2013 2014 Mustang Rear diffuser question - Mustang Evolution
Old 08-23-2015, 09:40 PM   #1
JohnnyBob's Avatar
I currently have the roush square top diffuser, my question is can I purchase the boss diffuser and fit it without a problem?
JohnnyBob is offline   Reply With Quote
Old 08-23-2015, 09:53 PM   #2
Bear376's Avatar
I don't think so. The Roush is designed to work with their exhaust system only. I wanted to install the Boss diffuser, but not if I have to cut the lower bumper. And I don't care for the Roush mufflers, so I won't install the Roush diffuser. Just can't win sometimes.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 08-23-2015, 09:57 PM   #3
oxford5pointoh's Avatar
The way I read this is that you are asking if the diffuser will still work after having the roush square diffuser? If that's all your asking then I don't see why not. The cut outs on the stock bumper should be the same, but even if they are not the boss diffuser will cover up jenky cuts on the bumper itself. Now as for the square tips fitting in the boss diffuser? I'd guess no. But it's a simple swap to the round tips and problem solved.
Old 08-24-2015, 12:55 AM   #4
JohnnyBob's Avatar
Not was I was asking but answered the question still. I have the Roush diffuser and I am looking to switch over to the Boss diffuser (going back to round tips) due to me selling the stang. That way I can install the stock exhaust mufflers.
Essentially what I'm trying to ask is if the cutouts (when I say cut outs I mean what I had to drill and saw to fit the tabs) to fit the Roush diffuser the same as the Boss diffuser that way I can just plug-and-play?
Old 08-24-2015, 07:57 AM   #5
Mean14's Avatar
Name:	ImageUploadedByMustang Evolution1440424529.759138.jpg
That is the piece that I had to cut off to install the Boss302 diffuser. I'm guessing it's the same exact setup for the Roush because there are pre-drawn lines to cut as well as four tabs (2 on each side) to cut out. Hope this helps
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
2014 mustang
My first big Mod (Boss 302 rear diffuser) Charlesph55 2011-2014 V6 Mustang 14 07-11-2014 08:08 AM
Cali specail rear diffuser Big_red502 2011-2014 V6 Mustang 1 08-25-2013 01:38 PM
For Sale: 2010-12 GT500/Boss 302 Rear Bumper Diffuser BlueSoulStang Mustang Parts for Sale and Wanted 2 06-19-2013 03:53 PM
Boss or RTR rear diffuser McQueen 2011-2014 Mustang GT 6 09-12-2012 05:34 PM
First design of custom rear diffuser. Opinions? Yellow50 2011-2014 Mustang GT 4 08-03-2012 10:06 PM
08:26 PM
