Past Few Days - Mustang Evolution
Old 07-02-2015, 08:53 PM   #1
5pointYoBro's Avatar
Past Few Days
HID Kit and Suspension (Coilovers, upper and lower control arms, panhard bar)
** Click on the pic and they will rotate. I think the pic is too big
ID:	186392   Click image for larger version
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 07-02-2015, 08:59 PM   #2
oxford5pointoh's Avatar
Drop looks great. Love those wheels too man.
IG @Oxford5pointoh
Old 07-02-2015, 09:03 PM   #3
Kevin.Cook
Guest
Posts: n/a
I would've dropped it a tad more and rolled the fenders. Preferably with an aluminum baseball bat.
Old 07-02-2015, 09:04 PM   #4
IG @Oxford5pointoh
Thanks brah.
Old 07-02-2015, 09:36 PM   #5
Mean14's Avatar
Looks great! Digging the stance and those wheels.
If you haven't already, pick up a set of lower control arm relocation brackets in order to correctly pitch the position of the LCA's after the drop. The rear part of the LCA (connected to the axle) should be parallel/lower(depending on your setup) than the front of the LCA (connected to the body).
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 07-02-2015, 09:39 PM   #6
Socal Stangman's Avatar
Looks great. What kind of coil overs? How's the ride?
Old 07-03-2015, 08:03 AM   #7
Already done my friend. Thanks for looking out though. Got the adj upper control arm too with the bracket
Old 07-03-2015, 08:07 AM   #8
Their BC Racing Coilovers.
And all other parts are BMR.
The ride is good, not like a dump truck lol. You can adjust the ride quality to make it stiff or soft. Mine right now is still pretty soft.
Handles way better in the corners now and basically have no nose dive when I brake.
The control arms made a huge difference in acceleration, the rear end doesnt squat much at all when I get on it.
Old 07-03-2015, 08:11 AM   #9
pitboss's Avatar
Love the hid set up. I did mine too with the stock lenses and the fogs. Doesn't blind others and allows a little more light down the road. The stock lighting suuuucks lol. I was running over my old headlight beam within a second
2012 Pony Pkg 3.7 convertible, MPT tuned, 4.10's, Dynotech 3.5" DS, Borla Touring axle backs, BBK 73mm TB and ceramic shorties, Whiteline sway bars and UCA/LCA with relocation brackets, BMR adj. PHB and brace, Steeda CAI, CE frame braces, Bilstein shocks, H&R race springs, SS brake lines, full HID, GT 500 gauge pod with gauges and misc. exterior upgrades
pitboss is offline   Reply With Quote
Old 07-03-2015, 09:33 PM   #10
Where did you buy your hid kit from? Mine's dm tuning, think its some company in china. Took a month to ship it here
Old 07-03-2015, 09:57 PM   #11
pitboss's Avatar
I was having amp and sub installed at California Sound in San Bernardino CA and the main guy said he could do headlights for 150 and fogs for 150 SO I TILD HIM TO DO IT lol. The first ballasts he used quit working 2 days later so I went back and he swapped them out for high end ones. No problems since. I'm using 6k lights. Guy said that's the max to go with non oem. I luv them
Old 07-03-2015, 10:06 PM   #12
Gotchya. Pretty sure my bulbs are 6k too.
Old 07-05-2015, 08:42 PM   #13
Did you do a retrofit? Or did you just install HID bulbs?
These are my headlights and my cut off
ID:	186565   Click image for larger version
theblackdahlia is offline   Reply With Quote
Old 07-05-2015, 08:46 PM   #14
Damn that looks sick!
Mine is just a 35w HID kit. (6k bulbs, ballasts, and all the wires and plugs.)
Old 07-05-2015, 08:48 PM   #15
Gotcha!
You should look into getting some halos or demon eyes!
Ive been building a lot of headlighrlts with demon eyes lately, theyre really popular
Old 07-05-2015, 08:49 PM   #16
Do you have a pic of one with halo's and no demon eyes?
Old 07-05-2015, 08:54 PM   #17
Heres a couple i have done, but to do these halos, you need projectors to mount them on
ID:	186567   Click image for larger version
Old 07-06-2015, 07:46 PM   #18
I might get them HID retrofitted down the road. But have other stuff to do first
Old 07-06-2015, 07:58 PM   #19
Highly recomend it, even ifit's just a basic Retrofit with no halos or anything
Gives a great color cut off,
And theyre a lot brighter and safer than halogen
It's been too quiet around here the past few days... lowflyn The Bar 39 07-15-2008 11:07 AM
06:27 PM
