Spark Plug change - Mustang Evolution
Old 08-24-2015, 01:54 PM   #1
Kevin.Cook
Guest
Posts: n/a
Spark Plug change
I know this is going to come off as super noob. But please give me the benefit of the doubt as I am trying to learn to do this myself.
I want to do a spark plug change myself on my 2011. I have the NGK plugs and a upper intake manifold gasket. However, I am a little clueless on how to actually do it. I see talk about gapping plugs and such. The only other time I have ever changed spark plugs was on my old 3000GT and it did not need any "Gap" for the plugs. Do they simply go in? PLEASE someone explain this to me
Old 08-24-2015, 02:06 PM   #2
Commercial Member
au01st's Avatar
http://v6mustangperformance.com/repa...-3-7l-mustang/
Have a Raxiom nav system? Hate having two antennas? Contact me to wire your nav thru your factory satellite radio antenna!
"Holy crap bro. You're a genius." - 2011 Kona Blue
au01st is offline   Reply With Quote
Old 08-24-2015, 02:08 PM   #3
Rosariors3's Avatar
Most plugs are already gapped. Not hard to change out the plugs. Just need proper tools and elbow grease
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 08-24-2015, 02:10 PM   #4
Kevin.Cook
Guest
Posts: n/a
I saw that and this part confused me:
These were gapped over .45 from the factory. Nick the tuner at ProCharger recommended I gap them from .35 to .38 (because of the blower)
Does that mean without a blower, you want it "gapped" at .45? From what I see so far, Gapping is just how far the metal tip is from the electrode and you adjust accordingly?
Old 08-24-2015, 02:10 PM   #5
Mean14's Avatar
ALWAYS double check that they are properly gapped. There have been plenty of times where they say they come gapped, and I end up having to redo them
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 08-24-2015, 02:13 PM   #6
Kevin.Cook
Guest
Posts: n/a
Ok. I got the ones from MPT. Not sure how good they are about gapping and such. I will go buy the tool needed to check the gap tonight.
Old 08-24-2015, 02:16 PM   #7
Rosariors3's Avatar
^ yea absolutely u should always question everything. To the op the company that sold in the blower do they sell the plugs as a kit with the blower? Meaning thatvtheybwill be gapped specific for the blower
Old 08-24-2015, 02:17 PM   #8
Kevin.Cook
Guest
Posts: n/a
Not sure. I bought the 6 plugs by themselves.
Old 08-24-2015, 02:19 PM   #9
Rosariors3's Avatar
That's ok gapping is no biggie. Ul b fine installing them. If the plugs are tough to remove don't be scared to give it a good torque to remove it. They won't break
Old 08-24-2015, 02:24 PM   #10
Kevin.Cook
Guest
Posts: n/a
Alrighty. And since I will be replacing all 6, I guess it doesn't matter what order they go in right? Is there a bolt sequence for the upper intake manifold?
Old 08-24-2015, 02:32 PM   #11
Rosariors3's Avatar
No specific order... As far as the manifold it should just unsnap. No bolts hold it together
Old 08-24-2015, 02:34 PM   #12
Kevin.Cook
Guest
Posts: n/a
You sure? I thought the upper intake manifold was held in by 6-7 bolts...
"Now for the Passenger side. You will need to remove the intake manifold. There are 7 bolts on the top."
Old 08-24-2015, 02:42 PM   #13
Rosariors3's Avatar
My bad I was thinking valve cover.. Ur right
Old 08-24-2015, 02:50 PM   #14
Rosariors3's Avatar
My setup is diff than yours
Old 08-24-2015, 02:54 PM   #15
Mean14's Avatar
Make sure to use anti-seize on the threads when reinstalling!
Old 08-24-2015, 02:57 PM   #16
Rosariors3's Avatar
That's more of a preference.. Not required. I didn't put any on mine. Than again im not gonna drive my car 10's of thousands of miles before replacing them
Old 08-24-2015, 03:07 PM   #17
Kevin.Cook
Guest
Posts: n/a
I will pick some up with the gap tool/item tonight. Kind of nervous to do this. lol. So when putting the spark plugs back in, am I ok to used the socket wrench/deep spark plug socket to screw in the plugs or will this mess up their thread?
Old 08-24-2015, 03:13 PM   #18
Rosariors3's Avatar
That's fine.. And don't be nervous U won't mess anythyhing up. When u put the plugs in hand tighten first than use the socket to prob tighten a little more. Best way I can explain if u were looking at a clock tighten to 1:00
Old 08-24-2015, 03:16 PM   #19
Kevin.Cook
Guest
Posts: n/a
Thanks! Not sure if I will attempt this tonight or wait until this weekend.
Old 08-24-2015, 03:23 PM   #20
Rosariors3's Avatar
Post ur results and if u have any question u can pm me. I'm not a professional but I've changed plugs on my own car so I know what it entails.
Old 08-24-2015, 03:24 PM   #21
Kevin.Cook
Guest
Posts: n/a
Will do. Just hoping getting the upper intake manifold doesn't take long. On the 3000GT, that part alone is a good hour.
Old 08-24-2015, 03:30 PM   #22
Rosariors3's Avatar
It will prob take u around that long if u haven't done it before. U shouldn't worry about time if u never done it . Ul prob need a couple hrs befor Everything is finished
Old 08-24-2015, 05:02 PM   #23
Kevin.Cook
Guest
Posts: n/a
So the plugs are gapped from MPT at .42. Is that ok?
I will have to do this, this weekend. Just to be safe and give myself plenty of time. I picked up Anti-seize gel and the dielectric grease just in case. Also got a gap checker and a spark plug socket.
Old 08-24-2015, 05:08 PM   #24
Rosariors3's Avatar
Well if u said that the company that sold u the blower said .35-.38 I think ? If u trust this guy and he knows what ur trying to do than I would say go ahead.
Old 08-24-2015, 05:12 PM   #25
Kevin.Cook
Guest
Posts: n/a
I have no idea what you are talking about. lol. I didn't buy a blower. This car is completely stock from Ford w/ the performance package. I am looking for stock specs.
Old 08-24-2015, 05:16 PM   #26
Rosariors3's Avatar
That's what made me think u had a blower
Old 08-24-2015, 05:17 PM   #27
Kevin.Cook
Guest
Posts: n/a
This is happening on the 2011
Old 08-24-2015, 05:18 PM   #28
Kevin.Cook
Guest
Posts: n/a
Oh nah. That was just a quote from the link au01st posted.
Old 08-24-2015, 05:24 PM   #29
Rosariors3's Avatar
I honestly don't know what the specs are for ur car and I don't wanna tell u something that wouldn't t be true. I would remove ur old plug and check what that is and match that withy the new plug. When u bought the plug did u specify it was for if car? Even if u did still check the old plug and c where it's set at. Also why r u replacing the plugs?
Old 08-24-2015, 06:23 PM   #30
Kevin.Cook
Guest
Posts: n/a
100k+ miles.
Old 08-24-2015, 06:25 PM   #31
Rosariors3's Avatar
Yea for some reason I thought u had a 14
Old 08-24-2015, 06:40 PM   #32
oxford5pointoh's Avatar
He has 2 3.7's. 11 & 14
Old 08-24-2015, 06:44 PM   #33
Kevin.Cook
Guest
Posts: n/a
I will keep googling but I am sure someone has changed plugs on a 3.7 that can lend this info.
Old 08-24-2015, 06:59 PM   #34
Kevin.Cook
Guest
Posts: n/a
Yea, I can't find anything for our 3.7s :/ Just need the gap specs at this point to be 100% sure.
Old 08-24-2015, 06:59 PM   #35
.45 gap from the factory.
Great write up
mustang turning off after spark plug change nsguido415 1979-1995 Mustang GT 24 08-25-2015 06:58 PM
Spark plugs and spark plug wires??? Moyhuerta 1979-1995 Mustang GT 11 12-05-2012 08:42 AM
E3 Spark Plugs Diamond Fire - Spark Plug gonzo56 2005-2010 V6 Mustang 6 09-28-2011 09:45 AM
spark plug change? maximus 1996-2004 Mustang GT 17 07-08-2009 07:18 AM
Spark plug change Rellik The Bar 7 08-20-2003 06:04 PM
08:41 AM
