Splash sheild - Mustang Evolution
Old 06-19-2015, 05:34 AM   #1
luisagordo31's Avatar
Splash sheild
So my splash sheild kept coming on and off due to me parking foward. I thought I had fixed the problem by putting it back in place, but driving off the highway this morning the splash sheild ripped off the car completely. It was dangling by one small piece. My question is does anyone know if it's highly important to get a new one??? Or could I leave it that way?
Sent from my SM-N910V using Mustang Evolution mobile app
luisagordo31 is offline   Reply With Quote
Old 06-19-2015, 06:10 AM   #2
Voltwings's Avatar
The shield is going to help with aerodynamics (mainly in regards to MPG), and removing it could have a very marginal affect on cooling (in regards to radiator efficiency), but mainly your engine bay is just going to get really dirty without one.
Old 06-19-2015, 06:14 AM   #3
I have the cervini grill lower and upper so there is air flow going toward the engine bay, but what do you mean by dry?
Old 06-19-2015, 07:00 AM   #4
Voltwings's Avatar
Sorry, not sure i understand your question?
Old 06-19-2015, 08:21 AM   #5
Does it really matter if I need the splash sheild? Or should I go order a new one ?
Old 06-19-2015, 08:24 AM   #6
Voltwings's Avatar
Well... the Splash shield is going to help with aerodynamics, which will improve MPG. The splash shield also prevents higher pressure from forming in the engine bay, which improves radiator efficiency and can help the car run cooler, and will also keep the engine bay from getting extremely dirty.
Old 06-19-2015, 08:35 AM   #7
20prima10's Avatar
Should you order one. Yes
Do you have to no.
Would I or voltwings order a new one. Hell yes.
20prima10 is offline   Reply With Quote
Old 06-19-2015, 10:33 AM   #8
Voltwings's Avatar
Do you have to no.
Old 06-19-2015, 10:42 AM   #9
oxford5pointoh's Avatar
Believe it or not it also serves as added rigidity to the bottom section of the bumper cover. I'd replace it
IG @Oxford5pointoh
Old 06-19-2015, 12:33 PM   #10
tym_v6's Avatar
It might also help deflect rocks and other road debris from bouncing up and hitting the radiator and A/C condenser.
Old 06-19-2015, 12:48 PM   #11
VIG
VIG's Avatar
Region: Delaware
+1 to all of these things.
I'd go buy a new one.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 06-19-2015, 12:57 PM   #12
tym_v6's Avatar
Yikes, a bit expensive new (using my 2013 MY car as a reference for lookup): SPLASH SHIELD for 2013 Ford Mustang|BR3Z-6C038-A
Old 06-19-2015, 01:09 PM   #13
VIG
VIG's Avatar
Region: Delaware
Jeezzzzzzzz
It's amazing what car companies can charge for a piece of plastic.
Old 06-19-2015, 01:15 PM   #14
tym_v6's Avatar
Might be worth trolling eBay and see if someone is selling a used one from a wreck or car they're parting out. Who cares if it has a few scuffs since nobody's going to see it?
Yeah, car companies are masters at charging huge sums for little bits of plastic.
Old 06-19-2015, 02:10 PM   #15
VIG
VIG's Avatar
Region: Delaware
Yeah, I'd definitely either go to eBay or check out any local junk yard.
Old 06-19-2015, 09:23 PM   #16
NewMtang's Avatar
Two things. 1) Replace the Splash Shield. 2) Take a course in how to park you car.
Old 06-19-2015, 09:49 PM   #17
VIG
VIG's Avatar
Region: Delaware
Hahaha out of all the advice in this thread, I'd heed this advice the most.
Old 06-20-2015, 01:28 PM   #18
Yea I was in a rush and the median that was there was actually higher then regulation lol I park backwards 99.9% of the time. What sucks is that I had the cervini gt500 chin spoiler which is what caught on to the median. Now I spoke with a Ford Mustang specialist that said the splash sheild is useless anyways. My car is regular height now if it was lowered then it would be best to switch it out.
Old 06-20-2015, 01:35 PM   #19
20prima10's Avatar
Still confused why you would back over a median? What is a median doing in a parking spot any ways??
Old 06-20-2015, 01:36 PM   #20
20prima10's Avatar
And since when is there a controlled median height? Did you measure said median to make sure it's over regulations
Old 06-20-2015, 01:39 PM   #21
Lol that's what the regulation calls it a "parking median" there's an actual measurement that it's suppose to be at. If it's to high it could mess up anyone's front bumper or even rear bumper there's lawsuits on it to.
Old 06-20-2015, 01:46 PM   #22
20prima10's Avatar
You'll have to post a picture. By definition a median is the grass with curbs or something similar like what's on a divided freeway. Little confused here
Old 06-20-2015, 01:47 PM   #23
20prima10's Avatar
I guess my main question is. If there is a law suit against it already that you know of. Than why park there and risk it?
Old 06-20-2015, 01:51 PM   #24
That's exactly what I thought and said but no I'll see if I get the state statue on it. There's not a lawsuit on this parking spot exactly lol I've heard of some on it. People create lawsuits for stupid reasons. I'll send a picture later
Old 06-20-2015, 01:52 PM   #25
20prima10's Avatar
Hmmmm.
Old 06-21-2015, 02:45 PM   #26
Voltwings's Avatar
Jeezzzzzzzz
Thats actually not terrible is the sad part. The replacement shift knob for my speed3 was like $360 when i last checked ...
Old 06-21-2015, 06:02 PM   #27
VIG
VIG's Avatar
Region: Delaware
Wow, that's ridiculous. Is it made unicorn hooves???
Old 06-21-2015, 06:33 PM   #28
tym_v6's Avatar
Whale baculum.
JLT / Truecarbon splash guards mmike87 2011-2014 Mustang GT 17 01-18-2013 12:24 PM
Splash screen RVAStang05 Mustang Audio & Video 13 01-04-2012 04:45 AM
Parts # for the splash shield under the front bumper kingpeng0318 2005-2010 V6 Mustang 0 09-17-2011 02:29 PM
heat sheild noise 4.0 2005-2010 V6 Mustang 0 04-27-2011 04:08 PM
Splash guards for an 04 gt CrimsonGT 1996-2004 Mustang GT 11 01-20-2011 09:39 PM
11:06 PM
