Is V6 sway bar the same as GT - Mustang Evolution
Old 08-17-2015, 10:04 AM   #1
I purchased a GT take off sway bar from ebay. When I tried to install it to my car, I realize that their diameters are of no difference. Below are their part numbers:
My 2014 V6 manual mustang: BR33-5482-EE-E29EA
The GT sway bar I purchased: BR33-5482-ED-E29EA
So I assume they are the same thing?
I called the dealer and they told me that the V6 mustang has the same sway bar as the GT convertible. GT coupe has a different sway bar.
Anyone knows the details?
2014 Mustang 3.7L cyclone engine with 6 spd transmission. Mods: 93 MPT Race Tune, 3.31 Gears, Airaid CAI, BBK Shorty Ceramic Headers, Corsa Sport axle backs, Strut Tower Brace, Steeda rear seat X-brace, BMR Rear LCAs, GT wheels, MGW race spec shifter, Passenger seat delete, spare tire delete, Moroso battery relocation to the trunk.
liv4spd is offline   Reply With Quote
Old 08-17-2015, 11:19 AM   #2
Socal Stangman's Avatar
Its possible the GT ones are set up a little stiffer, but overall they would be the same. If you already had sway bars why would you buy more stock parts anyway even if they were from a GT? Why not go aftermarket?
Old 08-17-2015, 11:34 AM   #3
Thank you for sharing your thoughts. I don't want to invest too much money on it. After all, it is a V6. I am trying to save up for a Corvette or a Cayman.
Stock parts are not necessarily bad. I just put Boss springs on my car, the change in cornering is phenomenal.
Old 08-17-2015, 11:53 AM   #4
Kevin.Cook
Guest
Posts: n/a
Well, with the v6 pp, the front sway bar was swapped with a GT. So i would assume they are a tad stiffer. So you could swap it out. You might not feel a difference and aftermarket might be better. But since you have the part, might as well put it on. Save the stock v6 one in case anything happens to the GT one.
Old 08-17-2015, 12:07 PM   #5
Thanks for the suggestion. If the difference is small, I might wait till fall to put it on. It is so hot in my garage right now.
Old 08-17-2015, 12:10 PM   #6
NewMtang's Avatar
Your putting parts that are made for a V8, not another V6. The springs may actually cause you to lose control in a tight turn.
So your saving up for a Vette or a Porsche. Why don't you just leave you car stock and you have more money for your new car. When are you plan on purchasing either one? 2030 or later?
Old 08-17-2015, 12:12 PM   #7
Nothing wrong with a Vette', Id trade my car in for one in a second.
To be honest Im not sure its worth the time to put it in. Then on the other hand you wont know until you try...hopefully you didnt spend to much money on them.
Old 08-17-2015, 12:19 PM   #8
Thanks!
Life is short. Try all kind of cars when you can. There is no need to stick with one model car forever.
Old 08-17-2015, 05:03 PM   #9
tym_v6's Avatar
I also know that on the V6, the rear sway bar is larger diameter than in the stock V6. What I don't know is if the bigger bar is pulled off a GT or not (might very well be, as that would be easiest/cheapest for Ford).
Old 08-17-2015, 06:12 PM   #10
2011 Kona Blue's Avatar
I sure do love those Vettes. Since you are trying to save up for a vette or Cayman, why buy any parts for your just a V6? Sounds like buying a GT sway bar was a waste of money when you have a perfectly fine sway bar on the V6 Wouldn't it make more sense to put that money towards the vette or Cayman?
What was the purpose of buying the Gt sway bar? Why?????
Sent from my SAMSUNG-SM-G890A using Mustang Evolution mobile app
Old 08-17-2015, 06:31 PM   #11
Diehard's Avatar
Sway Bar Sizes from 2014 Source Book
Old 08-17-2015, 06:40 PM   #12
Kevin.Cook
Guest
Posts: n/a
So as long as that GT sway bar isn't from a convertable, and you don't have the V6 PP, then it is a mild upgrade.
Old 08-17-2015, 06:43 PM   #13
tym_v6's Avatar
Originally Posted by Diehard View Post
Interesting! So looks like the V6 PP gets the "fattest" sway bar combo available, assuming the stiffness isn't somehow different between the GT bars of the same diameter...
Old 08-17-2015, 06:53 PM   #14
Kevin.Cook
Guest
Posts: n/a
Nope. The V6 PP equipped cars get a GT front swaybar and an older cobra/svt rear swaybar iirc.
Old 08-17-2015, 06:56 PM   #15
Thanks for the information. This is very helpful.
Old 08-19-2015, 03:41 AM   #16
I installed stock GT coupe front and rear sway bars on a stock 2014 base V6 coupe and the difference is night and day, a huge improvement.
I did the rear first and it overpowered the stock V6 front sway bar. Then installed the front GT sway bar and the car handled tremendously better, a terrific improvement with both front and rear GT coupe sway bars installed, well worth doing, easy install.
GT 1 is offline   Reply With Quote
Old 08-19-2015, 07:05 AM   #17
Excellent!
Thank you for sharing your experience.
Old 08-19-2015, 07:10 AM   #18
Kevin.Cook
Guest
Posts: n/a
No problem...
Old 08-19-2015, 09:41 AM   #19
bucko's Avatar
If you're looking for an upgraded rear sway bar for your V6, consider one from a GT500 or Boss 302; they are larger than your stock V6 one.
Old 08-19-2015, 11:06 AM   #20
Diehard's Avatar
Don't know about the GT500 but on the Boss 302 it appears that only the rear is bigger than the GT or V6 PP.
Front/Rear (mm)
GT - 34.6/24.0
Boss 302 - 34.6/25.0
Laguna Seca Package - 34.6/26.0
EDIT: The 2011 GT's apparently had a different rear stabilizer bar. Shows as a 44mm. ?? The after markets are using 25mm for rear.
Old 08-20-2015, 05:51 AM   #21
jande063's Avatar
Bigger sway bars are not always better. This car is fastest with a moderately sized rear bar. A lot of the ESP guys use the base V6 bar in their Boss 302's just to soften the back, otherwise you cannot productively put the power down.
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 08-20-2015, 07:05 AM   #22
In drag racing the front sway bar is sometimes unbolted or removed. For daily driver the GT sway bars are excellent. I absolutely would NOT use the base V6 rear sway bar. I tried that and the handling was dangerous. For real road racing l would consider the larger rear bars mentioned.
Old 08-20-2015, 08:47 AM   #23
Voltwings's Avatar
---------- Post added at 09:47 AM ---------- Previous post was at 09:47 AM ----------
Your suspension package as a whole needs to be considered, but he's right, a lot of people use the softer rear bar with great success.
Its the nature of all RWD cars, they almost all prefer more front bar than rear, so when you start jacking the rear up, you make them that much more tail happy. If you installed a smaller rear bar and were having issues, then something else is the problem. Either that, or it wasn't properly paired with the front bar or your overall spring rates.
Poly bushing replacement in PH bar and sway bar rear 5LHO 2011-2014 Mustang GT 0 02-21-2015 12:38 PM
For a 1966 mustang, should I get a 1' sway bar or a 1' 1/8 sway bar, does it matter? Carthage Classic Mustangs 1 12-16-2011 06:37 PM
sway bar STEVE Mustang Parts for Sale and Wanted 31 07-04-2004 05:58 PM
sway bar STEVE Pre-2005 V6 Mustang 18 05-28-2004 09:38 AM
Sway bar Question 01mineralgrey6 Pre-2005 V6 Mustang 35 05-03-2004 11:20 PM
09:50 PM
