Spring compressor for strut/shock spring installation - Mustang Evolution
Old 07-23-2015, 05:00 PM   #1
Will this internal coil spring compressor work?
I like the idea and it is currently on sale.
Sears.com
liv4spd is offline   Reply With Quote
Old 07-23-2015, 05:02 PM   #2
Socal Stangman's Avatar
No because the front strut will be in the center.
Old 07-23-2015, 06:34 PM   #3
DiESeven's Avatar
Used one similar to this when we did my springs.
http://m.harborfreight.com/macpherso...not%20provided
Old 07-23-2015, 07:03 PM   #4
Thank you for pointing that out!
MacPherson Strut Spring Compressor Set
Thank you for the suggestions. That's a good price.
Old 07-23-2015, 07:14 PM   #5
Hampton CIT's Avatar
You're not the only one Liv. I rented one from AdvanceAuto when I did my springs. The counter guy insisted the inner coil compressor would work... I think he was the stock boy covering while the real guy was in the bathroom. I picked up a cheap compressor like the one shown above. Advice: if you don't have a compressor, borrow one and go buy a 1/2 pneumatic impact gun (they are like $40). It will save you MAJOR time and suffering in tightening and loosening the compressors.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 07-23-2015, 07:30 PM   #6
Voltwings's Avatar
Also, grab the spring as high up, and as low down as you can. These springs are massive, I was literally almost grounding my compressor out before I was able to get the spring off.
Old 07-23-2015, 07:42 PM   #7
Excellent suggestion. Rent compressor + buy a cheap air gun.
Thanks for the tip. It's good to know this before hand.
Old 07-23-2015, 07:57 PM   #8
Diehard's Avatar
What do you think of the alternate method of decompressing the front spring before removing it from the car? As shown in this video starting at about 50 sec.
Looks like he has to push the control arm and rotor down more and seems to put some strain on the brake hose.
Old 07-23-2015, 08:55 PM   #9
That's really cool. You don't need a spring compressor in this method.
Looks like he has to push the control arm and rotor down more and seems to put some strain on the break hose.
Old 07-23-2015, 11:21 PM   #10
I didn't use a spring compressor when I did mine. I just set the assembly in the grass and stood over it as I used my impact gun to remove the nut. It just pops off. As long as your face isn't over it your fine. I put it in the grass so it really couldn't go anywhere, and it didn't.
Lowering Spring Installation - No Spring Compressor?? Mean14 2011-2014 V6 Mustang 12 05-22-2015 12:48 AM
Installing Cams on 4.6 with no spring compressor? Joe Dirt 222 2005-2010 Mustang GT 4 03-30-2015 08:53 PM
coil spring compressor needed to install eibach springs? rwheels 2011-2014 Mustang GT 6 01-11-2014 11:59 AM
Spring compressor help? iStang65 Classic Mustangs 5 01-24-2013 05:48 AM
whats the best shock strut? powerhungry966 Pre-2005 V6 Mustang 7 04-09-2006 12:48 AM
11:47 PM
