Suspension Question - Mustang Evolution
Old 08-12-2015, 12:20 PM   #1
Socal Stangman's Avatar
Suspension Question
Ok I have an issue I want to fix but not sure exactly what would fix it, heres my problem...
When Im doing some "spirited" driving and Im going around a curve or turn and then hit a bump, it feels like the front end has a mind of its own. Does this make sense? Its pretty annoying because I feel like I could loose control, I know I wont but it has a weird feel to it. I do plan on upgrading my shocks and struts but I have some other things I need to take care of first. I was going to do the Koni orange or the Eibachs but Im afraid they will be too soft...is this a strut issue anyway?
Old 08-12-2015, 12:24 PM   #2
Kevin.Cook
Guest
Posts: n/a
How are your tires? Alignment? Have you lifted the front end and tried to move the front wheels up and down - side to side? IF there is alot of play, it may be tie rod ends or ball joints. I had that issue on my old 3000GT. Someone else may have other suggestions.
Old 08-12-2015, 12:33 PM   #3
Everything else is good. I only have 12000 miles on the car. I dont mean to make it sound like its a super bad issue. I just find it more annoying than anything else.
Old 08-12-2015, 12:36 PM   #4
Kevin.Cook
Guest
Posts: n/a
Very rarely this happens to me. But if you hit big pot holes a lot and such, it wouldn't be bad to lift up the front wheels and check for play.
Old 08-12-2015, 12:36 PM   #5
Voltwings's Avatar
Is the front end wanting to wander around, or is it getting thrown around?
Old 08-12-2015, 12:44 PM   #6
No it drives great great. Its just when I hit the bumps the front gets " unsettled". It might be just the way the car is. Its hard to describe...
Old 08-12-2015, 12:47 PM   #7
Kevin.Cook
Guest
Posts: n/a
As in if you hit a pot hole or bump, the tires want to follow along with it, no matter how hard you hold the steering wheel in place?
Old 08-12-2015, 12:56 PM   #8
Yeah pretty much like that. If I see something as Im making a turn I feel myself almost grabbing the wheel a little harder.
Old 08-12-2015, 01:12 PM   #9
Kevin.Cook
Guest
Posts: n/a
Same issue I had with my old Mitsu. I guess if you ever get bored, you could always check the wheels for play. That would be my only suggestion if your alignment is correct.
Old 08-12-2015, 01:13 PM   #10
tj@steeda's Avatar
Hello OP,
I would check the bushings on the front lower control arms. They may have failed (common problem).
Hope that helps!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 08-12-2015, 02:23 PM   #11
JDM
JDM's Avatar
Are you certain the movement is from the front and not the rear axle movement when it travels over the bump?
2014 Deep Impact Blue V6
JDM is offline   Reply With Quote
Old 08-12-2015, 02:26 PM   #12
Originally Posted by tj@steeda View Post
Hello OP,
Hope that helps!
Best Regards,
TJ
Thanks. I guess it cant hurt to have them checked.
No its the front for sure.
Old 08-12-2015, 06:06 PM   #13
Diehard's Avatar
Just sounds like a soft suspension to me. Hitting a bump on a curve naturally throws the car a bit because the tires leave the ground slightly. Like my old soft riding Mercury Grand Marquis.
Old 08-12-2015, 09:17 PM   #14
Mean14's Avatar
Upgrade your sway bar.. whiteline FTW!
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 08-13-2015, 12:19 PM   #15
pitboss's Avatar
You need a bump steer kit. Pretty cheap fix
2012 Pony Pkg 3.7 convertible, MPT tuned, 4.10's, Dynotech 3.5" DS, Borla Touring axle backs, BBK 73mm TB and ceramic shorties, Whiteline sway bars and UCA/LCA with relocation brackets, BMR adj. PHB and brace, Steeda CAI, CE frame braces, Bilstein shocks, H&R race springs, SS brake lines, full HID, GT 500 gauge pod with gauges and misc. exterior upgrades
pitboss is offline   Reply With Quote
Old 08-13-2015, 08:39 PM   #16
Really? I'm not sure I've seen this before. I'll check it out. Is it easy to install?
Old 08-13-2015, 08:52 PM   #17
Bump steer kit, this is the solution!! I've been reading some reviews on this and some of the things people describe in the reviews are the same problems I'm having.
Old 08-13-2015, 08:54 PM   #18
Kevin.Cook
Guest
Posts: n/a
There ya go man! If you get it, let us know what you experience.
Old 08-14-2015, 05:09 AM   #19
20prima10's Avatar
As previously stated a bump steer kit will fix 90% of this. You'll still get it time to time on bigger bumps though.
2013 pp mca 3.7 glass roof
2.5% dl tinted windows
Bbk shortys
20"resonators
Roush ab.
Bama/mpt tunes
More coming visually for now.
20prima10 is offline   Reply With Quote
Old 08-14-2015, 08:19 AM   #20
tj@steeda's Avatar
You still want to check the bushings to ensure they are still in good shape ... then you can try the Bumpsteer kit:
Steeda 2005-14 Mustang Bumpsteer Kit - Made in USA 555-8106 | Free Shipping!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 08-14-2015, 08:27 PM   #21
pitboss's Avatar
I'm going to get a set sometime also. Can't decide between steeda or SR. Ether way will help suspension stay settled in twisties
Old 08-14-2015, 09:42 PM   #22
Sounds like the rebound on the struts needs to be a bit stiffer.
Old 08-17-2015, 03:38 AM   #23
jande063's Avatar
Sounds like the woes of a panhard bar to me. When you hit a bump, the axle shifts to the side and up, causing the whole car to get unsettled. Check your front end for damage, forget the bumpsteer kit, and if no damage, find someone with a watts link car to ride in. Everyone who says that they are not worth it has never had one.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 08-17-2015, 07:52 AM   #24
tj@steeda's Avatar
pitboss,
Can't go wrong with American Made parts by an American Company - you are getting high quality parts that are manufactured in the U.S. when you run with Steeda - you will be very happy with the parts.
Let me know if I can help assist with your order!
TJ
Steeda Autosports
www.steeda.com
Old 08-17-2015, 09:39 AM   #25
Ok so heres what Im getting from all the responses...I should add or change every suspension component on my car...correct? Lol...
Old 08-17-2015, 11:42 AM   #26
tj@steeda's Avatar
Yes & no ... lol. It may be one part that you need ... it may be another part you need. Suggest starting with one part, if that fixes the problem, then problem solved. The issue is, sometimes it is not one particular "solve all" problem.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 08-17-2015, 01:02 PM   #27
Best Regards,
TJ
Yeah I agree. This winter Ill be spending my time and money with suspension upgrades. Im sure at some point Ill end up replacing pretty much everything anyway...
Old 08-17-2015, 01:53 PM   #28
Diehard's Avatar
Right! LOL and you knew what to expect for answers before you asked.
Old 08-17-2015, 02:01 PM   #29
Lol, I guess I did.
Old 08-17-2015, 02:04 PM   #30
iguanaman3's Avatar
It could be your toe settings, have you noticed any extra wear on the inside edges of your front tread? I had bump steering problems when mine was too toed out.
iguanaman3 is offline   Reply With Quote
Old 08-18-2015, 03:37 AM   #31
jande063's Avatar
I drove for half a year with a full degree of toe out and 2.6 degrees negative camber, and did not have bump steer issues. That said, my car has not been a mustang for quite some time.
Soften up suspension: for those post suspension mods Jvibe92 2011-2014 Mustang GT 14 03-03-2015 02:05 PM
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
Front Suspension Question 00vertstang Pre-2005 V6 Mustang 2 09-29-2006 10:55 AM
suspension question horess05 Pre-2005 V6 Mustang 11 05-21-2004 07:10 PM
Suspension question GoIn2Shock Pre-2005 V6 Mustang 3 01-13-2004 02:33 PM
01:37 AM
