Exhaust question - Mustang Evolution
Old 08-02-2015, 12:26 PM   #1
Gumbus's Avatar
Exhaust question
Would putting GT over axles and GT stingers on my v6 be a simple bolt on?
2013 mustang v6 premium
Gumbus is offline   Reply With Quote
Old 08-02-2015, 12:36 PM   #2
Exhaust question
Yep. Just loosen up some clamps and work the pipe off. Then work the new pipe in and tighten the clamps. Do that while aligning the tips to make sure they're centered and even.
Once you're under it, it's pretty self explanatory.
Pick your poison.
Old 08-02-2015, 12:50 PM   #3
FastFord13's Avatar
Hmm, doesn't the Gt's pipe have a little bigger diameter than the 3.7s? I could be wrong though.
Sent from LG G3.
Old 08-02-2015, 03:02 PM   #4
Sent from LG G3.
You correct on the size difference. It will be a simple bolt on until you try and couple the midpipe to the catback this is the only mod needed to make it work. To make it easier the op can get the oem gt h-pipe and weld it in place of the v6 hybrid section
Bigshow14 is offline   Reply With Quote
Old 08-02-2015, 03:17 PM   #5
Mean14's Avatar
3.7 exhaust is 2.25" and 5.0s I believe at 2.5"
You can always get an adapter piece at any auto store to make it happen without having to weld anything. You run the risk of an exhaust leak but it'd be a lot cheaper than welding.
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
exhaust
Exhaust Exhaust Exhaust cdouglas12 2005-2010 Mustang GT 10 01-24-2015 09:37 PM
Exhaust Install? Not typical question about which exhaust is best.. satin06silver 2005-2010 V6 Mustang 7 01-08-2015 04:56 PM
One exhaust tip a little off after Boss exhaust install mmike87 2011-2014 Mustang GT 6 09-21-2012 07:42 PM
New Exhaust Video......3'' Exhaust WaldoGT07 General Mustang Discussion 0 12-20-2011 07:59 PM
04:05 AM
