Hawk Brake Pad install - Mustang Evolution
Old 06-27-2015, 06:37 PM   #1
Kevin.Cook
Guest
Posts: n/a
So today I installed my new Hawk Performance Ceramic Pads I got from AM. I also got my rotors resurfaced and installed my caliper covers. Everything fit fine. Took it for a few drives, and the new pads have good bite. The only problem I have with them, is they make A LOT of noise when close to a stop. It is extremely embarrassing and people stare. I got these because they were supposed to be extremely quiet compared to the others.
So I am a little upset about that. I did double check how they were installed and I did apply the gel. Double checked the rotors too and they are smooth with no abnormal wear.
The caliper covers look amazing I must say. I could not get a really good picture with the rims I currently have.
ID:	185997   Click image for larger version
Old 06-27-2015, 06:39 PM   #2
oxford5pointoh's Avatar
Wait, I thought you were installing brembos and wanted to know if your rims we're going to clear. What happened there?
IG @Oxford5pointoh
Old 06-27-2015, 06:41 PM   #3
Kevin.Cook
Guest
Posts: n/a
The $1,150 for the parts, the money needed for spacers, and the money needed for labor. LOL. Kept going over other people's suggestions and since our 6s don't put out alot of power nor do I track it, some nice pads and caliper covers would suffice.
But in case anyone did want Brembos for their V6 PP or GT/CS cars, you need 1/2" spacers.
Old 06-27-2015, 07:08 PM   #4
rringler's Avatar
Calipers look good! You should notice the brake dust minimized as well. Maybe the pads will quite down after a bit? Keep me updated on those pads, like we discussed earlier, when I need replacing I wanted to get these as well!
rringler is offline   Reply With Quote
Old 06-27-2015, 07:15 PM   #5
Socal Stangman's Avatar
They will probably get quieter when they bed a little more.
Labor? Dude you got to stop paying for labor. It's so easy to do these jobs. If you saw how easy it really is you'd want all your money back you spent in labor.
Old 06-27-2015, 07:24 PM   #6
Kevin.Cook
Guest
Posts: n/a
It's ok. I don't mind too much. Appreciate the concern though
Old 06-27-2015, 07:37 PM   #7
I have the same hawk pads in the rear of my car. I didn't notice any noise at all. I installed new rotors when I put them on because I went to the 13.8" Shelby rotor. Like mentioned before, they will get quieter as you break them in.
Sorry you couldn't swing the brembos. I don't think it matters what motor you have, upgraded brakes are a good investment. But I get it. They are not cheap.
IG @Oxford5pointoh
Old 06-27-2015, 08:22 PM   #8
Mean14's Avatar
Looks great! I also have a set of caliper covers and love them. I'm going to paint the calipers matte black to match the covers though because with the bigger wheels I have, you can see the silver calipers and it looks tacky.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 06-27-2015, 08:23 PM   #9
Diehard's Avatar
Kevin...For your consideration.
How to Bed-in Brake Pads - The Best Technique for Bedding in Brake Pads
To be honest, I have yet to try bedding my new brakes.
Here's one by Hawks.
http://www.hawkperformance.com/sites...ts_Bedding.pdf
Old 06-27-2015, 08:42 PM   #10
Kevin.Cook
Guest
Posts: n/a
I appreciate it. These coupled with my gear break in period, really makes for boring drives. Lol
Old 06-27-2015, 09:49 PM   #11
Sakol's Avatar
Thanks for the info. I picked up some from AM too. Click image for larger version
Name:	ImageUploadedByMustang Evolution1435463358.410373.jpg
Sakol is offline   Reply With Quote
Old 06-29-2015, 03:41 AM   #12
jande063's Avatar
I would make sure that whomever performed the install used the provided grease on the backing plate of the pads. The only Hawk (street) pads that should make noise would be the HP+.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 06-29-2015, 07:19 AM   #13
Kevin.Cook
Guest
Posts: n/a
The grease was applied to the backings of the brake pads. I was bored this weekend so I tried the bedding process a few times, with about 4-5 hours in between each. But after each one, I did not notice the brake pads getting any quieter. Probably put like 100 miles on just this weekend with trying to wear them down. At least I am about halfway with the gear break in now. lol
They are only noisy when I am almost to a dead stop.
Old 06-29-2015, 08:43 AM   #14
jande063's Avatar
Are they squealing under light braking at low speed, or hard braking?
Old 06-29-2015, 08:50 AM   #15
Kevin.Cook
Guest
Posts: n/a
light. i could brake hard to make it go away, but then I jerk to a halt and I don't like doing that to my brakes.
Old 06-29-2015, 07:07 PM   #16
tym_v6's Avatar
I put in some Hawk HPS pads on my front wheels about a year ago, and now have some squealing under light braking. I'm pretty sure it's the little stainless clips/brackets that go between the caliper body and the "ears" of the pads. I never replaced them, and I think they loosen up and rattle.
I'd bet good money that some re-greasing of those areas (and the backs of the pads, and the face of the pistons) will solve your problem. No matter how good the grease, repeated braking cycles, rain, road grime, etc., will eventually dry it up or wash it out.
Old 06-29-2015, 09:03 PM   #17
Damn Kevin it doesn't seem like you've had much luck lately...
Old 06-30-2015, 06:48 AM   #18
Kevin.Cook
Guest
Posts: n/a
Yup. And I am almost scared to order new wheels or anything else. D:
So as of now I am about 150 miles in on the new brake pads but they still make as much noise as before. Tried braking with different amounts of pressure for different amounts of time while going different speeds. I am just going to assume if it doesn't go away by 300 miles or so, that this is how these pads that I got are.
Old 06-30-2015, 07:18 AM   #19
Ish416's Avatar
I run hawk ceramics on my z28 and they squeak a bit. The only solution I found was to do a few full on panic stops from 70 mph and then drive around for 15 - 20 minutes to cool down. That seems to fix the issue for a few weeks-month.
Old 06-30-2015, 08:24 AM   #20
Kevin.Cook
Guest
Posts: n/a
I usually take my frustrations out by playing COD: AW for PS4
Old 06-30-2015, 11:52 AM   #21
rringler's Avatar
Damn, me too but on Xbox one!
Old 06-30-2015, 11:53 AM   #22
Diehard's Avatar
Recruit, Regular, Hardened or Veteran?
A diehard PC player.
Old 06-30-2015, 11:54 AM   #23
Kevin.Cook
Guest
Posts: n/a
Argh!!! Well xbox one has ruled the COD world on early releases. But starting with Black Ops 3, PSN will now be getting everything a month early and Xbox users will have to wait.
Sorry for the unrelated discussion :O
Old 06-30-2015, 11:58 AM   #24
Kevin.Cook
Guest
Posts: n/a
I usually beat the campaigns on Veteran to earn all of the trophies. I got the Platinum for Black Ops 1 and missing like 2-3 trophies for the MW2 Platinum. I think I got like 50% of the trophies for MW3 and Black Ops 2. I used to be a hardcore zombies player on BO1. Went to round 60 or 61 on the Black Ops 2 zombies map Die Rise.
With all my car problems and situations, I have not had time to even play the AW campaign.
Old 06-30-2015, 12:56 PM   #25
COD stopped impressing me after the first Black Ops
Old 06-30-2015, 01:45 PM   #26
jande063's Avatar
Same, I played a bit of black ops 2, then never did cod again. Steady diet of Forza and IRacing in the off season.
Old 06-30-2015, 01:49 PM   #27
I played COD since literally the very first one. Back when it was about the actual game. Now they don't put any thought I to campaign. And the game feels like it speed up. I like tactical shooting, not run and gun.
Old 06-30-2015, 01:55 PM   #28
jande063's Avatar
Then the new Rainbow Six may be closer to your style. Hopefully it is not multiplayer only (it looks like it may be).
Old 06-30-2015, 02:48 PM   #29
Diehard's Avatar
Agree! Too fast and restricted.
Prefer open world types like Far Cry 3 & 4, Borderlands 2, Just Cause2(3 coming out Dec). Also, Wolfenstein & Rage.
Old 06-30-2015, 02:50 PM   #30
Kevin.Cook
Guest
Posts: n/a
This thread died a slow death...lol
Old 06-30-2015, 02:55 PM   #31
Diehard's Avatar
Well I don't hear any brakes squeaking.
Old 06-30-2015, 02:57 PM   #32
Kevin.Cook
Guest
Posts: n/a
Trust me man, they are squeaking like there is no tomorrow. Lol
Hawk HPS rear brake pad fitment Redonblackpony 2011-2014 Mustang GT 4 12-13-2014 03:47 PM
Rear Brake Pad Install Write-up 1slosix Pre-2005 V6 Mustang 5 03-18-2013 12:11 PM
Post brake pad install help silvr002001 1996-2004 Mustang GT 7 03-12-2012 06:26 PM
Hawk Brake Pads Crispy Pre-2005 V6 Mustang 0 08-21-2004 04:27 PM
06:29 PM
