Tire Size for Tune - Mustang Evolution
Old 07-15-2015, 07:20 PM   #1
5pointYoBro's Avatar
Tire Size for Tune
Why do they ask for a tire size in your info for a tune???
May be a noob question, but I ask because I switched to a different size tire in the rear.
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
5pointYoBro is offline   Reply With Quote
Old 07-15-2015, 07:21 PM   #2
DiESeven's Avatar
To correct speedometer.
Old 07-15-2015, 07:24 PM   #3
So if I went from a 275/35/20 to a 285/30/20 my speedo is off?
Old 07-15-2015, 07:55 PM   #4
DiESeven's Avatar
http://tire-size-conversion.com/spee...r-calibration/
Old 07-15-2015, 08:09 PM   #5
Its only off by 2 mph
Old 07-15-2015, 08:10 PM   #6
Diehard's Avatar
Yeah but they would also have to know what tire size came standard with your vehicle and/or ask something about if they are original tire size, etc.
Tire size in and by itself doesn't tell the whole story. IMHO
Old 07-15-2015, 08:24 PM   #7
DiESeven's Avatar
You don't need to know what was on the car previously to fix speedo with a tune. The tune is a new file. Knowing what was on the car previously is simply to tell you if you're speedo is accurate or not.
There's a formula to tell you what your speedo should read with whatever gears/tires you have.
The website I linked simply takes that formula for both sizes and tells you the difference.
Old 07-15-2015, 08:36 PM   #8
Diehard's Avatar
Okay, not necessarily to correct it but to make sure it's correct.
I was thinking that there would be no reason to correct it(or fix it) if it had OE size tires. But like you say they would do it anyway to make sure it's correct.
Old 07-22-2015, 04:48 PM   #9
Tyriqq's Avatar
I went from 17" OEM to 18" staggered. I never notice a difference. Never even thought to see about retuning either
Tyriqq is offline   Reply With Quote
Old 07-22-2015, 09:08 PM   #10
Diehard's Avatar
It's the tire size that could make a difference, not the rim size.
Old 07-22-2015, 09:15 PM   #11
Commercial Member
au01st's Avatar
So which tire size should you use if you're running a staggered setup, front or back?
Sent from my #racecar
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 07-22-2015, 09:16 PM   #12
I just adjusted it myself in the tuner. Went to the additional options and then the tire size section, it asks for your revs per mile. Take your tire size and convert it to the overall diameter, that will correlate to a number in revs per mile. Find that number in the tuner and click it.
Old 07-22-2015, 09:17 PM   #13
It's based off of the drive tires....... So rear
Old 07-23-2015, 12:44 AM   #14
Tyriqq's Avatar
I'm not the smartest man, but I'm sure it pretty obvious what I'm talking about without going in to detail. The tires on my SVE Drift(which is a staggered setup) would not fit on my smaller OEM rim. Hence a difference size tire when I can't remember the radial numbers
Old 07-23-2015, 01:56 AM   #15
Abominable Mustang
WhoDat's Avatar
Region: Alaska
But you can go from 17" to 18" wheels without your overall tire diameter changing. That's what he's trying to say. Wheel size means nothing by itself when talking tire diameter and speedo corrections.
2012 Kona Blue 3.7L V6:
Old 07-23-2015, 02:42 AM   #16
Tyriqq's Avatar
So like I said in my OP. I switched to a staggered setup. Just eyeballing you can tell the radius is different in the rear. Like someone asked in this post. So what am I missing
Old 07-23-2015, 07:29 PM   #17
Abominable Mustang
WhoDat's Avatar
Region: Alaska
That everyone else is talking about tire diameter and you're talking about wheel size, which is in fact two separate things. OP changed his rear TIRE size which DOES affect the speedo. You changed WHEEL size which DOESN'T affect the speedo. Your wheel diameter changed but your tire diameter more than likely did not (at least in the rear) which is why you didn't notice a change in your speedo.
Sent from the Death Star.
(AM CAI+TUNE) is tire size important with tune? Vaiit 2005-2010 Mustang GT 9 03-31-2014 10:13 AM
Biggest rear tire size on 18" tire ChrisMustangs Mustang Wheels & Tires 6 06-24-2013 02:46 PM
Bama tune or lund tune or steeda tune Mustang32Bill 2011-2014 Mustang GT 89 11-12-2012 10:45 AM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
10:32 PM
