JLT Oil Separator - Mustang Evolution
Old 07-22-2015, 05:07 PM   #1
Hampton CIT's Avatar
JLT Oil Separator
JLT Oil Separator - Of all things to have a problem with. Just got my order in today. The unit fits great except the only way it fits is by plugging the tube that is labeled intake with an arrow into the block and the other end into the intake. Looking at pictures online, everyone else has it installed backwards too. Opening up the can, you can see the screen only is on the "intake" side so putting it in backwards so it would fit defeats the purpose. Gotta be a simple solution.
Signed embarrassed and confused,
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 07-22-2015, 05:25 PM   #2
Some pictures may help. Here is the unit installed backwards and the close up you can clearly see the arrow pointing and saying intake. The last picture is with the can off. It seems logical that the screen would be on the tube going out to the intake to screen off anything from the can going out; not screening everything going into the can. Logic and labels coincide here. You can't swap the tubes either as one has a deeper thread that closes off a port. Any thoughts anyone?
ID:	187807   Click image for larger version
Old 07-22-2015, 05:28 PM   #3
Kevin.Cook
Guest
Posts: n/a
Here is mine. Tubing was stiff but it fit.
ID:	187810   Click image for larger version
Old 07-22-2015, 05:49 PM   #4
Same thing. In your pic, see the arrow pointing and labeled intake? If one side wasn't actually connected to the intake, I'd think nothing of it. JLT happens to be half an hour away but I'll call them in the am. It's the little things like this that drive me nuts.
Old 07-22-2015, 05:53 PM   #5
Kevin.Cook
Guest
Posts: n/a
S'all good man.
Old 07-22-2015, 06:12 PM   #6
Kevin.Cook
Guest
Posts: n/a
You copying my car? lol
Old 07-22-2015, 06:29 PM   #7
I'm trying to improve my image my friend.
Old 07-22-2015, 06:37 PM   #8
Kevin.Cook
Guest
Posts: n/a
Ahh so you think you can out-do me? Challenge accepted.
Old 07-22-2015, 06:41 PM   #9
The challenge is my 2.73 gears vs your 3.73 gears in mpg then!
Old 07-22-2015, 06:43 PM   #10
Kevin.Cook
Guest
Posts: n/a
I lost before that challenge even started! I can see my gas needle drop as I drive. LOL. I get like 19 avg MPG combined city and highway.
Old 07-22-2015, 07:43 PM   #11
JimC's Avatar
The tube is from a different car, and is cut for the can. The arrow is meaningless, it's just a hollow tube. It only means something on the engine it was designed for because that is how it fits that engine.
You have it installed correctly. The logo reads in the correct orientation standing on the passenger side of the engine bay.
JimC is offline   Reply With Quote
Old 07-22-2015, 09:25 PM   #12
Shadetree43's Avatar
Just installed one three weeks ago. I questioned it too, but since it fit so well the way it did. I just figured some one stuck the label on the wrong end of the hose.
Shadetree43 is offline   Reply With Quote
Old 07-23-2015, 02:11 AM   #13
I contimplated that as well but at over 100 clams, I'd think they would pull off a confusing sticker. That almost has a craft shop / Lowes jury rig feel if that's the case. Will call or go by there this afternoon to solve the mystery.
Old 07-23-2015, 02:26 AM   #14
bucko's Avatar
Paying that much for a part that is being "questioned" by its purchasers should be corrected. Poor attention to detail IMO.
Old 07-23-2015, 06:05 AM   #15
The only thing I've ever really questioned about the JLT is that the filter is on the incoming side, instead of the exit side. It catches and pulls out the liquid vapors either way, but as the can gets full (more a winter issue with more moisture added in) with the screen on the incoming vs exit it allows the exit to also potentially suck the contents out of the can.
That's one of the huge advantages of the bob's can, everything enters lower in the can below the screens and exits out the top back to the intake.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 07-23-2015, 11:46 AM   #16
Exactly my thoughts too on the screen Marius, Hence my remark, logic and labels match. Just hung up with JLT. The hose with the sticker is OEM off a GT like JimC said. JLT orders OEM parts, puts the unit together but do not remove the sticker. When I pointed out the obvious about the label and arrow, I could hear the light bulb flash on. They said, oh yeah, that's worth looking into. smh
JLT Oil Separator GrabberBlue5.0 2011-2014 Mustang GT 55 12-23-2015 10:35 AM
Jlt vs Moroso oil separator OzzyLiriano 2011-2014 Mustang GT 39 10-29-2013 02:07 PM
JLT Oil Separator for Blown 5.0 poloka 2011-2014 Mustang GT 5 02-15-2013 02:47 PM
JLT Oil Separator 08Mustang 2005-2010 V6 Mustang 16 06-30-2012 07:56 AM
JLT oil separator Mustangpower5.0 2011-2014 Mustang GT 13 05-18-2012 10:32 PM
06:05 PM
