Accessory power points always on - Mustang Evolution
Old 07-09-2015, 12:04 PM   #1
king_13's Avatar
So the power ports in the car are always on in my 2011, and while it doesn't particularly bother me, I have a radar detector on the dashboard that is always on. Its becoming tedious to turn it off manually. On my wife's Cruze, the power ports lose power as soon as the key is out and the driver door is open.
Is there anyway to have it turned off like the Cruze?
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 07-09-2015, 12:24 PM   #2
20prima10's Avatar
You would have to rewrire the power wire to a wire that's only on when the key is on. Such as your radio power wires. Pretty easy to do something like this.
20prima10 is offline   Reply With Quote
Old 07-09-2015, 01:15 PM   #3
Strange Mud's Avatar
not w/o rewiring it as Prima said.
Old 07-09-2015, 01:45 PM   #4
tym_v6's Avatar
Do you have an auto-dimming mirror? If so, you can tap into the connector on the back to power your radar detector. It will be on the accessory delay circuit.
I did this on my '13 and it was pretty simple. My radar detector uses an RJ-11 plug for power, so I just hacked up an old phone cord, soldered on a couple of gold-plated pin connectors, and stuck them in the back of the connector supplying the mirror. Just be sure you don't short anything or you'll be replacing the accessory delay fuse (ask me how I know).
Old 07-10-2015, 09:10 AM   #5
king_13's Avatar
I do indeed have the auto dimming mirror, is there a guide on how to do this?
Sent from my iPhone
Old 07-10-2015, 11:18 AM   #6
tym_v6's Avatar
There should be one out there. They also sell a pre-made "mirror tap" that does what I described, so you might try Google searching for that term.
Old 07-10-2015, 01:31 PM   #7
I think I seen those wires on Amazon.com
I have my GPS plugged in to my center power receptacle on my 2102. The receptacle is on all of the time and I always leave my GPS plugged in and just turn it off. My radar detector is AA battery powered just the way I like it. No wires at all.
Old 07-10-2015, 04:42 PM   #8
tym_v6's Avatar
Here's the website that sells the pre-made MirrorTap with in-line fuse: MirrorTap Radar Detector Power Cords.
That said, if you are handy with tools, you can make your own for under $10 (probably under $5 if you omit the fuse, which isn't really necessary as the circuit in the car has is fused already).
Old 07-11-2015, 08:39 PM   #9
I have the same problem, it burn up my radar detector
Sent from my SM-G925T using Mustang Evolution mobile app
PapiJose is offline   Reply With Quote
Old 07-11-2015, 09:01 PM   #10
tym_v6's Avatar
What problem was that?
Old 07-12-2015, 06:28 AM   #11
I can't see how that can happen.
PapiJose say's:
Are you talking about the wire to plug it into your mirror?
Old 07-12-2015, 12:09 PM   #12
GrabberBlue1993's Avatar
Just install a toggle switch, I have one for my boost gauge
Sent from my 831C using Mustang Evolution mobile app
"At least it isn't a Honda"
GrabberBlue1993 is offline   Reply With Quote
Old 07-12-2015, 06:16 PM   #13
Diehard's Avatar
Keep in mind that every electrical circuit is protected by a fuse, which was sized to protect the wiring circuit, based on a maximum anticipated load. I'm guessing the typical radar detector would not impose that great of an additional load to worry about, but when adding a new load to an existing circuit be aware of why there are different fuse sizes for different circuits.
Old 07-12-2015, 09:55 PM   #14
tym_v6's Avatar
Originally Posted by Diehard View Post
Keep in mind that every electrical circuit is protected by a fuse, which was sized to protect the wiring circuit, based a maximum anticipated load. I'm guessing the typical radar detector would not impose that great of an additional load to worry about, but when adding a new load to an existing circuit be aware of why there are different fuse sizes for different circuits.
An excellent point.
Accessory plug Kbasham5 1996-2004 Mustang GT 3 09-13-2013 05:32 PM
Quick! Best accessory/upgrade on Amazon for $50 or less! GBMustang13 The Bar 14 09-13-2013 07:51 AM
Accessory Drive Whine dellito 2011-2014 Mustang GT 18 07-06-2012 08:27 PM
accessory drive bracket question mudduck7 1979-1995 Mustang GT 1 01-21-2012 11:33 PM
GT Coupe/Convertible Accessory Package 4 Marquise23 2011-2014 Mustang GT 0 08-16-2009 08:05 PM
11:21 AM
