Please support our sponsors and let them know you heard about them here! |
07-23-2015, 09:56 AM
#1
GT grill
Besides the gt grille and fog lights, what all is needed get the gt grill setup on my v6. I want to put some halo fogs on there
2013 mustang v6 premium
07-23-2015, 11:52 AM
#2
Probably a wiring harness for the fog lights
2014 GT. Oxford White.
20" Velgen VMB5s on NT555s.
MBRP Race Series Catback Exhaust
Bama 93 Performance Tune
07-23-2015, 12:12 PM
#3
Starkey makes a refurb kit with everything. I would recommend it. That's what I had on my old v6. It has everything from the switch to the bottom grille
Sent from my SM-N910V using Mustang Evolution mobile app
07-23-2015, 12:27 PM
#4
Thanks I'll look into that
07-23-2015, 12:32 PM
#5
Is $190 the cheapest you can get all that?
07-23-2015, 12:34 PM
#6
Guest
Well how cheap do you want it to be man? lol. Don't go too cheap, or you will regret it.
07-23-2015, 12:49 PM
#7
Yeah Kevin you're right lol. That's really not even that much considering I'm trading my stock grill for a gt one
07-23-2015, 12:52 PM
#8
Guest
See, the build is already underway. Just go with it, even if it means not saving a couple of bucks.
07-23-2015, 12:53 PM
#9
So I attach one end of the harness to the fogs and the other to the switch? What else needs connecting?
07-23-2015, 03:17 PM
#10
You'll have to tap into the switch, fusebox, and power.
07-23-2015, 03:21 PM
#11
How difficult is that?
07-23-2015, 03:26 PM
#12
It was super easy with the harness Starkey supplied. It was all to length and had splice connectors with it. However, if you're doing your own harness, it might be slightly different.
07-23-2015, 03:27 PM
#13
Okay I guess I'll just go with starkey's harnesses to make everything easier
07-23-2015, 03:28 PM
#14
^ All depends on your wiring skills. Took me less than an hour. You actually replace your switch. You have to splice into your fuse box on one end and your switch harness on the other. The Starkey harness is OEM quality and looks like factory when you're done. The instructions are very clear. Give it a shot.
Frank
1989 Blue LX Hatchback
2001 Red SVT Cobra Convertible (Phoenix)
2002 Black/Red GT (Ginger)
2011 Red Candy Metallic V6 (Manfred)
2016 Magnetic Metallic GT (Susie II)
#15
It was definitely worth it, even though it was a little more pricey.
07-23-2015, 03:29 PM
#16
Well I have less than no skills on wiring but I'll try. I can always have someone help me out
07-23-2015, 03:31 PM
#17
Which bulb connector option on the starkey website to I pick? There are three options
07-23-2015, 03:44 PM
#18
I'm going to have to remove the bumper for this right?
07-23-2015, 03:55 PM
#19
I am very new to this and I did the same conversion plus added lower valance fogs also. It took me 3-4 hrs in my garage to complete the whole process. You will have to buy 2 harnesses. one is the kit for lower valance fog second one is the extension from lower to Grille fogs. Yes to install Fogs u will need to remove the front bumper (Not that hard). There are videos on youtube you can follow. Pretty straight forward.
AirAidCIA | BAMA 87P Tune | BoralAtak AB| BMRAdj UCA | BMR UCA Mnt | BMRAdj PHB | GCCoilOvers | DSS 1 Piece AL Driveshaft | BMRLCA | BMR LCA Reloc Brackets | BARTONShifter | GT CS Spoiler| RedLine Hood struts | MMD Axim 20X8.5 Audio: Dynamatted Rear & Doors | AudioControl LC8i | Speakers: Infinity 682.9cf | RockFord Prime R250X4 Amp | Rockford Prime 500.1 Mono AMP | Kicker Twin10" L5 Solo Barics in a Ported BOX | P.S MORE TO COMEEEEE!!!!
07-23-2015, 04:59 PM
#21
It's gives you the option under there for bulb connectors for a pony package lower valence fogs, roush fogs, and something else i don't know
07-23-2015, 05:07 PM
#23
That all seems to be adding up to be expensive, they discontinued the kits because of the 13-14s not being in production anymore. I think I paid $400 for all the wiring, connectors, switch, fogs, upper and lower grille refurb. It seems as though you're looking at $300 for just wiring, switches, and connectors.
07-23-2015, 05:19 PM
#24
So are you advising I not do this?
07-23-2015, 05:23 PM
#25
It's however much you want to spend. If you can get grilles and fogs for cheap, I'd go for it. I loved mine.
07-23-2015, 05:24 PM
#26
Do have halos? I want to do this Bc a guy wants to trade grilles Bc his gt one won't fit something for his supercharger. So I figured this would be an easier and cheaper way to get some halos
07-23-2015, 05:32 PM
#27
Did you go with the starkey kit?
---------- Post added at 11:32 PM ---------- Previous post was at 11:32 PM ----------
And btw I see you're from Alabama. Right on brother
07-23-2015, 05:36 PM
#28
No I didn't have halos, I planned on getting them from AM but I totaled my v6....and yes, I used a refurb kit from Starkey.
---------- Post added at 11:36 PM ---------- Previous post was at 11:35 PM ----------
Just tell him to give you the supercharger😂😂
07-23-2015, 06:26 PM
#29
Region: Nevada
[QUOTE=andrewheath09;2265129]It was super easy with the harness Starkey supplied. It was all to length and had splice connectors with it. However, if you're doing your own harness, it might be slightly different.
I did this as well. As stated it is super easy and videos available on youtube. Took only a couple of hours. The Starkey switch also provides the option to have automatic head lights.
07-23-2015, 06:29 PM
#30
Are those just regular gt fogs? And how easy is it to switch the grills?
07-23-2015, 06:35 PM
#31
Region: Nevada
Regular gt fogs. The switch was just as easy. Forgot to mention the switch also allows you to use high beams and fog lights simultaneously.
07-24-2015, 07:38 AM
#32
If i was doing this i would get the foglights, grille and make my own wire kit. I dont really think there is a need to pay 190$ for factory switch thing. Just get a regular heavy duty two way flip switch from autozone or oreilly. Get a long good quality piece of wire that you can pull through the cabin to the fog lights. Connect the negative wire of the both the fog lights to the metal on your car. Get a fuse tapper and tap into fuse box from passenger side maybe fuse 7 or 8. Connect one positive wire to the switch and the output wire from the switch to both of the foglights positive wire. Place the switch somewhere thats convenient to you and you are done with the installation. All the wiring connections would take you about an hour and you'll be done within 25$ i suppose.
07-24-2015, 08:47 AM
#33
I think I would still get the factory switch because I've seen it on Amazon for like $15. Could I do that and then make my own wiring assembly?
07-24-2015, 11:33 AM
#34
I havent seen the stock fog light switch pins so really cant help you there. I'll try to look for their wiring diagram if i can find it, i might be able to help you there. I would think there should be one extra pin for positive output from the switch for foglight but to figure out which pin is for the fogs, you would need to get a diagram or do trial an error method. TBH i cant confirm this until i see the switch pins or have a wiring diagram.
07-24-2015, 11:35 AM
#35
Your V6 does not have factory bumper fog lights, correct?
Thread Tools |
Search this Thread |
