Little Front Change... - Mustang Evolution
Old 06-26-2015, 03:32 PM   #1
Its been awhile since I have really done anything to my Mustang...Well that changed today...
old front end....
during....
new front end...
Finally got and installed the Roush Driving Lights that I have been wanting for a long time...
Steve
'14 Deep Impact Blue V-6 Coupe
MCA Package
V-6 Performance Package
Premium Package
SRE TUS is offline   Reply With Quote
Old 06-26-2015, 06:15 PM   #2
Hampton CIT's Avatar
Very sharp looking. Since you were already wired for factory fog lights, was it a simple plug in the new lights to the existing lines/switch or did you have to change something else out?
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 06-26-2015, 06:49 PM   #3
Commercial Member
au01st's Avatar
Look good. Are they. Tighter than the factory fogs? They'd have to be.
Sent from my #racecar
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 06-26-2015, 07:10 PM   #4
Waylap1's Avatar
Region: New Hampshire
Looks awesome! Tell us how the install went. Anything to watch out for or make it easier?
Waylap1 is offline   Reply With Quote
Old 06-26-2015, 07:15 PM   #5
I had to get a Starkey wiring adapter from CJ Pony Parts. The original fogs were H11 and the Roush are H10. The adapter was around $26. Works perfect...
Steve
MCA Package
Premium Package
Old 06-26-2015, 07:20 PM   #6
The install took about 6 hours or so. The hardest part was making the first hole...After that, just time consuming. The templates are good, kind of a pain to mark.
The biggest issue I have is with the 3m auto tape that comes in the kit. I put it too close to the edge, not thinking that it would squish out very much...Well it did in a couple of places. Still have to finishing cleaning those areas a little better. The other problem with the tape is getting the red backer off once I had them positioned. Some came off, some didn't...
Looking forward to seeing how bright they are at night. The MCA fogs were pretty good, but I was looking for more. If they don't cut it, then I'll replace the bulbs...
Steve
MCA Package
Premium Package
Old 06-26-2015, 07:21 PM   #7
They seem to be fairly tight. They are two piece that sandwich the bumper after you make the cuts. Also they use 3m tape...
Steve
MCA Package
Premium Package
Old 06-30-2015, 10:22 AM   #8
20prima10's Avatar
How hard was it to remove the bumper?
20prima10 is offline   Reply With Quote
Old 06-30-2015, 11:04 AM   #9
Commercial Member
au01st's Avatar
Autocorrect... Should have said "brighter".
Old 06-30-2015, 01:24 PM   #10
They are probably dimmer than the fogs that I replaced. Also much yellower. I have ordered some LED's that I plan on installing in the next few days. Supposed to be much brighter and whiter to match the headlights...
Steve
MCA Package
Premium Package
Old 06-30-2015, 01:35 PM   #11
Not hard at all. You remove 4 8 mm bolts from the radiator area. 6 7 mm bolts from in the wheel well. And 11 (I think) 7 mm bolts from under the front end. Takes about 30 to 45 minutes. There is a video by Late Model Restorations showing the Roush install, but it starts by showing the bumper removal...
I can't send the link thru my iPad.
Steve
MCA Package
Premium Package
Old 06-30-2015, 01:37 PM   #12
20prima10's Avatar
Ya I looked it up after typing that. Thank u though. I'm planning on ripping mine off to clear plastidip it. Extra rock protection
Old 06-30-2015, 02:14 PM   #13
JimC's Avatar
I see you had the MCA fog lights before. Do the Roush lights stick back as far into the bumper area? I have the Hellion turbo and with the location (behind the fog lights) I had to remove the fog light on the driver side. It stuck back too far and the turbo won't fit. If the Roush doesn't stick back as far as the stock lights I can put the fog lights back on the car - any chance you have a picture showing how deep they go on the back side? It looks like they mount more on the front of the bumper cover compared to the stock lights that are mounted back in the cover.
JimC is online now   Reply With Quote
Old 06-30-2015, 03:25 PM   #14
I don't have a picture but can take and post one in the next few days when I swap out the bulbs.
Steve
MCA Package
Premium Package
Old 06-30-2015, 03:31 PM   #15
JimC's Avatar
Thanks!
Old 07-02-2015, 12:30 PM   #16
Just got one with swapping out the crappy bulbs with LED's. Here are a few pictures for you. I hope this helps. The Roush Fogs do stick back fairly deep into the area...
Steve
MCA Package
Premium Package
Old 07-02-2015, 12:35 PM   #17
Just finished swapping out the bulbs that came with the Roush kit. They were not as bright as the stock fogs and too yellow for what I wanted. I ordered these from Amazon: Amazon.com: JDM ASTAR Extremely Bright Max 50W High Power H10 9145 LED Bulbs for DRL or Fog Lights, Xenon White: Automotive
They seem to be much brighter and whiter. Here is a pic with one JDM and one of the Sylvania bulb...
Steve
MCA Package
Premium Package
Old 07-02-2015, 06:18 PM   #18
JimC's Avatar
Thanks for those pictures - they are slightly shallower than the stock MCA/GT-CS fog light housings but still too far into the space to fit with my turbo I think.
To change or not to change? Djulin 2011-2014 Mustang GT 13 04-03-2013 10:20 AM
Another oil change thread and front air dam Mlarv5 Shelby Mustang 1 01-06-2013 05:43 PM
Front end change to GT/CS m_tyler_r 2011-2014 V6 Mustang 14 12-15-2012 02:32 PM
A little change to the stang redfire2003 Mustang Audio & Video 18 08-28-2005 09:18 AM
05:56 AM
