Coolant leak thermostat housing - Mustang Evolution
Old 07-18-2015, 09:49 AM   #1
Region: Hawaii
Unhappy Coolant leak thermostat housing
Alright guys any help would be appreciated.I noticed my coolant reservoir keep getting low after a month or 2.So I took it to the dealership and they did pressure test and couldnt find any leaks.6 months later I notice dried coolant under my thermostat housing weephole.Should I change the waterpump or thermostat housing? My car never overheats just engine rpms dip when my ac is on.Click image for larger version
ID:	187409Click image for larger version
cardelljones23 is offline   Reply With Quote
Old 07-18-2015, 10:57 AM   #2
Diehard's Avatar
No easy answer.
Try to determine the exact source of the leak. At the leak rate you're talking about you may have a little time before having to fix it.
If the leak appears to be originating from the pump weep hole(s) it could very well be an impending failure.
The following was copied from an article off the web, FYI.
Does a drip from the weep hole mean seal or pump failure?
Perhaps. Seals will drip as the seal lap in but to understand a more prolonged or intermittent “drip” you have to understand a seal’s design. Seals purposefully drip because capillary action draws fluid from the seal face. As the seal drips, it helps wash loose debris out and reduce the heat load. Most drips evaporate or fall on the road and are not noticed.
Naturally, a more pronounced drip indicates a compromised seal and impending bearing failure.
There are a lot of post already on this subject. You should look at them and get familiar with the common problems people are having with water pumps.
Old 07-18-2015, 12:45 PM   #3
pitboss's Avatar
My water pump started leaking at 29,000 mi. For no reason. Dealer pressure checked and replaced under warranty
2012 Pony Pkg 3.7 convertible, MPT tuned, 4.10's, Dynotech 3.5" DS, Borla Touring axle backs, BBK 73mm TB and ceramic shorties, Whiteline sway bars and UCA/LCA with relocation brackets, BMR adj. PHB and brace, Steeda CAI, CE frame braces, Bilstein shocks, H&R race springs, SS brake lines, full HID, GT 500 gauge pod with gauges and misc. exterior upgrades
pitboss is offline   Reply With Quote
Old 07-19-2015, 07:57 AM   #4
espndon's Avatar
My 2012 v6 stang water pump leaked and started getting hot a month after I bought it , took to dealer and was fully covered and replaced under warranty. Something to do with return valve in coolant bottle.
2012 Mustang
In Haines City. Fl.
espndon is offline   Reply With Quote
Thermostat Housing Leak Texas22 2005-2010 V6 Mustang 27 10-05-2014 12:03 PM
Thermostat Housing Leak Texas22 2005-2010 V6 Mustang 1 09-22-2014 08:31 PM
Thermostat housing leaking. Please Help! dmax8709 1996-2004 Mustang GT 0 02-06-2012 07:17 PM
Thermostat Housing Tj88mustang 1979-1995 Mustang GT 8 11-27-2011 09:38 PM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 12:00 PM
11:50 PM
