Gears - Mustang Evolution
Old 07-23-2015, 11:23 PM   #1
roushMarlon831's Avatar
Send a message via Yahoo to roushMarlon831
Gears
Will v8 3.73's fit into a V6??
roushMarlon831 is offline   Reply With Quote
Old 07-23-2015, 11:30 PM   #2
Need an answer ASAP
Old 07-24-2015, 06:07 AM   #3
Kevin.Cook
Guest
Posts: n/a
As long as it is 8.8
Old 07-24-2015, 06:32 AM   #4
Thanks Kevin, Yea it Is an 8.8. Would I need to buy the kit on AM in order to install them? The gears I'm getting my buddy had them on his coyote for 1000 miles. And he's selling them now
Old 07-24-2015, 06:34 AM   #5
Kevin.Cook
Guest
Posts: n/a
You will want the Ford Racing install kit. Not Motive. Because you will need the bearings, shims, gasket, marking compound, etc.
Old 07-24-2015, 07:19 AM   #6
Personally I wouldn't put used gears into my car, but its your call. Used gears are almost impossible to make silent. They are likely to whine or make noise because they have an established wear pattern from the previous axle setup, and since no 2 axles are exactly alike they will be setup slightly different. If you get them, I would expect to hear some gear noise.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 07-24-2015, 09:25 AM   #7
I might as well just get new gears and the gear kit. I don't want no noise or having to spend the money I would just buying them new
Old 07-24-2015, 01:33 PM   #8
Voltwings's Avatar
I've also seen two sets of used gears where the pinion was severely damaged upon removal (its difficult not to damage them due to the removal process). I would buy new, this is not a job you want to have done multiple times.
Old 07-24-2015, 03:17 PM   #9
Region: Nevada
I would get new gears as well. Most of the expense is the labor. Most places will also not offer guarantee when installing used parts. Also as stated, get Ford not Motive install kit. You'll love how the gears will wake up your ride!
Jenkins is offline   Reply With Quote
Old 07-24-2015, 06:45 PM   #10
Thanks for the advice guys. Yea I'm just going to get some new ones instead
Old 07-24-2015, 06:57 PM   #11
Hawkstang's Avatar
Region: Iowa
OP... If you don't mind, please let us know what your 0-60 time is after the install as well as your MPG (and RPM) at 75 mph, if possible.
I'm on the fence as to re-gearing or not and your feedback would be appreciated.
Post #1 in the bag!
Hawkstang is offline   Reply With Quote
Old 07-24-2015, 07:04 PM   #12
I'm planning to hit the track late August and I'll let you know my times there. I won't be going with 3.73's tho I'm going for 4.10's
Old 07-24-2015, 07:29 PM   #13
Hawkstang's Avatar
Region: Iowa
Even better yet... your acceleration should be maxed out. Can't wait to see the results!
My guess from what I have read would be around a 4.3 time, which would be crazy fast for a v6 and well worth a slight drop in fuel efficiency IMO.
Old 07-24-2015, 07:39 PM   #14
4.3 time drop? Or 4.3 0-60 lol? Cause if it drops 4 seconds from 1/4 mile that would be amazing haha
Old 07-24-2015, 07:56 PM   #15
Hawkstang's Avatar
Region: Iowa
Ha, no I meant a 4.3 0-60. With that gear setup and (assuming) a good custom tune, I think the v6 has the ability to bring that in.
I've only owned mine for 3 months and I love it, but am disappointed that Ford decided to give it a grandpa setup with fuel efficiency as it's priority. I understand it from a marketing standpoint, but our v6 has soooo much restricted potential. The good news is I've never owned a car that was so easy to mod/upgrade... if I only had more scratch.
Old 07-24-2015, 08:06 PM   #16
Black8thElement's Avatar
One of these days ill get my 4.30s installed
Black 08GT "Spinning Ain't Winning"
Black8thElement is offline   Reply With Quote
Old 07-24-2015, 08:16 PM   #17
That's a little much don't you think? Then again my dad had a buddy with a Camaro that had 5.13s in the back. It was a 4 speed. He always said, it wasn't very fast but it sure got there quick.
Pick your poison.
Old 07-24-2015, 08:35 PM   #18
Lol...kinda what im shooting for i barely get to hit top end so its not that important for my preference
Old 07-25-2015, 10:15 AM   #19
Voltwings's Avatar
auto or standard? I'd also like to point out the irony of this ^^ being in your sig, while discussing 4.30 gears ...
Old 07-25-2015, 10:26 AM   #20
Rapinator126's Avatar
All about suspension and tire choice. If I was 100% motor and no nitrous I would have gone with 4.30's or 4.56's vs 4.10
Old 07-25-2015, 11:16 AM   #21
Voltwings's Avatar
And for the sake of legitimate discussion here, not being snarky, you really think a 4.56 is a good gear for the coyote motor?
In my mind there comes a point of diminishing returns, especially since the coyote doesn't exactly have an anemic power band to begin with? The v6 lacks some oomph, sure, but its power band is very similar to that of the 5.0, just 100 hp down obviously. I feel there just comes a point where there is too much gear.
Old 07-25-2015, 11:21 AM   #22
Yes I do JPC ran 9's NA with a 4.88 rear gear.
If your car is setup for it then yes.
Old 07-25-2015, 11:23 AM   #23
Meaningoflife90's Avatar
I did the 3.73's and if you street this thing at all, just go with those, they open it up plenty, and you not screaming down the highway at 70. The 4.10 looks fun and all but i know if i would have put anything shorter in mine it would have been a mistake, i still manage 24 mpg on the highway.
First gear with a 3:73 is already short enough, anymore and first will be useless and your going to spend the entire time shifting if your racing someone.
Its probably broken...
2012 Mustang V6,
3:73's, Airaid Intake, Dynomax VT Exhaust, Hotchkis Stage 1 kit, Hopes and Dreams injection.
Meaningoflife90 is offline   Reply With Quote
Old 07-25-2015, 11:26 AM   #24
I can still use my first gear. And 2nd on the bottle so................................. yeah
Old 07-25-2015, 02:09 PM   #25
Auto...i plan on having better tires before i have them installed
Old 07-25-2015, 06:00 PM   #26
So if I go with 4.10's Ima waste more time shifting that actually racing? That's what I want gears for to be honest. To race.
Difference between 2.3 rear axle gears and 5.0 rear axle gears 93mstnglx 2.3 Mustang 9 07-07-2013 05:12 PM
4:10 gears vs 4:30 gears SwatKatz901 1996-2004 Mustang GT 5 03-24-2012 03:17 PM
3:55 Gears vs 3:73 gears 06Blue 2005-2010 Mustang GT 19 01-04-2012 06:57 PM
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 10:57 AM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 04:02 AM
11:56 PM
