Bluetooth audio disconnecting - Mustang Evolution
Old 08-11-2015, 08:01 AM   #1
austin3.7's Avatar
Is anyone else having a problem with their Bluetooth audio disconnecting? For the past 3 days every time I connect my iPhone 5s to my car it will connect but the second I try to play music it will disconnect my phone, I've also tried doing it through the USB but that also won't work. I can receive calls through my car but if I answer the phone through my car it quits working also. Does anyone know how to fix this?
---------- Post added at 08:01 AM ---------- Previous post was at 08:00 AM ----------
Also, I updated the sync a few months ago when the update came out and I haven't had any problems until now.
austin3.7 is offline   Reply With Quote
Old 08-11-2015, 08:04 AM   #2
austin3.7's Avatar
I've done the master reset on the radio and disconnected SYNC from my phone and reconnected it and nothing seems to work.
Old 08-11-2015, 08:13 AM   #3
20prima10's Avatar
Reset network settings on your phone. There's a fuse you can pull to completely reset the radio. Idk off hand the number of it. But find it and pull out for 5-10 min.
Then put it back in and turn the radio on. Reinstall your phone to the radio.
If that does not work I would try your specific phone in a different car or try a different phone to your car. That will let you know if it's your phone or your car having issues. If it's your car. Take it and have it analyzed. If it's your phone your s.o.o.l. Unless you are due for a new one
2013 pp mca 3.7 glass roof
2.5% dl tinted windows
Bbk shortys
20"resonators
Roush ab.
Bama/mpt tunes
More coming visually for now.
20prima10 is offline   Reply With Quote
Old 08-11-2015, 08:35 AM   #4
austin3.7's Avatar
I tried my iPad and that also didn't work but of course literally right after I posted this I got in my car and it magically started to work again!
Old 08-11-2015, 08:42 AM   #5
20prima10's Avatar
Small glitch lol
Bbk shortys
20"resonators
Roush ab.
Bama/mpt tunes
Old 08-11-2015, 09:45 AM   #6
I had this happen with my android a month or so ago. pulled the fuse for sync, put it back in and it has worked every since.
rgstelzner is offline   Reply With Quote
Old 08-11-2015, 09:46 AM   #7
austin3.7's Avatar
Do you know what fuse that is?
Old 08-11-2015, 09:57 AM   #8
I believe its fuse #3 in the passenger footwell. Check your owners manual just to be sure.
Old 08-11-2015, 10:09 AM   #9
20prima10's Avatar
+1
Bbk shortys
20"resonators
Roush ab.
Bama/mpt tunes
Old 08-11-2015, 02:12 PM   #10
Harm_3.7's Avatar
Had this happen to me a couple days ago. I disconnected the battery and pulled the fuse for 10 minutes and it works fine now.
IG: justaslow3.7
Harm_3.7 is offline   Reply With Quote
Old 08-11-2015, 02:15 PM   #11
rringler's Avatar
Yup. This is what fixed my issue as well.
rringler is offline   Reply With Quote
Old 08-11-2015, 06:28 PM   #12
jonyou's Avatar
Also check on the ford service site that the dealer had you register your car on. Check for a sync update. This can fix a lot of problems if it hasn't been updated lately and its a fairly simple install just have to have a usb stick laying around.
2014 V6 Performance Package Sterling Grey
MPT Tuned.
Airaid CAI, BBK Shorty Headers, Borla S-types, Stubby Antenna, JLT Catch Can, MMD hood struts, GT500 spoiler, Oracle Halos on GT Grille, Dynotech One piece Aluminum Driveshaft.
jonyou is offline   Reply With Quote
Old 08-11-2015, 06:54 PM   #13
Abominable Mustang
WhoDat's Avatar
Region: Alaska
He mentions that he's already updated it.
IG: justaslow3.7
That seems a bit redundant haha.
2012 Kona Blue 3.7L V6:
Old 08-11-2015, 11:28 PM   #14
jonyou's Avatar
ahh my bad didn't see the edit
MPT Tuned.
Old 08-12-2015, 06:01 AM   #15
I believe I saw they pulled the sync update because it had some issues. Biggest thing ice noticed since the update is the response speech clarity is terrible. Garbled or like the sync voice is mumbling.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
Old 08-12-2015, 11:54 AM   #16
SterlingStang's Avatar
There is an update for sync its mostly an improvement in my experience however the 911 assist is annoying and I have also noticed some strange connecting disconnecting phone issues but overall everything works
Sent from my HTC One_M8 using Mustang Evolution mobile app
SterlingStang is offline   Reply With Quote
Old 09-07-2015, 09:29 AM   #17
Chrism's Avatar
You have to completely remove your phone from the car and then manually connect it again with the pin code and all that and then it should work. That's what I did with my mustang. Or you could take it to the dealer.
Chrism is offline   Reply With Quote
Old 09-09-2015, 05:25 PM   #18
I've had constant problems with bluetooth disconnecting, errors playing music USB, and 911 assist. I've done a master reset about 6 times. Each time it behaves for a few weeks and then problems start.
I've used 2 different phones. It's the newest SYNC update that came out in the spring. No problems before the update, constant problems after the update. I even re-installed the update a second time.
MapmanKC is offline   Reply With Quote
Bluetooth Audio blackmamba8 2011-2014 V6 Mustang 11 11-03-2014 10:37 PM
Always saying "BLUETOOTH AUDIO" iaintacop Mustang DIY and Technical 12 09-29-2014 10:29 AM
Sync and bluetooth audio... the_stig 2011-2014 V6 Mustang 7 03-21-2012 11:14 AM
Car Stalling after disconnecting battery nero 1979-1995 Mustang GT 7 01-17-2011 02:01 PM
Good bluetooth headsets? MarkuzLS1 The Bar 16 07-18-2006 10:18 AM
06:27 PM
