Time to go to a shop - Mustang Evolution
Old 06-15-2015, 11:05 PM   #1
Driving home from work today on I-75 I heard what sounded like a belt squelling for maybe 2 seconds. Shortly after I smell something burning. So I pull off and I have a clunking noise from the rear end with a slight howl. It has been just over 2 months since switching to 3.73. So bad seal? Leading to no fluids to lubricate? Night time and no garage to check. Any ideas would be greatly appreciated.
smallengineguy is offline   Reply With Quote
Old 06-16-2015, 12:25 AM   #2
Can you see any evidence of gear oil having leaked out?
I'd definitely take it back to the shop that did the gear installation.
Old 06-16-2015, 12:59 AM   #3
I did not as it had been raining. I'll be checking the oil level in the morning along with excessive play from pinion bearing
Sent from my SM-G900P using Mustang Evolution mobile app
Old 06-16-2015, 06:36 AM   #4
Kevin.Cook
Guest
Posts: n/a
Could be a bearing failed or fluid leak. Let us know what you find out.
Old 06-16-2015, 07:25 AM   #5
20prima10's Avatar
Sounds like a lot of you guys need to find better gear shops. This reared has been out for 20+ years and no real gear installer should have any issues with them. I've never babied gears after installing them. I usually put 40 miles on them as soon as I'm done with a gear swap. Then I dump and flush fluid and after that there good to go. I've never had any issues as long as quality parts are used there should never be an issue. Just my .02. Don't know if you guys have used cheap parts or just terrible installs.
20prima10 is offline   Reply With Quote
Old 06-16-2015, 07:46 AM   #6
Kevin.Cook
Guest
Posts: n/a
I have a list of most of the shops in my area in another thread. I called all of them. Most charge 700-1200 for just labor. And most admitted they rarely do them. It depends on your area. If there are alot of modded cars in your area, then chances are, the shops are more experienced (assuming they did a majority of the mods).
However, not really alot of this going on in Cedar Park, TX. So most shops just do normal maintenance stuff. And I cannot drive my car 1-2 cities away, drop it off, get it worked on, then hope in the following weeks I can pick it up.
I don't think people realize that everyone's resources and circumstances are a bit different.
Old 06-16-2015, 07:59 AM   #7
20prima10's Avatar
No I realize it lol. But it's worth a drive if it avoids all of the issues you have had? Am I wrong to assume that if you cud do yours over again you would take it to someone who actually knows gears.
Old 06-16-2015, 08:03 AM   #8
Kevin.Cook
Guest
Posts: n/a
That is true. But the next biggest city that is nearby is San Antonio. Takes about an hour to two to get out of Austin due to traffic, then another hour to get to SA, and the time within SA to get to the shop. So couple that with my 10 hour work days, it doesn't fit in to my schedule to go some place far. I rarely get time off since I am the only IT person at my work location.
Almost no shops will do a full gear install on a Saturday. So that really limits my options. So I have to pay to play with what I have available.
Don't worry. It will get done right one of these days....LOL
This time I made sure the work was warrantied....
Old 06-16-2015, 08:11 AM   #9
20prima10's Avatar
Lol well good luck to u. I've been doing my gear installs for the last 8 years and never had an issue. There easy if you have mechanical knowledge and proper tools. Good luck to you
Old 06-16-2015, 09:17 AM   #10
Well I had them installed by livernois. Here's what I came across today leaking pinion seal
Old 06-16-2015, 10:35 AM   #11
Labrat's Avatar
Livernois is a pretty reputable shop. Depending on how long since you've had the work done I would take it back and at least call'em.
Labrat is offline   Reply With Quote
Old 06-16-2015, 10:48 AM   #12
olerodder's Avatar
Region: Oregon
Not sure what year Mustang you have and just to let you know that I lost my pinion seal at 7600 miles. My Ford dealer replaced it and said this is pretty usual. The mechanic told me that Ford's OE seal is mostly plastic and that the "New Revised Piece" is metal. So far so good.
Old 06-16-2015, 12:10 PM   #13
Thanks. I doubt they will replace under warranty. It will be going in on thursday. In the mean time I got my other baby out.
Old 06-16-2015, 12:11 PM   #14
Kevin.Cook
Guest
Posts: n/a
Dang I need to save for one of those
Old 06-16-2015, 09:38 PM   #15
5pointYoBro's Avatar
Forreal. I've been trying to find a fox body for a while to replace my lame grand prix.
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 06-17-2015, 03:44 AM   #16
20prima10's Avatar
What shop in livernois are you referring to? I don't know the area? I could recommend an excellent shop around flint. My friends dad has owned it since we were little and he's always done great work.
Old 06-17-2015, 05:36 AM   #17
Livernois is the shop...
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 06-17-2015, 05:50 AM   #18
20prima10's Avatar
Oh ok. Never heard of them
Old 06-17-2015, 08:18 AM   #19
Labrat's Avatar
Here is a link to them. As I live in Flint also who are you talking about?
Livernois Motorsports: Specializing in Late Model Domestic Performance Parts
Old 06-17-2015, 08:20 AM   #20
Labrat's Avatar
Here is a link.
Where and who in Flint are you talking about?
Old 06-17-2015, 09:04 AM   #21
20prima10's Avatar
A small place out in Durand. Can't remember the name of his shop or if he's still in business. It's been a few years since I've been that way. Never seen your car around flint before.
Old 06-17-2015, 09:30 AM   #22
Labrat's Avatar
I'm out in Flint Township, but, we go to "Back To The Bricks" every year.
Old 06-17-2015, 09:33 AM   #23
Labrat's Avatar
She is not a daily driver as I store her during the winter and as I'm retired and on disability I don't get to drive her as much as I would like.
Old 06-17-2015, 09:41 AM   #24
20prima10's Avatar
Oh ok. Sorry to hear that.
Old 06-17-2015, 10:08 AM   #25
Back to bricks. Come on down to woodward or some mustang shows the same weekend
Old 06-17-2015, 10:22 AM   #26
20prima10's Avatar
No offense but I hate Woodward. To me there's nothing worse than sitting in traffic going no where lol.
Old 06-17-2015, 10:36 AM   #27
Park and become a spectator. Traffick jam cruises are a good sign of a food turn out haha. There's cars out every weekend. Gets busier closer to cruise date
Old 06-17-2015, 11:24 AM   #28
Labrat's Avatar
We go there every year too......I remember racing on Woodward back in the day.
Old 06-17-2015, 11:37 AM   #29
20prima10's Avatar
Ya I've been there in the past just not my cup of tea. I really don't even do back to the bricks much. Maybe 20 min or so before I take off and cruise.
Old 06-19-2015, 01:17 PM   #30
Well heres the update. Got my car back. The pinion bearing and seal got destroyed wear pattern on the ring was toasted. The shop I went to was fantastic. Half the price of the original install. Even the guys at the place were shocked at the damge and couldn't figure out what the installer at Livernois did.
---------- Post added at 07:17 PM ---------- Previous post was at 07:16 PM ----------
Lesson learned big name shops are not always the best
Old 06-19-2015, 03:20 PM   #31
20prima10's Avatar
I'm not covering there *** because I've never even went to that shop but.
It is possible that when the carrier bearing went it caused a lot of slop in the system thus trashing everything inside. Could have just been a fluke bad bearing or bad instal. Who knows man.
Glad it's fixed though
Old 06-19-2015, 07:24 PM   #32
I know. They are a good shop and have accomplished a lot.
---------- Post added at 01:24 AM ---------- Previous post was at 01:23 AM ----------
Just have to b**ch about some when things happen
Old 06-19-2015, 08:56 PM   #33
tym_v6's Avatar
^ Hey, a little bit of venting is fine by me!
Spring time is shop time! dmcgoy3 1996-2004 Mustang GT 4 04-10-2015 11:35 AM
Time for a tune, advice time. drivinglesson 2011-2014 Mustang GT 30 07-26-2011 06:54 PM
Looking for good body shop or restoration shop Mercedez L. Regional Mustang Discussion 16 11-25-2008 04:01 PM
Another shop to watch out for Ohio this time PureVenom The Bar 2 07-13-2005 05:21 PM
UN is a total waste !!!!! Time to close shop Danger Dude The Bar 7 10-15-2004 02:30 PM
10:21 PM
