Fuse 47.... are you using a relay or doing it manually. - Mustang Evolution
Old 06-27-2015, 06:25 PM   #1
TedG's Avatar
Re-post....
$38 shipped from Amazon.
HELLA 007794301 Weatherproof 20/40 Amp SPDT Mini Relay with Bracket
Sold by Amazon.com LLC
GTC CT6100 Fuse Socket Connector Kit GTC CT6100 Fuse Socket Connector Kit
HELLA H84709001 Iso Weatherproof Relay Connector with 12" Leads HELLA H84709001 Iso Weatherproof Relay Connector with 12" Leads
Inline Littlefuse Fuse Holder ATO ATC Kit Waterproof Marine Motorcycle 18 -16 Ga 15 Amp In-line Waterproof.
20 minute job at the kitchen table. Works like a charm!
Click on this link for directions....
http://www.paddedwall.org/2012mustang/Transmission.aspx
Become an Organ Donor today: http://donatelife.net/register-now/
Save as many as 50 lives. Thanks.
TedG is offline   Reply With Quote
Old 06-27-2015, 06:35 PM   #2
TedG's Avatar
Photos of the finished product.
Old 06-27-2015, 10:24 PM   #3
jayochs's Avatar
soo.. whatis fuse 47 lol
Sent from my Samsung Galaxy Note 4 using Tapatalk.
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 06-27-2015, 10:38 PM   #4
Commercial Member
au01st's Avatar
Originally Posted by jayochs View Post
soo.. wtf is fuse 47 lol
It resets the adaptive shifting which learns how you drive and adjusts shift points to improve fuel economy (and reduce performance!)
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 06-28-2015, 06:27 AM   #5
Jon3.7's Avatar
If you're tuned you should be fine right
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-28-2015, 06:53 AM   #6
TedG's Avatar
Paddedwall.org - 2012 Mustang Shelby Tribute
Old 06-28-2015, 06:55 AM   #7
TedG's Avatar
No. The tune will set up the transmission when installed, but eventually the shift points will adapt to what the FORD ecu dictates.
Old 06-28-2015, 06:55 AM   #8
Jon3.7's Avatar
So.. every once and a while, unplug it?
Old 06-28-2015, 07:07 AM   #9
tym_v6's Avatar
I've been using the relay mod since January. Snappier shifts, no problems, and no detectable change in fuel economy, so a win-win-win.
Old 06-28-2015, 07:10 AM   #10
Jon3.7's Avatar
I hate wiring....
Old 06-28-2015, 07:26 AM   #11
TedG's Avatar
I hate wiring....
This isn't "wiring". Anyone that can't do this job should not change light bulbs.
Old 06-28-2015, 09:40 AM   #12
jayochs's Avatar
so, this wouldn't apply to a manual at all i presume?
Old 06-28-2015, 09:44 AM   #13
TedG's Avatar
no
Old 06-28-2015, 10:12 AM   #14
Diehard's Avatar
Apparently some of the tuners don't agree with the need to pull this fuse when tuned.
See item #41 of...
Throttle is non responsive
Bama says they don't recommend pulling fuse #47.
See post #12 of...
Had a strange occurance after pulling fuse #47
Old 06-28-2015, 10:18 AM   #15
TedG's Avatar
See item #41 of...
See post #12 of...
OK
My relay has been installed and untouched for over a year. I have not experienced any problems, but I have noticed snappier shifting. While BAMA and MPT suggest that you do not alter the Fuse 47 setup, they fail to state WHY. Could it be that they'd prefer you stay on the elusive hunt for performance improvements.... that they will glady supply? I honestly don't know their reasons for their recommendations.
BAMA and/or MPT are free to chime in if they have a good reason to share. I'll listen.
Old 06-28-2015, 01:46 PM   #16
Diehard's Avatar
OK
I agree that Bama and MPT are a bit wishy washy with their comments on the subject, but MPT implies they have fixed it in their tune. And Bama says theirs will modify what can be learned and just how far these adjustments can go.
But they should be coming out and saying whether it can be detrimental to pull the fuse with their tune installed and why. They may not know.
Oh BTW you kind of imply you have a tune but I didn't notice that anywhere. ???
Old 06-28-2015, 01:49 PM   #17
TedG's Avatar
I've had a Bama tune since the beginning. I run it at 93 R. No problems.
Old 06-28-2015, 01:57 PM   #18
Diehard's Avatar
Yes I just found that under your garage.
I am not tuned nor have I ever pulled the fuse. Having driven mine for a year now I should try it and see if I notice a difference. I suppose I should try pushing it a bit first to test it's capabilities, then do the same after pulling fuse.
Usually when I want to drive a bit more spiritedly, I put it in the auto/sport mode.
Old 06-28-2015, 02:08 PM   #19
TedG's Avatar
I honestly don't know if pulling the fuse will affect the shift points without a tune. The tune re-sets the shift points and Ford's adaptive shifting tries to readjust it. Pulling the fuse sets the car back to the tuned points. At least that's my understanding.
Old 06-28-2015, 02:09 PM   #20
Jon3.7's Avatar
it's all in the programming. Ill go with my tuner suggests and be done.
Old 06-28-2015, 06:51 PM   #21
SouthernCyclone's Avatar
Relay Mod- 2 years and 0 issues
SouthernCyclone is offline   Reply With Quote
Old 06-28-2015, 08:23 PM   #22
VIG
VIG's Avatar
Region: Delaware
This is one of those "when I get around to it" mods. I just pull the fuse every so often after the tune feels noticeably watered down.
Et voila, back to new again.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 06-29-2015, 12:46 AM   #23
Midnight2012's Avatar
If it's adaptive learning won't it readjust if you drive more aggressively?
Midnight2012 is offline   Reply With Quote
Old 06-29-2015, 01:43 PM   #24
MustangDawg's Avatar
+1
2013 V6 Auto Premium | Sterling Gray | Pony/Comfort/Security Packages
Borla S-Type AB, Airaid CAI, SR Performance STB, JLT Oil Separator, MPT Tuned, MMD Classic Louvers, Roush Upper & Lower Grilles, BFGoodrich G-Force Sport Comp-2 A/S Tires, Koni STR.T Shocks & Struts, SR Performance Lowering Springs, J&M Stainless Steel Teflon Brake Lines, BMR LCAs w/Brackets, BMR Panhard Rod Support, Whiteline Adj. Panhard Bar, Ford Racing Differential Finned Cover Plate, Philips X-tremeVision LED Fog Lamps, JMS PedalMax
MustangDawg is offline   Reply With Quote
Fuse 47 Changeover to Relay DIY TedG Mustang DIY and Technical 15 06-08-2015 04:51 PM
Are You Using the #47 Fuse Bypass Relay? TedG 2011-2014 V6 Mustang 11 10-06-2014 01:08 AM
Has anyone done the Fuse 47 Changeover to Relay TedG 2011-2014 V6 Mustang 11 06-25-2014 07:10 AM
Fuse 47 By-Pass to Relay w/photos TedG Mustang DIY and Technical 6 06-03-2014 06:40 PM
Window fuse/relay jjpea 1996-2004 Mustang GT 1 03-13-2009 10:15 PM
11:08 PM
