That hesitation tho - Mustang Evolution
Old 07-11-2015, 03:28 PM   #1
jayochs's Avatar
That hesitation tho
i've seen before that i think someone said it was an effect of the DOHC, but i can't remember or if i'm just making it up....
but i'm sure you've all felt that hesitation, let's say where you're flooring it in 2nd or something, and even though you're flooring it, the power doesn't really kick in until the mid to high RPM range, and then all is good.
i'm all, 'vtec just kicked in.' :p
but seriously ,what causes this exactly?
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 07-11-2015, 03:34 PM   #2
Mean14's Avatar
3.7L 4V Ti-VCT V6 engine
The new 3.7L 4V Ti-VCT V6 engine achieves an industry-exclusive 305 horsepower and 280 lb.-ft. of torque while delivering an EPA-estimated 31 hwy MPG*. That’s due in part to twin independent variable cam timing (TiVCT) which allows variable control of intake valve closing. This capability optimizes combustion at full load to provide improved power and low speed torque. It also enables variable valve overlap, which provides better fuel economy and optimizes cold start operation with improved exhaust emissions.
**copied and pasted from v6mustangperformance.com
If you want more low end grunt to get into your RPM band faster, look into installing a set of gears. 3.55 and up will get rid of most of the hesitation.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 07-11-2015, 03:38 PM   #3
Kevin.Cook
Guest
Posts: n/a
And a good tune will help along with gears.
Old 07-11-2015, 06:33 PM   #4
jayochs's Avatar
it doesn't seem to do it every time though..so it's cam timing pretty much? it's like sometimes it'll be a bit hesitant, then it just jumps to life and bam.
idk if i'm going to do anything big on the car like a tune or gears, but i was just curious what exactly did this. thanks!
Old 07-11-2015, 07:14 PM   #5
Mean14's Avatar
If you're still running the stock 2.73s, that has a lot to do with it. I know exactly what you're talking about though cause I'm running stock gears as well. I like it though because there is more time spent in the powerband compared to lower gears.
Old 07-11-2015, 07:31 PM   #6
jayochs's Avatar
ahh i see. thanks 😆
Sent from my Samsung Galaxy Note 4 using Tapatalk.
Old 07-11-2015, 08:16 PM   #7
shunc01's Avatar
If you want to upgrade your stock gears im selling my stock 331 gears.
MPT TUNE, Borla S-Type, Airaid Cai, Ford racing X pipe, Mac ceramic shorty headers, 2010 GT500 rims, 35% tint, Sr Springs, J&M phb, camber bolts, blacked out side markers, front and taillights.
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 07-12-2015, 02:13 AM   #8
alrefire's Avatar
Yup, gears and shorties will give you the most low end torque.
Only reason I haven't done shorties is because I'm going turbo here shortly after I finish the motor.
The turbo manifolds kind of look like shorties?
Old 07-12-2015, 05:22 AM   #9
ponie1992's Avatar
Even with 3.31 gears, mine will do this from time to time.
Sent from my SM-G920V using Mustang Evolution mobile app
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 07-12-2015, 09:07 AM   #10
Ish416's Avatar
The valve train layout (OHV, SOHC, DOHC), cam phasing and gearing has nothing to do with this issue.
The issue the OP is describing is simply throttle by wire. Basically even if you have the gas pedal floored, the throttle may not be completely open until the computer in the car tells it to open 100%. Most cars with electronically controlled throttles will have this issue in one way or another.
A tune will help this issue but will still not completely remove it.
Going with lower gears (3.55, 3.73, 4.10) will make the issue harder to feel but it will still be there.
If you have a premium car or a wideband, watch it, when this happens the AFR won't change to indicate full throttle, until you feel the car really start to accelerate.
Old 07-12-2015, 09:11 AM   #11
Rapinator126's Avatar
Something that actually helps. Is the pedal max from JMS.
http://www.latemodelrestoration.com/...-px-5000-1114f
Old 07-12-2015, 09:19 AM   #12
oxford5pointoh's Avatar
Do you have one of these?
IG @Oxford5pointoh
Old 07-12-2015, 09:23 AM   #13
IG @Oxford5pointoh
Yes
Old 07-12-2015, 09:24 AM   #14
Yes
Interesting. I thought this was adjusted through a tune as well? So if you have a tune, how does this help? Just curious. Never seen these
IG @Oxford5pointoh
Old 07-12-2015, 09:26 AM   #15
IG @Oxford5pointoh
Yes it still helps. It just ups the voltage. The tune only does so much
Old 07-12-2015, 09:36 AM   #16
Oh okay that makes sense
IG @Oxford5pointoh
Old 07-12-2015, 09:38 AM   #17
alrefire's Avatar
I had no idea this thing existed!
Old 07-12-2015, 10:39 AM   #18
jayochs's Avatar
THANK YOU. I knew this was part of the reasoning. it just feels like it's not kicking in, and i knew gears weren't the issue because i thought I saw someone talk about this somewhere before. it was always a computer issue. awesome.
Old 07-12-2015, 10:42 AM   #19
jayochs's Avatar
and that pedal max looks awesome. so even without a tune, it helps?
Old 07-12-2015, 10:42 AM   #20
Yes
Old 07-12-2015, 11:07 AM   #21
tym_v6's Avatar
Cool but a little spendy.
Old 07-12-2015, 12:42 PM   #22
jayochs's Avatar
yeah, seems expensive, but i bookmarked it. maybe in the future i'll check it out.
94 3.8 off idle hesitation problem crash Pre-2005 V6 Mustang 3 07-14-2008 06:19 PM
Haha this is funny but sucks tho ridenmystang Pictures and Videos 6 02-05-2007 09:20 AM
Hesitation at 40-50 MPH mustang2002 Pre-2005 V6 Mustang 8 05-03-2006 07:51 AM
'02 GT Hesitation?? SHAG5150 1996-2004 Mustang GT 4 03-16-2006 02:09 AM
Hesitation in Accelerating... Ibanezplayer272 1979-1995 Mustang GT 15 11-28-2005 06:09 AM
11:58 AM
