3.7 Valve woes - Mustang Evolution
Old 07-17-2015, 07:36 PM   #1
Meaningoflife90's Avatar
3.7 Valve woes
First, yes i used the search button
So i have read countless articles, forum posts, and such regarding a valve noise coming from our engines. The problem is explained as a rattle, tap, noise when it cold and eventually goes away when it warms up. Which im sure tha'ts no fun either, but mine does the opposite of that, it becomes louder as it gets warmer, and the best way to describe it is it sounds like a card on a bike wheel but sharper and more metallic.
Its coming from the driver side valve cover,
Its the worst when holding it at around 2-2.3K rpm,
goes away (or is muffled) under a moderate to heavy load.
It does raise and lower with engine speed.
Its LOUD, like it reverberates off of passing cars and walls.
There's so many post on this type of thing i cant even begin to put a solid answer together, just looking for some insight,
Thanks!
Its probably broken...
2012 Mustang V6,
3:73's, Airaid Intake, Dynomax VT Exhaust, Hotchkis Stage 1 kit, Hopes and Dreams injection.
Meaningoflife90 is offline   Reply With Quote
Old 07-17-2015, 07:51 PM   #2
Kevin.Cook
Guest
Posts: n/a
Are you the first owner? Was wondering about oil change history, etc.
Old 07-17-2015, 07:55 PM   #3
No i am the second owner, bought it with 52K on it. So god knows, i switched it over to mobil 1 the day after i bought it and have done it every 4k since and i'm at 62k now.
2012 Mustang V6,
Old 07-17-2015, 07:57 PM   #4
FastFord13's Avatar
Was it a rental? God knows what people do with a rental Mustang. Oh wait yes i do.
Sent from LG G3.
Old 07-17-2015, 07:59 PM   #5
Luckily that is one thing i could be sure of, it wasn't a rental. I actually met the previous owner when i bough it, she was picking up her 2015 GT the same day i picked up mine.
Yeah i was jealous.
2012 Mustang V6,
Old 07-17-2015, 08:07 PM   #6
FastFord13's Avatar
That would bother the hell out of me. I have also read quite a few post on this but most are just told "its normal" from their dealers.
I'm going to watch this thread. Good luck!
Sent from LG G3.
Old 07-17-2015, 08:09 PM   #7
Kevin.Cook
Guest
Posts: n/a
Just cuz it was a woman doesnt mean she didnt dog the hell out of it. If she was getting a GT, then you know she wanted more power. Something tells me she couldnt go fast enough with the v6....
Old 07-17-2015, 08:12 PM   #8
Oh i had a feeling anyone moving from that to a 15 GT was looking for more power. I've seen both sides of the gender spectrum tear the hell out of a car.
None the less, on a scale of 1 to fubar'd..... where does this problem seem to sit, im going to try my dealer tomorrow.
2012 Mustang V6,
Old 07-17-2015, 08:49 PM   #9
Kevin.Cook
Guest
Posts: n/a
Without opening it up, it would be hard to tell. As long as the car runs ok, then you should be fine for now.
Old 07-17-2015, 08:56 PM   #10
If i open it up, (thank go its the drivers side) what am i looking for? A marred cam lobe? Marred follower?
2012 Mustang V6,
Old 07-17-2015, 09:12 PM   #11
Kevin.Cook
Guest
Posts: n/a
Does the car run funny at all?
Old 07-18-2015, 12:08 AM   #12
Kevin.Cook
Guest
Posts: n/a
Also, have any mods? What octane gas do you use? Just collecting info.
Old 07-18-2015, 01:23 AM   #13
pitboss's Avatar
Hydrolic lifters? Not pumping up or not staying pumped up?
2012 Pony Pkg 3.7 convertible, MPT tuned, 4.10's, Dynotech 3.5" DS, Borla Touring axle backs, BBK 73mm TB and ceramic shorties, Whiteline sway bars and UCA/LCA with relocation brackets, BMR adj. PHB and brace, Steeda CAI, CE frame braces, Bilstein shocks, H&R race springs, SS brake lines, full HID, GT 500 gauge pod with gauges and misc. exterior upgrades
pitboss is offline   Reply With Quote
Old 07-18-2015, 08:25 AM   #14
Voltwings's Avatar
If you're really worried do a compression / leak down test. If its a valve issue, you will see it there. The easiest fix may be to just step up to a thicker oil, whats the factory like 5w-20? Throw a 5w-40 in there (i run rotella T6 in ours) and see if it doesnt clear things up.
Old 07-18-2015, 10:17 AM   #15
Thicker oil- You really gotta be kiddig
Mobil-1 5w 20 is what it calls for. You already have good oil in it and just try adding some Chevron Techron to the gas to clean out the injectors. That may or may not solve the problem.
Some of these guys will have people putting sawdust in the rear or crankcase to quiet down a problem like the shady dealers did in the good old days.
Thick oil will be quieter but really not a good option. Rotalla T6 oil for use in a turbo diesel is good for voltwings engine or a truck but I sure as hell would not use it in my Mustang.
Before you do anything, Take a long screwdriver and put it to your ear and to the valve cover to be sure that is where the noise is coming from. They do sell Automotive stethoscopes for this but the long screwdriver works pretty good.
Old 07-18-2015, 10:45 AM   #16
Shadetree43's Avatar
SeaFoam also works wonders on sticky/noisy injectors.
Shadetree43 is offline   Reply With Quote
Old 07-18-2015, 11:12 AM   #17
Kevin- Just your typical intake exhaust, nothing real involved yet, i run 89 most of the time. it does not really run bad at all.
Voltwings, i dont think the vale is not seating correctly i think the cam to valve contact point is the issue
Ronnie, ill go try that trick with the screw driver now.
2012 Mustang V6,
Old 07-18-2015, 12:51 PM   #18
Let us know how it sounds
Listen to both sides and see if the passenger side has the same noise but not as loud.
Old 07-18-2015, 02:31 PM   #19
Voltwings's Avatar
The reason rotella T6 is good in Turbos and diesel engines is because even though it is thick, it easily flows through tiny passages, such as turbo feed and drain, and doesn't break down due to heat. This makes it a fantastic oil for damn near any engine, and i can show you several black stone lab reports to prove that.
There are a lot of parts in these TI-vct engines that rely on oil pressure to operate, hell, the Cams have their own oil pressure regulators. In the summer months when oil is more likely to break down, especially if you're using cheap oil, and the systems are seeing too low of pressure, it can cause an issue. This is specifically why the track pack GT has a 5w-50 spec oil. The 5w-20 is just a thin oil to help the v6 hit it's mpg targets.
Thicker oil would not only be a remedy, but a diagnostic approach as well.
Old 07-18-2015, 02:56 PM   #20
Fintile's Avatar
I'm wondering, why would you buy Mobil 1 and swap it every 4k miles?
Ive heard you could get 2 different weights. 1/2 5w20 the other half 5w40 the heavier oil will help with the preasure while the lighter oil keeps everything going smoothly. Honestly it sounds like a jacked up mess and for me doesnt sound right at all.
Also has anyone used Marvel Mystery Oil before?
Fintile is offline   Reply With Quote
Old 07-18-2015, 03:43 PM   #21
I used some Marvel Mystery oil long ago on a 1990 Ranger crankcase. It caused the cork oil pan gasket to deteriorate and plugged up the oil pump pickup. Had to pull pan, replace gasket & as preventable maint the oil pump.
I don't use it in modern engines today.
14 SGM V6 Prem Vert
CS Upper/Lower Grill | GT Mufflers | JLT Catch Can | PP Engine Cover | Steeda PH Brace | JDM Adj PH bar | AMR 18x9 Dark Stainless -Cont Contact Sport 235-55x18 | Roush Vent Pod/Oil Pressure Gauge | Airaid MIT - aFe Pro S |MMD Hood Struts | Steeda Jacking Rails | Prev Maint Rear Axle Vent tube, Radiator degass tube
Old 07-18-2015, 05:41 PM   #22
[QUOTE=Fintile;2262633]I'm wondering, why would you buy Mobil 1 and swap it every 4k miles?
I like working up into longer intervals, i dont know, i feel more comfortable that way. apparently it did a whole fat lot of good....
Update! now that i really stuck my head in there and had someone hold it at 2k, i sear it sounds like its coming from the front top of the driver valve cover.
2012 Mustang V6,
Old 07-19-2015, 07:26 AM   #23
Jon3.7's Avatar
Sounds like a cam phaser.
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 07-22-2015, 03:02 PM   #24
Fintile's Avatar
You 100% with no doubt that was the cause? I used it in every oil change and every 3 gas fill up on my 2004 Hyundai from 10k miles 170k miles later my brother drove it cross country with me and he has it here in Boston. Ive just never used it in my Mustang. Im guessing i shouldnt. Im just going to stick with the motercraft semi-synth that Ford puts in the car. This is the um-teenth time Ive heard someone having a valve issue, idle issue or just noise period after using an aftermarket full synthetic. Makes me reconsider getting new tranny fluid now.
Old 07-24-2015, 05:38 PM   #25
Well! Got the news today!
Cylinder 5 is coming apart, either at the wrist pin or a rod bearing, it goes away when you deactivate the cylinder and there is metal in the oil.
yee
freaking
haw
2012 Mustang V6,
Old 07-24-2015, 05:53 PM   #26
Kevin.Cook
Guest
Posts: n/a
Holy s*** i didnt even know this happened on our cars. Guess "built ford tough" is out of the question...
Old 07-24-2015, 05:55 PM   #27
Did you buy your 2012 brand new ??????
How many miles on it now????
I hate to hear your bad news and hope it does not cost you way to much to fix.
Old 07-25-2015, 11:25 AM   #28
69k Miles on it is all.
Yeah ford told me 7000 for a long block, i think ill risk a used on at this point.
2012 Mustang V6,
Old 07-25-2015, 11:33 AM   #29
Voltwings's Avatar
Hit up Alrefire, i feel like dude just has them laying around at this point
Old 07-25-2015, 06:42 PM   #30
Jon3.7's Avatar
Call ford up directly and ***** at them. They will work with you.
Old 07-26-2015, 08:03 AM   #31
alrefire's Avatar
Lmao
No, I only have 2 motors.
You can find a decent used one for pretty cheap.
Just be careful with picking one, my spare motor has an oil leak. It's coming out in a month or so, so I'm not too concerned with taking it apart to fix it now.
If I purchased from lkq, it'd be covered under their 6 Month warranty... but..... I'm cheap lol
Old 07-26-2015, 10:39 AM   #32
Fintile's Avatar
Thats just their trucks. With their cars (the Mustang in particular) it's "FORD BUILT TOO MANY" constant mass production and "half 'ed" quality standards is why we have these issues. youd never see this in a Toyota or hell not even the Genesis Coupes have seen as many issues as our V6. I think this is a sign for you to do a 5.0 or go all out with a GT500 crate swap!
7000 will get you a working used 5.0 with harness. trans is another 2-3k depending where you find it... I could be wrong though.
I gotta say considering the issue with the amount of time you have had this issue and Im sure youve driven the car hard a couple times tells me its still has a pretty solid build.
Old 07-26-2015, 11:41 AM   #33
Hi Meaningoflife90
I know I asked before if you bought the Mustang "BRAND NEW"
I'll ask again because you never said.
Old 07-26-2015, 01:25 PM   #34
iguanaman3's Avatar
He answered that in the 3rd post. He bought it used with 52,000 miles on it.
iguanaman3 is offline   Reply With Quote
Old 07-26-2015, 04:42 PM   #35
Thanks iguanaman3
I sure don't know how I missed that but I did.
I'm wondering if the person that had it before used crap oil or maybe did not change it at all. It is rare for the 3,7 V6 to have any problems. They have been using that engine in trucks with zero problems.
69,000 miles is not a lot on a late model car of any brand.
Suspension woes charkelly9 Pre-2005 V6 Mustang 9 07-22-2008 06:56 AM
'07 Pony "earl" woes greaser Pre-2005 V6 Mustang 16 09-24-2006 08:42 PM
charging system woes Thomas91169 Mustang Audio & Video 15 08-12-2006 12:34 AM
college woes jimmy_beaner The Bar 27 10-31-2004 10:55 PM
window woes el cheapo Mustang Audio & Video 13 10-06-2003 11:59 AM
11:44 PM
