Manual Mustang V6 not going into 1st from neutral. - Mustang Evolution
Old 08-02-2015, 11:21 AM   #1
Hello fellow mustang drivers, my name is Felipe and I bought my 2011 mustang used from Carmax about 14 months ago, it was only previously owned by one driver. The past few months, I have been having trouble with shifting into first gear from neutral. At first, it was just a tight fit, but now, it seems like its blocked. In order to enter the gear, I either have to press the clutch, an press the shifter to the left a couple of times until the gear slips into first. Or I have to slip it into 2nd gear and then into first. I recently got my clutch and flywheel replaced about a month ago, but the problem has been happening before the replacement. Everything else is stock except for a Airaid intake. Any advice would be greatly appreciated. Thanks!
golcarfel is offline   Reply With Quote
Old 08-02-2015, 12:21 PM   #2
pwrby4d's Avatar
do a search on MT82 transmission ford mustang and you will see thousands of posts and issues. From 1500 miles I had the same issue. I had the same issue.
I replaced everything except the gearbox with aftermarket i.e braided clutch line, whittline trans mount, Spec stage 2 aluminum flywheel and clutch, throwout bearing, Barton shifter bracket, MGW shifter and even the rear gears and an aluminum driveshaft all before 13,000 and I still get a tough first gear sometimes but very rare it clashes and grinds when the clutch is let out. Ford said it was normal lol. I just went with my motto of never replace with stock. 2013 model. I only have about 15,000 on it now.
Ford didnt even take the trans out of the car and when we did we found a leaking throwout bearing so that did stop a lot of the issue I had. Maybe start there IDK.
2011 was the first year for that transmission so they had a ton of them that had issues in the 5.0 and quite a few in the 3.7 too.
pwrby4d is offline   Reply With Quote
Old 08-02-2015, 02:13 PM   #3
20prima10's Avatar
Could just be bad syncros.
Honestly on a manual trans it can be a lot of small things.
20prima10 is offline   Reply With Quote
Old 08-02-2015, 05:49 PM   #4
Meaningoflife90's Avatar
Mine does that to! I just thought it was normal, and i always bring it down to second before first anyways. Changed the fluid in it yet? I used the Redline MTL, and it smoothed it out, the biggest change was its not crunchy in first and second anymore. I dont know, worth a try.
Its probably broken...
2012 Mustang V6,
3:73's, Airaid Intake, Dynomax VT Exhaust, Hotchkis Stage 1 kit, Hopes and Dreams injection.
Meaningoflife90 is offline   Reply With Quote
Old 08-03-2015, 10:16 AM   #5
ddtmoto's Avatar
Region: Utah
Sounds like your clutch is not completely disengaging. There was an issue with some flywheels having the pressure plate bolts backing out. Dealer could check pretty easy on a lift. I believe there is TSB on the issue..
ddtmoto is offline   Reply With Quote
Old 08-03-2015, 10:18 AM   #6
Strange Mud's Avatar
+1 on checking the tsb also on some aftermarket shifters the reverse lockout may need to be adjusted.
Strange Mud is online now   Reply With Quote
Old 08-03-2015, 02:25 PM   #7
Yea, I've been reading a lot about it in the past few weeks. I replaced the stock clutch and flywheel with a Spec version from American Muscle and also replaced the throwout bearing. I wonder if the thowout bearing that I got was faulty. Is there anyway to check it without having to lower the transmission and removing the clutch and flywheel? I was thinking into replacing both the shifter bracket and the shifter with a nice aftermarket one, hoping that would solve the problem. I have read in a couple of forums that the stock shifter bracket is complete crap and could twist and cause the problems that I am experiencing. Even thought going from second to first to get the car started works most of the time, I sometimes have a hard time going into second gear. All only from neutral. Once the car is moving, even slightly, the car tends to shift like normal.
Yea, the more I read about it, the more I see that it has a lot of problems. I don't think that it would be the syncros, given that I only have the problem when moving into gear from neutral. I feel that if it was the syncros, it would be a problem going into gear always.
Yea, I'm looking into changing the fluids. Did you change the transmission fluid yourself or did you take it to the shop? And if you did it yourself, was it difficult to do?
I skimmed the web a little for TSB for the Spec cluthc/flywheel system that I bought but didn't find anything that was relevant to my problem, but I'll dig a little deeper. I'll also look into clutch disengaging problems and see if that could be the possible cause. What would be some other symptoms of the clutch not completely disengaging?
I looked into the reverse lookout system and I don't believe that that is the problem. If the reverse lockout was sticking out too far to cause the troubled shifting, it would occur at any time of the shifting process, both while stopped and while moving. But my problem seems to occur only while the car is stopped. When the car is moving, even sligthly, the car shifts into first gear and all of the other gears with ease.
Thank you so much for all of the help and all of the advice guys, I really appreciate it!
Old 08-04-2015, 06:58 AM   #8
Voltwings's Avatar
There's also a lockout that wont let you into first over like 10 mph, are you sure you're not fighting with that?
Old 08-04-2015, 05:06 PM   #9
It wasnt hard, just do yourself a favir and buy that fluid transfer pump from like oreillys! Its not hard at all!
2012 Mustang V6,
Old 08-04-2015, 07:05 PM   #10
ddtmoto's Avatar
Region: Utah
Heal toe, brake and gas. Blip the throttle on down shifts. Tough for us old guys..rev matching helps every where. When coming to a stop, just a few feet before the car stops I slide her into first. I usually start in second. 1st gear with my 3.73s is for launching and impressing normal people....
Old 08-05-2015, 01:38 PM   #11
Just a thought to check out--the clutch is hydraulic using fluid from the brake reservoir. Make sure the fluid level is right, and check for air in the line. Might need to be bled.
kipschitz is offline   Reply With Quote
Old 08-05-2015, 03:45 PM   #12
iantrusive's Avatar
I thought this was normal for all manual cars. Every manual car I've driven has done this with first gear and reverse. Only pops in after the car moves like a fraction of an inch. Always thought it was due to the transmission fluid settling after a while which makes it tougher to align with the synchro. That was just my thought though, there is no research behind it lol
Sent from my Mustang.
iantrusive is offline   Reply With Quote
Transmission not going into 5th gear Jr Sager Pre-2005 V6 Mustang 1 10-19-2014 11:05 AM
Vibration behind dashboard on 1st and 2nd (Manual Trans) MrxBurrito Pre-2005 V6 Mustang 2 07-14-2013 09:44 PM
1st time going to the track, questions?? MikeC 2011-2014 Mustang GT 8 08-30-2012 12:21 PM
1976 ford mustang will not start, not headlights come on, it is not the battery, why? eifion Classic Mustangs 6 08-24-2009 03:12 AM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 09:08 AM
04:23 PM
