Suspension Work - Mustang Evolution
Old 07-06-2015, 11:58 PM   #1
mutaz102's Avatar
Suspension Work
A while ago when the car had about 40k miles on it, I installed SR lowering springs with J&M panhard bar. Now after about 6k miles the car started making some noise in the front when moving the steering wheel and rattle noise on the passenger rear end. So I figured out that it's the time to upgrade the suspension. I need your recommendations for the needed parts as the car is my DD.
mutaz102 is offline   Reply With Quote
Old 07-07-2015, 07:50 AM   #2
alrefire's Avatar
Bmr makes good stuff.
Start with their LCAs, LCA relo brackets, and the UCA with mount. Then upgrade to 2010 struts and shocks with gt500 mounts (that'll fix your popping problem) you'll probably want camber bolts too.
At some point in time you'll upgrade your sway bars.
Old 07-07-2015, 09:15 AM   #3
Socal Stangman's Avatar
So to use the GT 500 mounts you have to use 2010 Struts?
Old 07-07-2015, 03:16 PM   #4
rob.james.arias
Guest
Posts: n/a
That is correct. The threading length for the top most strut bolt is a different length.
Old 07-07-2015, 03:20 PM   #5
rob.james.arias
Guest
Posts: n/a
I went through a similar experience except my car was BRAND new. I used the same brand parts as you. For me the solution was new OEM strut mounts for the front. The rear was two fold, the hanger on the muffler was rattling against the sway bar link. The sway bar was also loose.
Replace strut mounts $119. Tighten everything in the rear, free.
Old 07-07-2015, 06:04 PM   #6
mutaz102's Avatar
I was thinking about KONI shocks and struts but I'm not sure if the car would benefit from them right now
Old 07-07-2015, 08:49 PM   #7
5pointYoBro's Avatar
What kind of noise does it make when you move the steering wheel? Does it do it when you're not moving?
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 07-07-2015, 08:51 PM   #8
If you're lowered you will benefit with new shocks and struts. The stock ones are not designed to be used with a lowered vehicle. These are next on my list as well.
Old 07-08-2015, 04:43 AM   #9
shunc01's Avatar
Socal if you don't mind what's going to be your set up? Suspension wise.. Thanks
MPT TUNE, Borla S-Type, Airaid Cai, Ford racing X pipe, Mac ceramic shorty headers, 2010 GT500 rims, 35% tint, Sr Springs, J&M phb, camber bolts, blacked out side markers, front and taillights.
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 07-08-2015, 09:25 AM   #10
I just started doing some research on this so Im not 100% yet. What Im looking at though is:
Real LCA's
Rear upper control arm and mount
Relocation Brackets
Most likely Koni Shocks
GT500 Mounts
Ill probably also do some new springs. I want to go a little lower.
Then at some point new sway bars
Right now this is on hold. Im getting a new hood and paint so Ill pay off this first and then move on to my suspension.
Old 07-08-2015, 09:42 AM   #11
shunc01's Avatar
Real LCA's
Relocation Brackets
GT500 Mounts
good plan my friend, i will copy your build list since this is where im going for as well.. little by little..
Mods:
Would kind of suspension would work in a 1966 mustang? sevastianos Classic Mustangs 1 12-14-2011 05:17 PM
Suspension work-arounds? ColeJohnson 1996-2004 Mustang GT 3 12-13-2011 08:55 AM
suspension work needed geo Pre-2005 V6 Mustang 11 10-07-2011 05:15 PM
A little suspension work... lowflyn Pictures and Videos 30 05-13-2008 08:14 PM
suspension work... whipster24 Pictures and Videos 23 03-13-2006 11:47 PM
05:12 AM
