Tpms - Mustang Evolution
Old 08-18-2015, 07:00 AM   #1
Gumbus's Avatar
Tpms
When I take my tires to the shop to be mounted and balanced, will it be possible for them to switch the tpms from my stock wheel to the new ones?
2013 mustang v6 premium
Gumbus is offline   Reply With Quote
Old 08-18-2015, 08:01 AM   #2
Diehard's Avatar
I would certainly think so.
You'd be looking at added cost to break down, and I assume remount, your stock tires. This would be added cost vs. buying new sensors off eBay. You may want to do a quick comparison.
Old 08-18-2015, 08:08 AM   #3
Gumbus's Avatar
Thanks that's what I was thinking.
Old 08-18-2015, 08:11 AM   #4
Strange Mud's Avatar
yes, but if your old rim/tire setup is still good I'd buy new ones. Or do what I do with my 2nd set that did not come with them and cover the light with tape.
Old 08-18-2015, 08:35 AM   #5
Gumbus's Avatar
I might just run without them. Will the tire shop install wheels that don't have them?
Old 08-18-2015, 08:52 AM   #6
Robostang's Avatar
Interesting question. My shop indicated to me that they cannot mount tires on a car without sensors (if the car came with them) however they will mount tires on wheels without them since they don't know what car they will be mounted on. Some crazy law.
2012 Kona Blue GT Premium 401A, Manual, 3.55, Steeda Pro-Action Shocks, Struts, Sport Springs, LCAs, Adjustable Swaybars, Adjustable Panhard Bar, BMR Relocation Brackets and Adjustable UCA, Driveshaft Shop Aluminum Drive Shaft, Airaid CAI, MGW Shifter, GT500 Axle-Backs, 3M Clear Bra and Tint, Side Window Louvers, JLT Oil Separator, Staggered MMD Zeven Wheels and Mickey Thompson Street Comp Tires, Bama 93 Race Tune
Robostang is offline   Reply With Quote
Old 08-18-2015, 09:31 AM   #7
idk but agree with Rob. It will depend on shop. If you just bring the 4 tires and rims I don't see why not. If they are on a car who knows. I have been told by shops that they couldn't patch my tire because of where the hole was (and this is a shop that free patched a tire for me b4)
Old 08-18-2015, 10:08 AM   #8
Gumbus's Avatar
Well what do you guys advise? Is getting new tmps worth it?
Old 08-18-2015, 10:13 AM   #9
I'm cheap....if it cost more than $50 no.
On my 2nd set of rims I looked for a while and subtracted $100 from the price I was willing to spend if they didn't have them. You have to put a piece of tape on the idiot tpms light and each time you start the car you'll have to hit reset on the msg center (and once in a while randomly)
this is assuming you'll check tire pressure at least once a month
Old 08-18-2015, 10:17 AM   #10
Gumbus's Avatar
The ones on eBay are about $50. I'd probably check my tire pressure though
Old 08-18-2015, 10:36 AM   #11
GRREEN's Avatar
My 2013 Mustang has aftermarket wheels with brand new sensors that were
put on two years ago and I hadn't bothered to check the tire pressure since and recently
discovered that they only had 20 psi in them, yet I never received any warning from the dash that they were low. On my wife's 2010 Camaro, the warning light trips at 29 psi. Does Ford warn you when the pressure is zero, or is there something wrong with my car?
GRREEN is offline   Reply With Quote
Old 08-18-2015, 12:19 PM   #12
Mlp07's Avatar
You have to drive a certain amount of miles, for the car to warn you its low. Also it depends what tire pressure you programmed it to be at. We have a 07 Avalanche and on the truck, it tells you what's the exact tire pressure on each tire. I don't know if the premium cluster has that feature.
Mlp07 is offline   Reply With Quote
Old 08-18-2015, 12:44 PM   #13
Diehard's Avatar
It's generally set at +/-25% .
For example, if tire pressure is suppose to be 32 psi, an 8 to 9 psi drop (23 psi) should trigger them.
EDIT: BTW...The TMPS is not meant to be a substitute for checking your air pressure manually. Or so they say.
Then they shouldn't make them a requirement for inspections, is the way I see it. But that's another subject.
Old 08-18-2015, 03:20 PM   #14
Mean14's Avatar
Tpms
No one has mentioned this, but when taking old tpms sensors and putting them in a new tire, they are going to have to rebuild the seals/grommets to prevent future leaks. I got quoted $15 per sensor to rebuild plus another $15 per wheel to rebalance. So you're looking at $120 to have them transferred when you can buy new ones for about $150ish
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 08-18-2015, 03:53 PM   #15
Diehard's Avatar
Wow that's interesting. Sounds like new ones are definitely the way to go.
Old 08-19-2015, 02:31 AM   #16
Mustangs's Avatar
Americas tire did it for me for free
Mustangs is offline   Reply With Quote
Tpms sensors Black5.0 2011-2014 Mustang GT 3 11-19-2011 11:56 AM
2011 Valve TPMS itsme37421 2011-2014 Mustang GT 2 10-16-2011 03:27 PM
tpms question 07stang 2005-2010 Mustang GT 6 12-31-2009 11:35 PM
TPMS light ?? wkndpaintballer 2005-2010 Mustang GT 11 11-09-2009 09:23 AM
TPMS Darkhorse_MD 2005-2010 Mustang GT 1 04-11-2008 09:38 AM
07:56 PM
