Prepping for track day: Brakes on a budget - Mustang Evolution
Old 08-21-2015, 12:05 AM   #1
Sakib's Avatar
I'm registered for a track weekend (road racing, not drag strip) in two weeks. This will be my first time road racing. We need to pass an inspection before, one of the requirements is near new brake pads and a brake fluid flush in the past 6 months. Now my car has 50K and I haven't done any brake maintenance yet, so it is definitely time anyway. However, I want to invest in a proper brake upgrade with high performance pads, larger rotors, stainless steel lines in the not-too-distant future, but not now, not for this track weekend. I'd rather just pass inspection for now for as cheap as possible, because I want to just run these down for a short time before I do the major upgrade after this season. So my question is, what is the minimum I could do now to get a great bang for the buck and also not be unsafe on the track?
What I am thinking:
- PowerStop Z23 ceramic pads, front and rear = $80 on AM
- Turning all four rotors = let's say $60
- 3L DOT 4 brake fluid for a full flush = need a recommendation for a good one
What do you all think of this plan? Am I missing anything critical and/or endangering myself? Any other advice?
Sakib is offline   Reply With Quote
Old 08-21-2015, 03:24 AM   #2
Jza1736's Avatar
Get a second set for track use. I have oem rotors and i use hawk dtc 70 for the front and dtc 60 for the rear. It's an easy swap once you get used to doing it. Don't skimp on brakes for the track!
Dot 4 fluid is also a good idea. I use motul 600, or has a nice high boiling point.
Sent from my SM-N920P using Tapatalk
Jza1736 is offline   Reply With Quote
Old 08-21-2015, 04:03 AM   #3
jande063's Avatar
Before turning your rotors down, make sure to mic them and check to see that they are plenty over spec. If you tell me which brake options your car has, I can give you the factory spec from my copy of the service manuals.
Fluid, you can't go wrong with the Motul, but 2 liters will do it, no need for three
Pads, this is a sticky subject. Most cars can get away with a set of Hawk HP+, but not an S197. You need to go to an actual track pad like a Hawk DTC, or a higher number Carbotech. Call Sam Strano, as at this point, you have completely left the realm that AM can give good advice.
Welcome to the deep end of the pool, and recognize two facts, as spoken by Peter Egan.
"Never let your ego outrun your contact patches."
"Auto racing makes a heroin addiction look like a mild desire for something salty."
2014 Mustang V6-Built to run TTB, CAM-C, and ESP
Proving to my fellow racers that the disdain that some GT drivers have for V6 drivers is unfounded, one results archive at a time since 2013.
jande063 is offline   Reply With Quote
Old 08-21-2015, 11:56 AM   #4
Sakib's Avatar
Thanks for the advice. A member contacted me and sold me his Carbotech XP10 front pads for $50, they had seen two track days. He is also selling me his FRPP brake duct kit. I'll let him be anonymous unless he chooses to reveal himself here. I will make these a dedicated track set of pads. I'll decide on something more tame and quiet for my street pair. Not sure what I'm going to do about the rears yet. Might get Carbotech XP8 for the track, to-be-determined for the street, not too concerned about that yet. Just looking forward to the track weekend in two weeks. Yes, jande, I am super excited for it - it has been all I can think about for past few days!
Old 08-21-2015, 12:01 PM   #5
Jza1736's Avatar
It is a blast. What track are you running?
Old 08-21-2015, 12:07 PM   #6
Sakib's Avatar
Texas World Speedway in College Station. Texas World Speedway
Old 08-21-2015, 12:09 PM   #7
Jza1736's Avatar
Brake ducts will be good I'm sure it's hot down there.
Old 08-21-2015, 12:10 PM   #8
Sakib's Avatar
God yes it is. Until yesterday it went over 100F every day for about a month.
Old 08-21-2015, 12:27 PM   #9
Fabman's Avatar
I spoke with Edwin at Hawk a few weeks ago.
He suggested DTC 60 front and Blue 9012 for the rear on my s197
I have 14" Baer pro+6 pistons up front and 14" rear rotors with GT 500 calipers rear. He seemed to think that there was going to be too much rear bias....which I thought was odd, but he's the pro so I went with it.
I'll be running them next month on the 19th so stay tuned on that one.
Tuned by AED
*694 RWHP/677 RWTQ* 10.22@136mph
Currently Assaulting California's Roadcourses
Fabman is offline   Reply With Quote
Old 08-21-2015, 02:54 PM   #10
jande063's Avatar
To be honest, I run as little pad in the rear as I can. I am just trying to insulate the caliper with it more than give much in the way of braking force (all of the top guys in AI do this also). That said, I have a fairly unorthodox driving style, most who ride with me for an example of what to do tend to come away with the conclusion that I am out of my mind...
Mustangs like to have a higher front brake bias, as it helps them rotate on braking. It allows you to make use of the weight transfer of small steering inputs to cause the axle to give you rear steer, and if you are using all the available friction at the back for braking, they will scrub instead of pivot.
Old 08-21-2015, 04:47 PM   #11
Fabman's Avatar
I drove stock cars for decades...I always had a knob on the dash so I could adjust as needed. I don't like the idea of having someone picking the bias for me and being stuck with it.
Tuned by AED
Photo - Steeda is Prepping for the 2015 Mustang ... Are You? tj@steeda 2015+ Mustang Ecoboost (and V6) 8 06-04-2015 08:23 PM
$90 Track Day@Willow Springs-Big Track- Feb 4th in SoCal Extremespeed Regional Mustang Discussion 0 01-15-2012 11:12 PM
$125 Track Day@WillowSprings-Big Track-Dec 17-18 in Socal Extremespeed Regional Mustang Discussion 3 12-13-2011 02:12 AM
$109 Track Day@WillowSprings-Big Track-August 13-14 in Socal Extremespeed Regional Mustang Discussion 1 08-04-2011 02:54 AM
$125 track day at Willow Springs-Big Willow Track-February 5th in SoCal Extremespeed General Mustang Discussion 1 01-06-2011 11:25 PM
06:22 PM
