Whining - Mustang Evolution
Old 08-25-2015, 02:47 PM   #1
Scott2byrd3's Avatar
Whining
So not sure if anyone else has this issue but about the middle of the day around noon if i go for lunch and when i start my car i hear a Whining from a belt and i am not sure why but it goes away when i start driving after about 30 seconds. any else have this?
Scott2byrd3 is offline   Reply With Quote
Old 08-25-2015, 02:48 PM   #2
Kevin.Cook
Guest
Posts: n/a
Could be a bad tensioner, belt, pulley, etc. Have you had anything inspected?
Old 08-25-2015, 02:54 PM   #3
Never happens besides around noon and only for around 30 seconds :/
Old 08-25-2015, 02:58 PM   #4
Kevin.Cook
Guest
Posts: n/a
Then maybe just the temperature around that time of day exposes a weak component. Best to inspect the belt and such.
Old 08-25-2015, 03:08 PM   #5
Kevin.Cook
Guest
Posts: n/a
How many miles on the ride?
Old 08-25-2015, 03:11 PM   #6
Whatever you do, don't use any of the old treatments for fan belts (soap, any lubricating spray, etc.). The new serpentine belts HATE being lubed, and if you are getting a belt squeel at any time, it is more related to a pulley being out of line, a tensioner being weak or one of those prematurely wearing the belt itself.
The noon thing is just related to the belt being warmer and for some reason slipping enough to squeel.
Old 08-25-2015, 03:12 PM   #7
parkerz28's Avatar
What you eating for lunch... Mustang may want Honda not Taco Bell lol
Sent from the back seat
parkerz28 is offline   Reply With Quote
Old 08-25-2015, 03:16 PM   #8
Kevin.Cook
Guest
Posts: n/a
WTF? LMAO!!!!
Old 08-25-2015, 03:18 PM   #9
Mean14's Avatar
Hahahahah!
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 08-25-2015, 03:23 PM   #10
parkerz28's Avatar
lol my wife doesn't find me funny 😥
Old 08-25-2015, 04:38 PM   #11
66k currently
Sent from my HTCONE using Mustang Evolution mobile app
Old 08-25-2015, 06:10 PM   #12
Kevin.Cook
Guest
Posts: n/a
I would definitely get the pulleys inspected and check the belt.
Old 08-26-2015, 10:16 AM   #13
So I just now poped the hood and listend to the sound it sounds like it is not coming from a belt it sounds more like it's coming from a driver side injector or back of the motor on that side
Old 08-26-2015, 10:18 AM   #14
Kevin.Cook
Guest
Posts: n/a
Have someone give the car gas while you listen under the hood. See if you can further pinpoint it or if the sound changes.
Old 08-26-2015, 10:20 AM   #15
It goes away when I press the gas
Old 08-26-2015, 10:23 AM   #16
Kevin.Cook
Guest
Posts: n/a
Possibly a leak somewhere then. Could be exhaust or vacuum. Exhaust might be more of a ticking though. The pressure or load increase can make it apparent or go away. Double check/trace all hoses and make sure everything is connected and tight.
Edit - Can someone confirm if the timing chains and pulleys are in the back of the engine or front?
Trying to look at this diagram but it doesn't specify - http://www.fixya.com/cars/t12736493-...7_timing_chain
Old 08-26-2015, 10:44 AM   #17
I think it might be a timing pulley >.> the more i listen to it because it is coming from with in the motor i know that for a fact now. but it does not seem to be affecting performance... In fact since this started happening about 2 months now or so. I have been getting really good 0-60 times better than before it started to happen. <.<
Old 08-26-2015, 10:49 AM   #18
Kevin.Cook
Guest
Posts: n/a
That would suck if it was a pulley. I had one go out on my 3000GT while I was driving down the road. Luckily, the engine came out fine in the end and once I got the timing issue squared away, the car was good to drive again.
Old 08-26-2015, 04:54 PM   #19
There's a thread on this somewhere here in the v6 section. A lot of people's cars do this on start-up, including mine. I think it my have been titled something like "squealing" or "screeching."
CUBuffalo is offline   Reply With Quote
Old 08-26-2015, 04:59 PM   #20
Here's one of the threads. I think there's another thread out there though.
Belt sound?
Old 08-27-2015, 10:55 AM   #21
blackstang1's Avatar
Have had the exact same problem since ~2k miles. Told the dealer about it and they explained that they couldn't help me if it wasn't reproduced with them. For me, it happens mostly in the morning when the humidity is slightly high. It goes away after 30 seconds and i have read a lot of other owners having the same problem so I'm not too worried about it.
2014 Mustang V6 w/Technology package, 6MT
Mods: Airaid CAI w/ Synthamax filter, 18" black AMR wheels
blackstang1 is offline   Reply With Quote
Old 08-27-2015, 11:26 AM   #22
I listened to it today at lunch. it was 72F today. and it sounds like it coming from the drivers side header maybe it is just a exhaust leak with me...
Old 08-27-2015, 11:40 AM   #23
jayochs's Avatar
my squelching happens at like 6 to 700 rpms only. and it only does it at certain temperatures. it's really weird and annoying, yet goes away when the car warms up. saw a lot of other people had the issue too. I've got a video of mine on YouTube here https://youtu.be/3e9BlVR7L8Q
Sent from my Galaxy Note 4
2014 Ford Mustang 3.7 Premium 6-speed:
MPT Performance Tune, AM Laguna Seca Black 19" Rims, Borla Touring Axlebacks, Boss 302 Strut Tower Brace, Airaid Modular Intake Tube, aFe Pro Dry S Air Filter, Mustang GT Grille w/ Foglight Mesh, Taillight Tint, Tinted Door Ventvisors, Diode Dynamics LED's
jayochs is offline   Reply With Quote
Old 09-07-2015, 10:38 AM   #24
Chrism's Avatar
It happens to me to. I'm going to change my clutch next week, I'll tell you if that fix the problem or not.
Chrism is offline   Reply With Quote
Old 09-09-2015, 08:57 AM   #25
CodyC's Avatar
Yup, does it to mine too. From what I've seen with other v6 owners, it seems like humidity plays a factor, though that's just a theory. It does seem to be a "normal" problem that resolves itself within 30 seconds to a minute. I drive in a parking garage at my job so I can hear it bounce off the walls pretty clearly when I leave, but still have no idea what causes it.
CodyC is offline   Reply With Quote
Whining noise coming from engine area johnb554 2005-2010 Mustang GT 13 05-05-2017 05:55 PM
2012 5.0 whining noise? Superstang General Mustang Discussion 8 01-25-2012 08:15 PM
whining noises? 96civic87 Pre-2005 V6 Mustang 12 11-15-2011 01:52 PM
8.8 rear end whining 67mustang97 1996-2004 Mustang GT 2 04-18-2010 09:34 PM
Whining noise? SVTCOBRA Pre-2005 V6 Mustang 13 02-20-2010 11:58 AM
05:01 AM
