Gt grill fog light conversion - Mustang Evolution
Old 06-17-2015, 11:12 PM   #1
I just bought this
Mustang GT-Style Fog Light Conversion Kit - Fits V6 and GT/CS (2013-2014)
And I was wondering how I can make this work with my stock lower valance fogs?
A rep told me I needed another wire to connect the one that comes with it to my stock lights
Thanks
Sent from my HTC One M9 using Mustang Evolution mobile app
mark09 is offline   Reply With Quote
Old 06-17-2015, 11:32 PM   #2
Commercial Member
au01st's Avatar
You're going to need to tap into the lower fogs for switch and power. Keep in mind in most places it's illegal to run with 6 lights on the front.
Sent from my #racecar
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 06-17-2015, 11:35 PM   #3
Probably gonna smoke out 2 of them, would you know how it is in Cali?
Old 06-18-2015, 09:54 PM   #4
CA is probably the most restrictive of any state when it comes to mods...
Just found this online...Not more than 4 lights can be on at a time...
http://www.leginfo.ca.gov/cgi-bin/di...le=24400-24411
Steve
'14 Deep Impact Blue V-6 Coupe
MCA Package
V-6 Performance Package
Premium Package
SRE TUS is offline   Reply With Quote
Old 06-19-2015, 08:58 AM   #5
Whitelightning's Avatar
I just bought this
Thanks
You'll need the h11 to h10 connector or extension if the same connector.
Just extends the harness to the bottom fogs lights
Old 06-23-2015, 05:03 PM   #6
I am running the same configuration you are trying to. Mine is a base model so I had to piece together full set. I bought Grille, Grille fogs, Lower valance Fogs, Starkey Lower Valance Wiring Kit and Extension wires. Along with that I had purchased 2 pairs of h11 connectors. I spliced one end and connected it to the other to make a pair of splitter.
First I installed Lower valance lights made sure everything was working fine. Ran this setup for some days to make sure it is working fine. Then Went ahead with the Grille and Grille Fogs installation. Used splitter that I put together to connect one end to lower and other to Grille Fogs.
I had also checked with Steve at Starkey. He said this setup was safe and will not cause any other problems. Legality wise yes. This could be an issue at many places. Hope this helps.
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX |P.S MORE TO COMEEEEE!!!!
Firstang001 is offline   Reply With Quote
Old 06-23-2015, 05:13 PM   #7
Same setup but I have factory lower valance fogs. So I bought the Starkey set so all I need are extensions to reach the lower fogs? Do u know where I can find them? And I don't need the h11 connectors if my lower fogs are oem right?
Old 06-24-2015, 08:28 AM   #8
Are u trying to get completely rid of you lower valance fogs?
Old 06-24-2015, 11:39 AM   #9
no trying to use them with the grill lights
Old 06-24-2015, 12:49 PM   #10
Then you don't need extensions.They already come with the Starkey kit you have. All you have to buy are 2 pairs (4 pieces) of H11 male/female connectors.
Splitter construction:
Now if I am not wrong. The power connector that goes from OEM harness to lower valance is female. If this is right then cut male side of one H11 connector you bought and tap it into wires of H11 another connector using wire taps. With this you have pair splitters with each having one male end and 2 female ends.
Installation:
Once you are done installing the grille and fogs. Connect this splitter to harness that goes into one end of lower Fog. In this way now you have two females ends with power. one goes to lower and another goes to the harness coming from Grille Fogs. Repeat same on the other side and you will be good.
Also Attached a wring diagram i made. I am not a professional in creating diagrams. But if you have any questions you can always reach out.
Name:	Foglight Wiring.png
Old 06-24-2015, 12:53 PM   #11
Installation:
thanks slot appreciate it
Old 06-24-2015, 01:26 PM   #12
Sure!! Good Luck!!
2014 v6 grill to GT grill w/ foglight conversion mark09 2011-2014 V6 Mustang 23 06-10-2015 08:32 PM
GT Fog Light Conversion 3Point7 HTx 2011-2014 V6 Mustang 0 02-21-2015 12:33 AM
Can i have both grill fog lights and lower fog lights working at the same time? servs 2011-2014 V6 Mustang 3 03-31-2014 05:35 AM
Fog light conversion Cali_JC 2005-2010 V6 Mustang 0 02-11-2013 10:51 PM
GT wing & GT grill with fog light holes for sale ReggStang 2005-2010 Mustang GT 1 08-20-2012 08:00 PM
01:55 PM
