Alignment Report Ride Height Specs - Mustang Evolution
Old 07-14-2015, 11:26 AM   #1
Diehard's Avatar
On the bottom of the attached alignment report they show "front and rear ride heights". Does anyone know where those dimensions are taken?
Name:	Alignment Specs.jpg
Old 07-14-2015, 12:26 PM   #2
Mean14's Avatar
Hey you copied my picture! Lol.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 07-14-2015, 12:27 PM   #3
Mean14's Avatar
No idea where it's taken from but keep in mind those are stock specs on a stock vehicle.
Old 07-14-2015, 01:29 PM   #4
Diehard's Avatar
Yes! I knew you wouldn't mind me borrowing your report.
I thought I'd get my car good and level and then check heights, camber angles and rear wheels-to-body alignment, as a reference point before I do any suspension work.
I noticed typically when ppl talk about ride height they are looking at the distance from ground to wheel well lip. Or better still, center of wheel to wheel well lip.
So I can't even guess where those spec #'s of 1.6"(avg) Front and 4.45"(avg) Rear, are measured.
Old 07-14-2015, 01:39 PM   #5
Voltwings's Avatar
On the miatas we measure ground to rocker panel (side skirt) and our ideal ride height is right around 4.25", but for the life of my i cant figure out what the 1.x could possibly be measuring if its the min and 4.x is the max.
Old 07-14-2015, 03:25 PM   #6
Diehard's Avatar
That was 1.30" min to 1.93" max for the front. The 4.13 to 4.76 was for the rear.
Yeah, it can't be anything from the ground.(I don't think.)
I'm going back out there now to finish trying to level it. It's a good thing I have plenty of scrap wood.
And I'll take a look for something that comes close to those spec heights.
Old 07-14-2015, 03:31 PM   #7
Mean14's Avatar
I can call the alignment shop I got it done at and ask them. Don't hurt yourself thinking too hard. 😋
Old 07-14-2015, 04:57 PM   #8
Diehard's Avatar
LOL...That would be great!
I'll buy you a drink the next time I'm in Chicago.
Need 94-95 specs engine specs blaster_5.0 1979-1995 Mustang GT 0 10-28-2013 09:23 AM
alignment specs problem? Audicrashdummy 2005-2010 V6 Mustang 4 08-16-2013 10:13 PM
staggered required alignment specs for auto cross? M3hunter 2011-2014 Mustang GT 4 09-13-2012 12:33 PM
Ride Height Change obxdude018 Pre-2005 V6 Mustang 5 08-10-2010 07:31 AM
Would it be possible to make a 82 Mustang 4 wheel and still retain it factory ride height? wolfgang General Mustang Discussion 3 03-19-2010 09:17 PM
10:33 AM
