Anyone installed braided clutch line before? - Mustang Evolution
Old 08-26-2015, 08:23 PM   #1
Any tricks, or anything I need to be aware of?
2014 Mustang 3.7L cyclone engine with 6 spd transmission. Mods: 93 MPT Race Tune, 3.31 Gears, Airaid CAI, BBK Shorty Ceramic Headers, Corsa Sport axle backs, Strut Tower Brace, Steeda rear seat X-brace, BMR Rear LCAs, GT wheels, MGW race spec shifter, Passenger seat delete, spare tire delete, Moroso battery relocation to the trunk.
liv4spd is offline   Reply With Quote
Old 08-26-2015, 08:28 PM   #2
Kevin.Cook
Guest
Posts: n/a
Following. I am interested as well.
Old 08-26-2015, 11:02 PM   #3
ak_stang's Avatar
Region: Alaska
Brake fluid is terrible for paint, accidentally spilled a little on and wiped it off not 5 seconds later and some paint rubbed off with it, also don't loose the little metal retaining clips when you pop them off
Sent from my LG-D801 using Mustang Evolution mobile app
ak_stang is offline   Reply With Quote
Old 08-26-2015, 11:39 PM   #4
Marc3.71994's Avatar
The metal clip on the end that attaches near the fire wall is easy to loose be very careful, the other metal clip that attaches to the tranny will not come all the way out so you don't have to worry about loosing that one. The install is very simple. Our cars have a self bleeding system, once the new hose is in, pump the hose 100+ times, eventually you will get full pressure back and your good to go.
Marc
Marc3.71994 is offline   Reply With Quote
Old 08-27-2015, 10:22 AM   #5
Voltwings's Avatar
Also, firmly press the line into the transmission and be aware of a slight "click." I felt mine wasnt in all the way so i kept pushing and pushing and pushing and ... cracked the plastic fitting into the trans -_- had to take it to the dealership to get replaced. Just get it in there firm is all it takes. Also, a decent, long set of needle nose pliers makes getting the fitting off the trans side a lot easier.
Old 08-27-2015, 10:32 AM   #6
Strange Mud's Avatar
besides stressing DO NOT DROP CLIP!
I had to re-bleed mine the next day.....100-200 pedal push
I'll suggest if you are a cautious type to attach a piece of string on the clip before removal (not that I did) so if you drop it you won't have to look for 5 minutes to find it (and be glad you did find it)
Old 08-27-2015, 12:31 PM   #7
Thank you all for these invaluable suggestions!
I'll pay special attention to:
1) not losing the clips,
2) listening to the click sound and not use too much force to break the adapter,
3) cleaning up the brake fluid right away.
Marc
Old 08-27-2015, 12:58 PM   #8
gotta mention I did this and I liked the theory of it I didn't notice any difference. For the $ and ease I'm glad I did it but this was one of the few MT "improvements" I didn't notice.
Old 08-29-2015, 09:30 AM   #9
I just finished installing mine. It was super easy. I first pulled out the clip near the transmission from underneath the car, then the one at the other end (located close to the brake booster). In the next step, I pulled the stock clutch line from above. Installation was the reverse. It only took me 15 minutes. I had to pump my clutch with hand for 150 times, then with foot for another 60 times.
I have to disagree with Strange_Mud on this mod. My clutch now feels much crisper even when the car is cold.
Many thanks again for the great suggestions that helped make my installation drama free.
Old 08-29-2015, 10:04 AM   #10
Mean14's Avatar
The self bleeding process of pumping the clutch pedal 200+ times is a pita. The first 80 I had to do by hand because the pedal wouldn't retract. Then it started to achieve some stiffness to it and I kept pumping and pumping what felt like three days..
I thought I messed something up at first because it too so long for the firmness to come back. But just keep pumping. It will come back eventually. Took me longer to bleed the system than to install the actual part lol
Procharged D1 on 12Lbs, MPT 93 Tune, 73mm BBK TB, Ported Upper/Lower Intakes, BBK Shorty Headers, FRPP Cut n Clamp Xpipe, Borla S-Types, Barton Short Shifter/Blowfish Bracket, SS Clutch Line, Whiteline Trans Bushing, One Piece Driveshaft, Front and Rear Tower Brace, Whiteline Front and Rear Sway Bars, Whiteline Adj LCAs/Adj UCA, BMR Relocation Brackets, BMR adj Panhard Bar, Eibach Sportlines, FRPP Dampers, 20" AMRs, 3.55 gears, Brembos
Mean14 is offline   Reply With Quote
Old 08-29-2015, 05:42 PM   #11
I admit to being an Oaf....
you may have to re bleed it the next day, if you gotta go to work/school/jail Monday you may want to leave a bit early just to check it. It took mine nowhere near as much bleeding the 2nd day.
Old 08-29-2015, 06:18 PM   #12
Thanks for the suggestions! I'll give it more pumps on Sunday.
With this clutch line, a new shifter bracket and Whiteline insert, the stock shifter and MT-82 feels so much better.
Old 09-05-2015, 12:23 PM   #13
Mean14's Avatar
Change out the trans fluid and it will feel even better!
Old 09-05-2015, 02:14 PM   #14
What fluid are you running?
I put BG Synchroshift II from Mercedes Benz in. It seems to be an improvement.
Old 09-05-2015, 02:24 PM   #15
Mean14's Avatar
I went with RP Synchromax. I did all the supporting mods to clean up the shifting on the MT82 and when I changed the crappy stock fluid out, it kind of brought everything together and my high rpm 1-2 shifts are better than ever.
Old 09-05-2015, 03:33 PM   #16
FastFord13's Avatar
This is what I've done, RP syncromax along with a Barton shifter bracket and have had 0 issues shifting at any Rpm.
Mt 82 has been great since the fluid and bracket change over 2 years ago.
Sent from LG G3.
braided s.s. brakelines foxbox 1979-1995 Mustang GT 3 12-21-2013 04:14 PM
Clutch fluid line?? muscledom 2005-2010 Mustang GT 2 12-19-2012 01:09 PM
Braided Universal Dipstick Herbstang Pre-2005 V6 Mustang 0 10-09-2012 10:12 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 04:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 05:44 PM
05:40 PM
