Trust the gauge or the light - Mustang Evolution
Old 08-25-2015, 10:35 AM   #1
Hey, I'm currently having an issue with my gas gauge. I was running low on gas yesterday so I put $20 worth the gas in which put my up to a little over a quarter tank on the gauge.
Problem is the light that indicates I'm low on gas won't turn off and it says I'm 30 miles to E, but after doing some math I should have much more than that, along with the gauge indicating I have more gas than that. Anyone else ever have this problem?
TrevorHolmberg is offline   Reply With Quote
Old 08-25-2015, 10:47 AM   #2
pitboss's Avatar
There may be a recall on the gas gauges. Check with your dealership
2012 Pony Pkg 3.7 convertible, MPT tuned, 4.10's, Dynotech 3.5" DS, Borla Touring axle backs, BBK 73mm TB and ceramic shorties, Whiteline sway bars and UCA/LCA with relocation brackets, BMR adj. PHB and brace, Steeda CAI, CE frame braces, Bilstein shocks, H&R race springs, SS brake lines, full HID, GT 500 gauge pod with gauges and misc. exterior upgrades
pitboss is offline   Reply With Quote
Old 08-25-2015, 12:36 PM   #3
Diehard's Avatar
Sounds like you can't trust either one.
Play it safe (until you get it fixed) and start from a full tank and go like 200 miles and fill again. Unless of course you think you average less than about 16 MPG.
Old 08-25-2015, 01:22 PM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Disconnect the battery for 5-10 minutes. See if that resets the ecm's fuel eco calculations.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 08-25-2015, 01:45 PM   #5
Mean14's Avatar
Did you keep your car running when you filled up?
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 08-25-2015, 02:08 PM   #6
No
Old 08-26-2015, 08:03 AM   #7
Strange Mud's Avatar
the miles to empty calculates using available gallons x how many MPG you averaged over the last 500 miles. Also remember with the split tank design it leaves 1-2 gallons per side. The light does come on early and I find the tank small but I'm not convinced you have a problem other than needing gas.
Old 08-26-2015, 08:06 AM   #8
People like this are the reason we'll never have hydrogen powered cars.
Old 08-26-2015, 11:53 AM   #9
DEvermore's Avatar
Region: Iowa
Aw, ye of little faith! Sure we will! Consequently people who leave their cars running while fueling will suddenly be no more a problem.
2017 GT350 w/electronics package.
DEvermore is offline   Reply With Quote
Old 08-26-2015, 12:17 PM   #10
Kevin.Cook
Guest
Posts: n/a
LMAO! I like this one.
Old 08-26-2015, 12:19 PM   #11
Lol, very true. Except I don't want to be the guy next to the idiot filling up with the car running.
Or the idiot filling up gas cans in the bed of their pickup...I've actually SEEN that before... Again, there is a potential for that problem to eliminate itself haha.
Shops you trust in austin tx TXstang125 Regional Mustang Discussion 4 09-05-2012 08:02 AM
I can full trust my car Jfoster General Mustang Discussion 6 01-05-2011 07:00 AM
Trust me...I know what i'm doing! at7311 Pictures and Videos 6 05-13-2008 01:06 PM
Trust the skittles touch. n8r Pictures and Videos 8 08-21-2007 09:41 AM
06:09 AM
