Installed 5.0 Sound Tube - Mustang Evolution
Old 06-24-2015, 08:47 AM   #1
Kevin.Cook
Guest
Posts: n/a
So yesterday I got my car back....FINALLY. I installed my JLT Oil Separator and GT Sound Tube.
Now for the sound tube, I plugged it in to the firewall where it normally goes on the 5.0. I then used 3M Tape and Epoxy to secure it to one of the openings on the Airaid (the opening where the driver's side crank case connects to). Then I put a breather filter on the crankcase where the hose was. Everything is connected up and no leaks or anything. No weird idle or sounds, so the install was a success.
However!...This thing makes my engine bay look atrocious. The 3.7 engine cover is not sitting right. The sound tube is too bulky and doesn't flex enough to his under the engine cover, so it is stuck pushing up against it.
The breather filter is also another culprit with not letting the engine cover sit right. Now I can probably cut a small amount from under the engine cover to allow it to sit right.
Last thing, I played with the baffles in and both of them out. But I really couldn't hear any difference with the sound tube. On or off.
Any thoughts?
Luckily, nothing was cut right now or anything. So if I wanted to take it off, I could and keep the look I had before installing it.
ID:	185649   Click image for larger version
ID:	185651   Click image for larger version
Old 06-24-2015, 08:55 AM   #2
bucko's Avatar
You're CAI is in affect, killing the sound tube. While most aftermarket CAI's for the 5.0 made a hookup for the factory sound tube (larger nipple), the 3.7 CAI's do not, since it was not an option for it.
When I "played" with a sound tube on my 3.7, I had the same results as you with an installed CAI and a fabricated connection to the sound tube; no real sound in the car. I had an automatic, so the extra nipple on the CAI had to be connected to the transmissions breather.
I reinstalled the factory intake, and fabbed a 90 degree PVC fitting by the "sound deadner" (large square box on the factory intake tube). Huge sound difference was now heard in the car.
However, I removed it, as it was simply butt ugly under the hood, and the "cuteness" of the sound in the cabin quickly lost interest with me. My GT500 exhaust was much better to listen to.
Old 06-24-2015, 08:55 AM   #3
oxford5pointoh's Avatar
Is your oil separator just sitting on or right above the headers? That's part of why I went with the moroso one because it has a bracket. I know it's for a 5.0 but it's pretty universal and I think it would work in your situation.
That sound tube looks weird because of where you have it on the tube. They are not good looking in any engine bay really
Name:	ImageUploadedByMustang Evolution1435154119.753582.jpg
IG @Oxford5pointoh
Old 06-24-2015, 08:59 AM   #4
Kevin.Cook
Guest
Posts: n/a
I really looks like it is sitting on the header but it is in fact just dangling there. lol.
Yea I might take it off and throw it up on CL or something. Weird how the CAI would be robbing it of sound even though it's connected in a correct way. Maybe the valve on the inside of the CAI is too small to make a huge difference?
Old 06-24-2015, 09:01 AM   #5
Kevin.Cook
Guest
Posts: n/a
Also, I really tried to get the sound tube under the engine cover but if I made it flex any further then what is already is, it would not have met up with the opening correctly. So its a terrible compromise. lol
Old 06-24-2015, 09:03 AM   #6
Sorry it didn't work out like you wanted it to man
IG @Oxford5pointoh
Old 06-24-2015, 09:04 AM   #7
bucko's Avatar
Gotta remember, it was designed around the 5.0's engine. While our 3.7's have the fender side connections for the valve and tube routing, the tube part that connects to the intake tube is located different on the 5.0's then our 3.7's. This slight difference is what makes the tube hard to connect "cleanly".
Old 06-24-2015, 09:05 AM   #8
Kevin.Cook
Guest
Posts: n/a
It was a cheap thing to try though. Only spent like $40 for everything. Now had it been like $300+, then I would be a little upset. lol.
Old 06-24-2015, 09:07 AM   #9
bucko's Avatar
I got mine 3 years ago for 20 bucks, then sold it last year for the same amount!
No gain, no loss.
Old 06-24-2015, 09:09 AM   #10
Kevin.Cook
Guest
Posts: n/a
No gain, no loss.
I hear ya. Just a lesson learned. Wouldn't be so bad for the people without an engine cover and stock intake I guess.
Old 06-24-2015, 09:53 AM   #11
Strange Mud's Avatar
No gain, no loss.
same here but the # was $25....I never got around to installing mine. I ended up with an Airaid CAI used for a great price. Yeah I know = 0HP but the sound was worth the price.
Old 06-24-2015, 11:23 AM   #12
I routed mine under the engine cover...
Kevin, it can be done. I routed mine under the engine cover, I did have to cut some of the cover to accommodate the extra hose... but it came out looking nice and clean. I'll upload the pictures to my garage in a few minutes. Oh, and I have plenty of sound... so it might be the size of the hole to tapped into. I cut a 1" hole out of the Steeda tube, used a " sink tailpiece" ( plumbing supply) and then wrapped with silicone tape to seal up.
Ppkonablue12 is offline   Reply With Quote
Old 06-24-2015, 11:28 AM   #13
Kevin.Cook
Guest
Posts: n/a
Ok. thanks. I will keep an eye out for the pics.
Old 06-24-2015, 11:35 AM   #14
OK, I don't have any pictures with the cover on, but here's one showing the bend from the back of the motor along the firewall, to the cabin hole...
Old 06-24-2015, 11:39 AM   #15
Kevin.Cook
Guest
Posts: n/a
I dont see a breather filter on the drivers side crank case so I assume you are Manual? That is currently one of the poopy parts of being auto. You got 2 tubes running from the intake as it is. So I was able to eliminate 1 with a breather tube. May need to carve some of the padding on the bottom of the engine cover so it will sit cleanly above the breather filter.
Old 06-24-2015, 11:50 AM   #16
Sound tube? why on earth would you want it? Mine came off in the 1st week.
SVOGT302 is offline   Reply With Quote
Old 06-24-2015, 11:53 AM   #17
Kevin.Cook
Guest
Posts: n/a
With a 5.0, you get plenty of engine sound and exhaust sound. You have to remember for us little 6s, we don't. So we mod to give us stuff like the luxuries you have (or don't have....anymore).
Old 06-24-2015, 12:32 PM   #18
olerodder's Avatar
Region: Oregon
I just took mine off because I really couldn't hear anything and want to hear more of the GT500 twin tip mufflers.
Also, I couldn't fit this new addition because the sound tube was in the way.........if anyone wants a complete sound tube just let me know.
Name:	New Addition.jpg
Old 06-24-2015, 12:51 PM   #19
When you removed it could you even tell a difference?
IG @Oxford5pointoh
Old 06-24-2015, 01:03 PM   #20
olerodder's Avatar
Region: Oregon
IG @Oxford5pointoh
This is an old picture before I put the Ford Racing Coil Covers on.
It was hooked up I believe just like the original with the tube attached to CAI just ahead of the PCV hose attachment.
I could tell no difference at all.
Old 06-24-2015, 01:04 PM   #21
Kevin.Cook
Guest
Posts: n/a
I removed mine. I tried moving it like suggested and all the epoxy cracked and broke. It is too hot in Texas to be dealing with this mess. Put all of the stock stuff back on. About sweated my a** off just doing that.
Old 06-24-2015, 01:17 PM   #22
Going to pull mine off. I hadn't messed with it out of pure laziness but it's gotta go. I was just curious if it actually got any quieter in your cabin
IG @Oxford5pointoh
Old 06-24-2015, 01:50 PM   #23
I think you may be right. I do not have an engine cover and have the stock intake. I bought a sound tube modified by VIG. At WOT it definitely sounds more aggressive in the cabin than without it hooked up. All baffles out. Not a major improvement and no sound improvement outside the cabin. I am thinking about buying just the Airaid intake tube to see if sound improves more. Has anyone done this and what did it do to the sound?
tucsondivots is offline   Reply With Quote
Old 06-24-2015, 09:53 PM   #24
Tyriqq's Avatar
Been there done that Kevin. But I just took my cover off in an attempt to run the tube underneath it. But I had a little problem with the pony emblem breaking off the cover, then it go wet and the pony was never the same. Ended up just saying bye bye to my engine cover lol
Tyriqq is offline   Reply With Quote
Long tube/ short tube headers power band range rosad Pre-2005 V6 Mustang 0 02-25-2015 12:21 PM
Long tube or short tube headers? Laquisha 2011-2014 Mustang GT 17 09-14-2014 09:31 PM
Long tube or short tube headers for acceleration Mustang47 Pre-2005 V6 Mustang 7 10-31-2013 04:41 PM
Long tube vs short tube 94CobraUSMC 1979-1995 Mustang GT 15 06-24-2013 02:24 PM
Long tube header vs. short tube USMCSS 1996-2004 Mustang GT 5 12-24-2006 06:06 PM
03:00 PM
