Tires - Mustang Evolution
Old 07-21-2015, 10:27 AM   #1
Gumbus's Avatar
Tires
Guys, what are the downsides of running staggered tires on my daily driven mustang? For instance, 255 on the front and 285 on the back. Thanks
2013 mustang v6 premium
Gumbus is offline   Reply With Quote
Old 07-21-2015, 10:28 AM   #2
Kevin.Cook
Guest
Posts: n/a
Only real bad side is you cannot rotate them.
Old 07-21-2015, 10:29 AM   #3
Agreed with Kevin. Mines the same now 255 and 275 but I'll be running 285 when I replace rear tires.
2010 Grabber Blue GT
1999 Contour ES
IG = @silverskoundrel
Old 07-21-2015, 10:31 AM   #4
Gumbus's Avatar
So I'm guessing with staggered tires Ill just have to replace the rear before I replace the fronts?
Old 07-21-2015, 10:31 AM   #5
Socal Stangman's Avatar
The looks out weigh any negatives. I run a 295 in the rear and it looks nice.
Old 07-21-2015, 10:32 AM   #6
Kevin.Cook
Guest
Posts: n/a
Correct. Especially if you are gonna race them.
Old 07-21-2015, 10:34 AM   #7
How wide a rear wheel ?
1999 Contour ES
Old 07-21-2015, 10:37 AM   #8
Gumbus's Avatar
I'm more than likely not going to race it's just the used set I'm looking at is coming staggered
Old 07-21-2015, 10:39 AM   #9
Kevin.Cook
Guest
Posts: n/a
The most you can do with them is swap the sides they are on. But not front to back and vice versa. If you drive normal, you can get pretty good miles out of them.
Old 07-21-2015, 10:41 AM   #10
Tires
Not if they're one directional lol unless you have em broken down every rotation I feel like my nittos are one directional.
1999 Contour ES
Old 07-21-2015, 10:50 AM   #11
Kevin.Cook
Guest
Posts: n/a
True! My goodyear f1s are good for either side though. so if it something like those, he should be ok.
Old 07-21-2015, 10:52 AM   #12
Luckyyyy
1999 Contour ES
Old 07-21-2015, 10:54 AM   #13
Kevin.Cook
Guest
Posts: n/a
they aren't the worst. Ford actually offered decent tires on my car. lol. Goodyear F1 Supercar tires - 255/40/19s on a 19x8.5 rim. Tires have 220 tread wear.
Old 07-21-2015, 10:56 AM   #14
I don't even remember whAt came stock on my 18x8s. I traded them for 18x9.5s with staggered nittos
1999 Contour ES
Old 07-21-2015, 11:04 AM   #15
Kevin.Cook
Guest
Posts: n/a
I know the new 15 5.0s on the PP they got a pretty good setup. They are staggered with 19x9 in the front and 19.9.5 in the back. I think the front is 255 and the back is 275. Ford is finally stepping it up.
Old 07-21-2015, 11:04 AM   #16
Tires
Took long enough to start figuring it out
1999 Contour ES
Old 07-21-2015, 12:38 PM   #17
Voltwings's Avatar
1999 Contour ES
What are they? Some say Left / Right and they need to be on the dirver side or passenger side respectively, and some say inside / outside, and that just denotes mounting on the rim, and they can be put at any corner.
Old 07-21-2015, 02:44 PM   #18
I'd have to look when I get home to be sure
1999 Contour ES
Old 07-21-2015, 03:02 PM   #19
1999 Contour ES
10.5"
Old 07-21-2015, 03:14 PM   #20
10.5"
Nice mine are only 9.5
1999 Contour ES
Will 205/75-14 tires fit 14x7 wheels? will 225/45-17 tires fit 16x8 wheels? baudier Classic Mustangs 4 03-29-2016 08:25 PM
Tires Tires!!! Nathan69 2005-2010 Mustang GT 17 01-04-2011 01:43 PM
I need tires and rims for my 1990 Mustang. But I want the tires to be shipped ON the rims.? nahcomence Mustang Wheels & Tires 5 04-02-2010 01:06 AM
cobras/tires for welds/tires, $$$? tire The Bar 2 02-22-2004 11:11 AM
07:47 AM
