scanned it again, this time no codes.I just cleaned the maf and throttle body. Do I need to recalibrate anything?
Old 06-24-2015, 10:04 AM   #18
Kevin.Cook
Guest
Posts: n/a
Nope. Just turn it on again. Once the wrench light comes on, if it comes on, scan for codes again. You should also be able to clear codes with it.
Also, if you are tuned, try going back to stock and retest. Assuming you dont have long tubes or anything major.
Old 06-24-2015, 10:47 AM   #19
I've been running car now for about 25 minutes. ... No wrench do far. If it appears again I will try setting it back to stock and retest. Thanks for your help.
Old 06-24-2015, 10:52 AM   #20
Kevin.Cook
Guest
Posts: n/a
If it does come down to the tune, might want to check with your vendor that the transmission tuning and everything is on point.
Because on Autos, if that solenoid doesn't fill up due to bad tuning or even damage/failure, then your car isn't going anywhere when you hit the gas.
Old 06-24-2015, 11:13 AM   #21
I'm gonna take it for a test ride on my lunch break. Hopefully no more problems.
Old 06-25-2015, 09:47 AM   #22
Let us know!
2012 Mustang V6
Old 06-25-2015, 12:02 PM   #23
So far so good! Cleaned maf sensor, removed and cleaned throttle body. I'm going yuk be test driving today and tomorrow so by Monday my wife can take her own car and I can have my car back! ( 2015 mustang gt)
Old 06-25-2015, 02:51 PM   #24
So after no issues yesterday , wrench turns back on today! Back in limp mode. I'm going to plug in tuner and see if I get any codes.
Ford Racing super cobra jet throttle body issue dude0715 2011-2014 Mustang GT 7 01-11-2015 12:21 PM
New Throttle Body Issue Shelton 1979-1995 Mustang GT 37 12-09-2014 05:44 PM
Possible Throttle Issue Yankytyke 2011-2014 V6 Mustang 9 06-01-2013 02:19 PM
Throttle Issue gmcmanus 2005-2010 Mustang GT 30 12-07-2012 01:06 AM
Throttle issue today drivinglesson 2011-2014 Mustang GT 23 02-06-2012 08:44 PM
02:31 PM
