Need help loosening the front spring nut - Mustang Evolution
Old 07-27-2015, 11:24 AM   #1
I am stuck when trying to replace the front springs of my Mustang. I can not loosen the front strut top nut. Anyone has a good solution?
I tried to bring it to a mechanic and that guy wanted $75 to loosening the nut
Thank you.
2014 Mustang 3.7L cyclone engine with 6 spd transmission. Mods: 93 MPT Race Tune, 3.31 Gears, Airaid CAI, BBK Shorty Ceramic Headers, Corsa Sport axle backs, Strut Tower Brace, Steeda rear seat X-brace, BMR Rear LCAs, GT wheels, MGW race spec shifter, Passenger seat delete, spare tire delete, Moroso battery relocation to the trunk.
liv4spd is offline   Reply With Quote
Old 07-27-2015, 11:27 AM   #2
oxford5pointoh's Avatar
You need a pneumatic impact to blast it off. Otherwise the shaft spins. You can try to put a wrench on the top of the shaft above the nut but that's a pain in the butt.
It also goes without saying to make sure you have removed all spring tension before you do this.
๐Ÿ‡บ๐Ÿ‡ธVote Ox for July MOTM!๐Ÿ‡บ๐Ÿ‡ธ
IG @Oxford5pointoh
Old 07-27-2015, 11:33 AM   #3
Thank you.
Are you familiar with using a pneumatic gun?
I bought a 1/2 impact gun and have a small compressor with 100 psi. The gun seems to have no power.
IG @Oxford5pointoh
Old 07-27-2015, 11:45 AM   #4
Originally Posted by liv4spd View Post
Thank you.
Yes, I have done 4 of these in the last few weeks for friends.
If your gun is weak, make sure it's oiled.
If it's still sucks it's probably time to replace it.
The air pressure obviously plays a part in it but most impacts are 90 psi max. As long as the compressor is allowing 90 to the gun you should be in good shape.
IG @Oxford5pointoh
Old 07-27-2015, 11:51 AM   #5
Thank you very much!
The gun is brand new. Do I need to oil it before the first use? May I use regular engine oil?
Sorry for the silly questions. My first time to touch an pneumatic gun.
IG @Oxford5pointoh
Old 07-27-2015, 11:58 AM   #6
You def should have oiled it new and every time you use it. They sell air tool oil at hardware stores like lowes or homedepot but you can get it anywhere you can buy the tools usually. I would imagine any oil will be better than no oil but I don't know what weight the actual tool needs. Might just want to make a trip to the store. Hopefully you didn't damage the tool already by not oiling it. If you bought it at a store I would exchange it and tell them it's defective and get another (not at the same time you buy the oil though ๐Ÿ˜Ž).
Hope that works for you
IG @Oxford5pointoh
Old 07-27-2015, 12:04 PM   #7
Voltwings's Avatar
loosen the spring compressor to put some tension back on the top hat. Sometimes that is enough to get that bolt loose, just obviously don't take it all the way off until you compress the spring again.
Old 07-27-2015, 01:36 PM   #8
Thank you, guys.
To make things worse, now the strut mount plate is in two pieces. I can see the bearing steel beads with lube. Is it still reusable?
Old 07-27-2015, 01:40 PM   #9
Socal Stangman's Avatar
Thank you, guys.
I dont think so. I dont think it should ever be in 2 pieces.
Old 07-27-2015, 01:43 PM   #10
Weird engouth. I don't remember giving it any force. It just came off as two pieces.
Will this be an upgrade of this?
Ford Racing Mustang GT500 Style Strut Mount Upgrade M-18183-C (05-14 All) - Free Shipping
Old 07-27-2015, 01:45 PM   #11
Yeah the GT 500 mounts are a really good upgrade...however you have to have struts from an 05-10 Mustang
Old 07-27-2015, 01:45 PM   #12
Voltwings's Avatar
It is reusable, but this is assuming you didn't lose all the ball bearings. The top hats arent exactly pressed together, and it is possible for them to separate. Just carefully place the ball bearings back in place, make sure no dirt or crap is in the grease, and reassemble.
Old 07-27-2015, 02:16 PM   #13
Diehard's Avatar
As far as getting your air operated air impact wrench to function properly you need to provide it with the specified volume (CFM) at the specified minimum pressure. Not just the pressure.
Old 07-27-2015, 02:17 PM   #14
I guess that's probably the reason.
Thanks.
Old 07-27-2015, 08:30 PM   #15
Big thanks! You saved my day. I was able to put everything back together.
Yes, it is very much reusable.
Old 07-27-2015, 11:05 PM   #16
When I did the same thing last year to my previous Mustang, like you, I didn't expect the strut mounts to separate into two pieces. I ended up losing a bunch of ball bearings and had to buy new two-piece strut mounts. When I start working on the suspension for my current car, I'm going strait to the GT500 strut mounts and 05-10 struts, it's best to do that and not bother taking apart the factory 11-14 strut assembly even though my car already has lowering springs. I want different springs anyways as I think the Roush springs the previous owner installed are a little two soft.
Josh_101 is offline   Reply With Quote
Does the standard GT strut tower brace need improving/replacing? Guard 5.0 2015 Mustang GT 9 07-25-2015 02:37 PM
Quick question about replacing front wheel bearing and hub Mfore33 Mustang DIY and Technical 4 09-26-2014 03:54 PM
I need help replacing my fuel pump relay in my 1986 Mustang LX? ashbbie 1979-1995 Mustang GT 2 12-15-2011 05:50 PM
92 Mustang replacing front cailpers CreationNation 1979-1995 Mustang GT 9 04-18-2009 07:37 PM
Need help replacing thermostat floridamba Pre-2005 V6 Mustang 1 04-01-2007 06:30 PM
12:03 PM
