Sticky brake pedal or imagination. 14 mustang - Mustang Evolution
Old 08-06-2015, 08:04 AM   #1
4lexC's Avatar
Hey guys. My pedal seems to come up little slower after braking. Is this normal. I mean the car us you new. Is it how the system is set up?
4lexC is offline   Reply With Quote
Old 08-06-2015, 08:20 AM   #2
Strange Mud's Avatar
I've seen several complaints about clutch pedals sticking...i don't remember any brake pedal complaints.
Old 08-06-2015, 08:38 AM   #3
Voltwings's Avatar
Give us details, how many miles on the car, standard or auto, how was the car being driven when it happened, does it happen often ... details.
Old 08-06-2015, 08:52 AM   #4
Senior Member
rlma84's Avatar
I hear a clunk sound on mine when i take my foot off
rlma84 is offline   Reply With Quote
Old 08-06-2015, 08:55 AM   #5
Senior Member
rlma84's Avatar
I also have this problem anyone knows if its normal? 20000 miles 2013 gt
https://youtu.be/qVBzAnpWc_Y
Old 08-06-2015, 09:00 AM   #6
Kevin.Cook
Guest
Posts: n/a
I would like to know from the OP, if it happens when the car is cold started and braking before the brakes heat up. Or if it happens when the brakes are already hot and used alot. Maybe both?
Old 08-06-2015, 12:44 PM   #7
4lexC's Avatar
It does it cold or not. It makes a hissing sound when pressed which is normal then come back up little slower than other cars(I know every car is different) and it's a 2014 v6 performance pack. 18k miles
Old 08-06-2015, 12:47 PM   #8
Kevin.Cook
Guest
Posts: n/a
I wonder if your brake booster is shot. Don't these also have a check valve?
Old 08-06-2015, 12:53 PM   #9
Voltwings's Avatar
how many miles on the car? Have the brakes ever been bled?
Old 08-06-2015, 12:53 PM   #10
Manual transmission or automatic?
I drove a 2015 at an Ecoboost challenge a while back and both the brake pedal and clutch pedal were doing what you described.
It didn't seem "normal" to me.
Old 08-06-2015, 01:04 PM   #11
Voltwings's Avatar
people dragging the brakes / pumping the clutch / heating the fluid. That car needed to be bled, and i'm willing to bet OPs does too. Even cars running super bad *** fluid have to bleed the brakes again after a track weekend, and that's brand new fluid. Most street cars go WAY over the recommended interval because its just not something people keep up with.
Old 08-06-2015, 03:11 PM   #12
4lexC's Avatar
Had the brakes bled 2 weeks ago. Just the clutch comes back real fast the brake pedal comes back little slower like squeezing a bottle of windex (not that slow but you et the idea)
---------- Post added at 09:11 PM ---------- Previous post was at 09:11 PM ----------
Manual
Old 08-06-2015, 03:14 PM   #13
Voltwings's Avatar
Hmm... interesting.
Old 08-06-2015, 03:19 PM   #14
Kevin.Cook
Guest
Posts: n/a
Originally Posted by Voltwings View Post
Hmm... interesting.
Voltwings sir...
Do you think it could be possible a hose has a small leak or the brake booster could be messing up?
Old 08-07-2015, 07:31 AM   #15
tym_v6's Avatar
OP, are you noticing the level in the master cylinder reservoir dropping at all?
Old 08-08-2015, 08:00 AM   #16
jande063's Avatar
I have intermittently had this issue. Pedal also intermittently feels spongy on the inward stroke. Have spent some time dataloging with an IR imager, and found that most of the time my car is actuating no more than two calipers. Possibly not the same issue, but this has put me more firmly on the path that i have been chasing a faulty abs module for the last year (I know, shocking). Other symptoms include random moments where the brake pedal will not move due to the abs module having shut off all input due to a faulty ice mode trip, advancetrac becoming homicidal and randomly actuating individual calipers while cruising, and calipers locking up solid for minutes at a time, then unlocking after a key cycle (only after destroying my $3500 axle).
jande063 is offline   Reply With Quote
Old 08-09-2015, 06:48 AM   #17
4lexC's Avatar
Not really. I had everything checked said it was okay but when pressing its fine but coming back up its little slower. It just doesn't pop back up to normal position its like air is coming out
Shaking clutch pedal until pedal is pushed GHO5T5NIPER 1996-2004 Mustang GT 78 05-03-2015 11:47 PM
Brake noise from brake pedal blooce 2005-2010 Mustang GT 8 09-30-2012 06:41 PM
I have a 1992 mustang GT. and everytime i push down the brake pedal it squeaks. whats wrong? Adalard 1979-1995 Mustang GT 6 12-16-2011 04:15 AM
Adjust brake pedal 06 V6 Mustang gonzo56 Pre-2005 V6 Mustang 1 04-06-2011 01:07 PM
Clicking sounds when depressed brake pedal jaynez31 New Member Introductions & Greetings 2 11-30-2005 08:01 PM
10:15 AM
