Trunk Mat/ Spare Tire Cover - Mustang Evolution
Old 08-25-2015, 05:39 PM   #1
TrevorMCA's Avatar
So I put 2 cases of water in my trunk awhile back and when I got home I noticed the mat/cover was bent and I guess it's made if styrofoam or something. I cut a board to fit over for the most part and a post that sits right where the tire should go. It rattles really bad when I drive and I don't know what else to do. Any suggestions?
Trevor
TrevorMCA is offline   Reply With Quote
Old 08-25-2015, 08:21 PM   #2
Mean14's Avatar
I went to hobby lobby and bought some fluffy cotton stuff for like four bucks and stuffed it in there. Also, wrapped a towel around the threaded steel bolt to insulate it between the mat and steel
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 08-25-2015, 08:48 PM   #3
tym_v6's Avatar
There should be some sort of particle board or something attached to the carpet/cover. I've put some really heavy stuff in there and it hasn't warped. I too had to sneak some foam under the particle board bits so they wouldn't vibrate when driving.
01:51 PM
