Loose steering and soft brake pedal on my 2013 v6 - Mustang Evolution
Old 08-08-2015, 10:40 PM   #1
I have a 2013 V6 with about 35k miles. The steering wheel has a little play and wants to fade left by a tad on the higway. When braking hard the steering wheel turns left. I just has a lower control arm replaced and it still does this. The wheels are aligned from what ford said. When I go over bumpy roads at 30 mph the wheel turns left and right. Also the brake pedal is soft in traffic. I have to push it in about a quarter of the way before it begins to slow down. Has anyone else had these issues on their Sixxer?
racemamxx is offline   Reply With Quote
Old 08-09-2015, 07:29 AM   #2
jayochs's Avatar
might be my imagination, but sometimes I think mine pulls slightly left a bit. but my steering is pretty tight. it's insane how responsive it is
Sent from my Galaxy Note 4
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 08-09-2015, 10:03 AM   #3
Mean14's Avatar
I would recommend getting your alignment double checked. There's a Casey Automotive by me that will check vehicle alignment for free. I would look into getting it double checked. Never trust the stealership. As for the brake pedal.. maybe time for new pads?
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 08-09-2015, 12:55 PM   #4
TrevorMCA's Avatar
Did you change the steering setting for your steering? I know there are 3: Standard, comfort, and sport. Sport is real tight and responsive. I love it. Could be a fix and is worth a try.
Trevor
TrevorMCA is offline   Reply With Quote
Soft Brake Pedal Issue TheJigShow 1996-2004 Mustang GT 11 03-17-2016 06:05 PM
Gas pedal loose robin_gt 1996-2004 Mustang GT 3 04-08-2015 01:22 PM
bleed brakes and still soft pedal? rwheels 2011-2014 Mustang GT 1 08-09-2014 03:04 PM
New clutch, too soft pedal FerKnight 2005-2010 V6 Mustang 2 08-29-2011 11:37 AM
07:18 PM
